10-11-2022, 03:57 PM | #67 |
Rep 4,554
Drives: 2015 328d xDrive
Installed new valve stems and plate frame:
NYC Bimmer259.50 toxik2522.50 |
12-04-2022, 09:44 AM | #68 |
Rep 4,554
Painted the calipers, rotor hubs, and dust shields and ordered a 6WB (still waiting for it)
Before: After:
12-04-2022, 02:13 PM | #69 |
Rep 1,844
any plans for headlight upgrade andrew?
12-04-2022, 04:08 PM | #70 |
215
Rep 190
Which bulbs did you go with for the fog lights?
Did you code it out using Bimmercode? Car looks great. Everytime I see your 403m's it reminds me I need to get mine refurbished |
AndrewC198910949.00 |
12-04-2022, 04:11 PM | #71 | |
Rep 4,554
This is my set up: Front fogs: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Low beams: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 DRL: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Turn signals: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 High Beams: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 That strange parking light bulb: https://www.amazon.com/HSUN-Chipsets...ps%2C81&sr=8-8 Bulb sizes are: H7 for low beam and high beam (but high beam housing has less room so usually bulbs with a fan won't fit) H8 for the front fogs PY21W for the front indicators H6W for the parking lights Custom Fog Light Coding: https://www.bimmerpost.com/forums/sh...php?p=28937662
F30_320D_UK215.00 NYC Bimmer259.50 |
12-04-2022, 04:15 PM | #72 |
215
Rep 190
Thanks man
12-12-2022, 02:38 PM | #73 |
Rep 4,554
Would love OEM LED but too expensive and complicated to retrofit on a budget. Was thinking about these potentially but am worried about the quality and longevity of the parts:
https://www.aliexpress.us/item/32568...9-1671167d4757
NYC Bimmer259.50 |
12-12-2022, 02:39 PM | #74 | |
Rep 1,844
I could be wrong, but from what I've seen, headlights and taillights reproductions have stood the test of time. |
12-12-2022, 02:49 PM | #75 | |
Rep 4,554
https://f30.bimmerpost.com/forums/sh....php?t=1842004
NYC Bimmer259.50 |
12-12-2022, 02:59 PM | #76 | |
Rep 1,844
12-12-2022, 03:04 PM | #77 |
Rep 4,554
I’ll probably cave in and give them a try once I recover from my last round of mods
toxik2522.50 NYC Bimmer259.50 |
12-17-2022, 07:34 AM | #78 |
Rep 4,554
Just got my 6wb, love it!
NYC Bimmer259.50 |
12-17-2022, 03:42 PM | #79 |
215
Rep 190
Nice mod, man! Must update the cabin by whole bunch of years
Interesting how your old tachometer stops at 6k and the new one at 7k So does that mean you can retrofit a petrol 6wb cluster onto a diesel? Is it alot if coding requied for this mod? |
12-17-2022, 07:19 PM | #80 | |
Rep 4,554
Those photos are after install but before coding so fuel doesn’t say diesel and redline is wrong. Both changed after coding. I paid a coder to remote code it for me, wasn’t something easy I could do myself in bimmercode.
12-19-2022, 01:36 AM | #81 |
215
Rep 190
Very cool! Thanks for clarifying
Looks top shelf |
12-20-2022, 02:35 PM | #82 |
Rep 4,554
Trying out some gloss black M Sport fender badges. Not sure if i’ll keep yet, need to sleep on it.
Edit: Did not keep them
03-27-2023, 05:39 PM | #83 |
Rep 4,554
Coded my rear plate lights off in reverse to reduce glare
DIY thread here: https://f30.bimmerpost.com/forums/sh...php?p=29976284
NYC Bimmer259.50 |
04-01-2023, 10:31 AM | #84 |
901
Rep 223
Drives: 2012 335i Sport
Really enjoyed following your build, has given me lots of inspiration for my own Imperial Blue Metallic! One thing I like in particular is how light you went on your tint, I’m on the fence between going after your set up or something in the 35-45 range.
I’m currently debating whether to prioritize a tint before summer hits or go after other mods first. How big of a difference with heat transmission did you feel after the tint? |
04-01-2023, 10:54 AM | #85 | |
Rep 4,554
The ceramic tint makes a huge difference in the summer, especially with a black interior. I see you’re in NoVA like me, so a lighter tint like 40-50 will be fine. If you were in Arizona or something I’d recommend going darker. It’s also perfectly legal to go 50% all around in VA which is nice, don’t have to worry about the police. The 80% on my windshield isn’t technically legal, but it’s light enough where no one will ever notice. I got my state inspection sticker without any issue. The only annoying thing will be removing it when it expires. Will have to do it myself with a plastic razor blade so the tint isn’t damaged. Definitely worth the hastle though, not having the windshield covered is like only putting sunscreen on 3/4 of your body. Obviously ceramic tint isn’t a miracle product, the car will still heat up when you park outside for long periods of time, and you’ll still want to use a sunshade and crack the sunroof (also tinted), but when you’re parking for shorter periods, and driving with the AC on (no longer have to blast it) it really makes a world of difference. If I were you I would definitely do tints first.
thatgarrett901.00 |
04-01-2023, 12:33 PM | #86 |
901
Rep 223
That is super helpful! Yeah on past cars I’ve done 25-30% usually, but things were more lax in TN and SC, and alpine white took a darker tint very well. I was always a little nervous when I moved to NoVA with my old Impreza that had 25% all around but never had any trouble. Having a black interior I don’t want a cave, but I don’t want it hot, so hearing that feedback was the last little bit I needed to convince me to do that! Great tip on the inspection sticker, I wouldn’t have thought about that and could have been bad!
Honestly, I think I saw your car on the tint thread and another that was imperial blue with a 35%, and your car sold me on the lighter tint for the first time! Yours also sold me on a gloss black grill, which I was in the fence about for this color. Anyways thanks for posting so many of your mods, a huge help for people like me debating certain things! |
04-01-2023, 01:06 PM | #87 | |
Rep 4,554
NYC Bimmer259.50 |
04-03-2023, 07:22 PM | #88 |
Rep 4,554
Most recent pic thus far. She's come a long way from life as a base model!
