TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > General BMW X5 (E70) and X5M Forum (2006-2013)
      03-24-2019, 12:48 AM   #67
Autobacs
Autobacs's Avatar
Drives: 2019 BMW X6M
Changed out my spark plugs and put heat shields on crossover lines, filtered air ducts, and water lines on top of engine.
2019 BMW X6M
2013 Lexus RX450H
2010 Nissan GTR AMS Omega 14
9vapors653.50
      03-24-2019, 01:20 AM   #68
9vapors
Drives: CB X5M
Got any pics of the heat shielding you used?
      03-24-2019, 02:47 AM   #69
Autobacs
Autobacs's Avatar
2019 BMW X6M
2013 Lexus RX450H
9vapors653.50
      03-24-2019, 07:43 AM   #70
9vapors
Drives: CB X5M
Attachment 2016908
Good stuff man! I did something similar in the first post. Hopefully it helps!
      03-24-2019, 12:28 PM   #71
pdX5M
pdX5M's Avatar
Drives: E70 X5M
2013 BMW X5 M  [0.00]
Originally Posted by pdX5M View Post
Installing Active Autowerke downpipes and Velos Stage 2+ tune today. Might do the spark plugs as well if I have time. Fingers crossed for a smooth install! Buddy has a shop at his house with a lift and all so that's a huge plus
Downpipes are a mofo, but as you said, with a buddy and lift, that changes everything!
Downpipes are in and tune is flashed but had a pretty gnarly exhaust leak up at one of the v bands on top. Going to BMW tomorrow to pick up a new v band clamp and new gaskets. Hopefully will have this job wrapped up tomorrow afternoon.
- 2013 X5 M - Silverstone Metallic w/ Black Perforated Complete Merino - All OEM Options - 12.5mm/20mm Spacers - Velos Stage 2 - xHP Stage 3 - AA Catless - Megan Racing Supremo - PTP Blanket - K&N Drop In -
      03-24-2019, 03:49 PM   #72
Yanchii
Moldova
59
Drives: 09 BMW X5 35D
Attachment 2016908
Where did you buy them from??
      03-24-2019, 04:08 PM   #73
Sophisticated Redneck
Drives: 2012 BMW X5 50i
Sounds like you are getting the BMW brand, I tried going cheap and have exhaust leaks too. I noticed the after market turbo to manifold and turbo to downpipe..errr.. I mean catalytic converter gaskets where thinner then factory BMW and believe this is the source so I just picked up some new ones from BMW too...32 dollars each
9vapors653.50
pdX5M111.50
      03-24-2019, 04:13 PM   #74
I replaced the soft-close latch and motor assembly in the driver's side. I have 142K and open a s close the door at least 10 times a day so really can't complain...well except for the price, no after market versions I would trust so 454 dollars at the dealer.... Pretty easy job over all
9vapors653.50
      03-24-2019, 06:15 PM   #75
9vapors
Drives: CB X5M
Attachment 2016908
I ordered mine off of Amazon.
Design Engineering 010458 Heat... https://www.amazon.com/dp/B06WD8F97P...p_mob_ap_share
      03-24-2019, 07:28 PM   #76
pdX5M
pdX5M's Avatar
Drives: E70 X5M
I ordered the gaskets from FCP Euro that were supposedly OEM graphite gaskets. The gaskets seemed super fat and it was hard to get the top of downpipe lined up and to get the vband to seal on all sides so it was just a huge leak right there.
      03-24-2019, 08:36 PM   #77
Yanchii
Moldova
59
Attachment 2016908
Thank you!
      03-24-2019, 08:41 PM   #78
9vapors
Drives: CB X5M
I got the expensive ones from the dealer, they took a little bit to get them in and fitted. It also took a lot of wrenching and twisting to get the pipes to sit flush against the top turbo side. I had to rubber mallet the vband in place while putting pressure on the pipe. Took all of my strength to get them in place alone. I also had to loosen the exhaust and drop the hangers over and over to get things to sit right, then put them back in reverse. Finally everything was tight and fit. Except, and this is a big one, my bolts in the bottom of the downpipes were too long, so I tightened them all the way and thought that was it, but there was a 1/2 space left on both sides that was a giant exhaust leak and the bottom gaskets eventually flew out of the openings.
Had to air hammer the bolts out and replace them. Was a nightmare... still need to revisit it again when I have some time.
pdX5M111.50
      03-25-2019, 09:40 AM   #79
Colodano
131
Drives: 2010 X5M
Not very exciting, but the bottom tabs from my front bumper to undertray were broken, so I pulled my bumper skin off to fix a dislodged parking sensor, and put it all back together with some zip tie magic. No more hanging plastic, or annoying sensor scream when reversing.
I had been driving my truck for the last few weeks, glad to be back in the M!
9vapors653.50
      03-25-2019, 11:55 AM   #80
Spyro235
Drives: '10 X5D, '04 330i ZHP
Today, I commuted in the X5d... Oh wait, that's every day. I've done around 2k miles since the delete and tune, and I'm super pleased with the setup. Sounds no different from the inside, but crack the windows and you hear those turbos spooling! Wonderful noises! I spend the last 600mile tank driving pretty arrogantly, and I got 28.6 mpg. That's the exact best I ever got before the delete, babying it everywhere with cruise at 70mph. Now cruise is set to 75+, and I'm feeling the acceleration whenever I want to.
The best part is really the launch ability of the X5. Taking off from a brake boost, the old 255 wide winters that I bought the car with ride the struggle bus while trying to keep grip. I can feel the wandering of them playing at their limits, which is a pretty hilarious thing to feel in a 5k pound SUV.
I drive about 140 miles a day now, 100 for commuting and then 40 is round trip to my shop, where my drift car is finally almost back together again. Can't wait to use the X5 to tow it for the first time, it'll be a run to the tire shop for a quick alignment!
Daily/ Tow: 2010 X5 35D - 326k, Deleted w/DUDMD Stage 2, Sutphin Trans tune, Comfort seat retrofit
Fun car: 2004 ZHP 6mt - 256k miles, z4m FCAB, stock. Drift car: 2001 330i for sale
9vapors653.50
      03-25-2019, 04:08 PM   #81
JRiggs2976
Drives: 2013 BMW X5 xDrive35i M Sport
Bought a 2013 BMW X5 xDrive35i.
      03-25-2019, 09:11 PM   #82
pdX5M
pdX5M's Avatar
Drives: E70 X5M
Downpipes are in, leaks are sealed, and tune is flashed with no warning lights on the dash. She definitely pulls harder based on the short test drive I just did. Will have a better feel for the difference with the tune over the next few days and will provide and update with my thoughts.
Edit: one thing I will say right away is that actually hearing the turbos spool is AWESOME!
9vapors653.50
IN-FLT12.00
      03-25-2019, 10:06 PM   #83
Autobacs
Autobacs's Avatar
https://www.ebay.com/itm/Heatshield-...72.m2749.l2649
2019 BMW X6M
2013 Lexus RX450H
      03-25-2019, 10:54 PM   #84
9vapors
Drives: CB X5M
Here's a good video to show we are using these things...
      03-26-2019, 08:53 AM   #85
Nyc Dito
Nyc Dito's Avatar
113
Drives: BMW X5 35d
Anywhere on a 35d where this would be beneficial?
E70 LCI 35D
Sutphin trans tune///xDelete///What EGR?
      03-26-2019, 09:09 AM   #86
9vapors
Drives: CB X5M
I think Yanchii is running some on his front mount inter cooler setup. He might have some better info since his is a diesel...
      03-26-2019, 04:13 PM   #87
9vapors
Drives: CB X5M
Added some new grilles...
TTV8M126.00
      03-26-2019, 05:37 PM   #88
ryansbmw
Drives: 2013 X5 35i M-Sport, 2010 535x
Those look sharp!
VRSF CP & DP | BMS Intake | MHD 2+ Tune | BavSound Stage 1 | 20% Tint
Need coding or modules reset? PM me
9vapors653.50
xbimmers
