06-05-2009, 07:44 PM | #67 | |
My ride: bimmergirl84
22
Rep 302
The rest of you -- So sorry for not getting back promptly, I have been extremely busy lately!! I check this thread when I can but usually don't have time for a long reply. I finally have a day off this Sunday so hopefully I will have some time to write up thoughtful relpies then! |
06-08-2009, 12:40 AM | #69 | ||||
22
Rep 302
As you know, during symmetrical up-and-down suspension movement, the bars do nothing (unless they have some load on them from not being installed correctly). I would try getting some adjustable sway bar endlinks, get any swaybar preload out, and then see how things are. Quote:
But, to give you something to try: Since you have a skidpad, try getting the car near/at it's grip limit around the pad so that you are at constant throttle and constant steering. Then, abruptly lift off-throttle, turn in towards the center of the skidpad a little bit (maybe a 45* change on the steering wheel), and then abruptly go to full throttle and pay attention to the feel of the rear end of the car. Quote:
06-08-2009, 12:41 AM | #70 |
22
Rep 302
Sure! If you are willing to lose a little bit of your rear tire tread. This would be very useful for all of us and would easily answer all these questions. I'm in Irvine btw.
06-08-2009, 10:52 AM | #71 | |
16
Rep 355
The car is very easy to induce either trailing throttle over-steer particularly when transitioning from an understeering condition or power on over-steer. We teach that to students. It was easier to hold a high yaw rate on the skid pad, then to hold at 10-15 degrees. unfortunately the skid pad was not level so it requires some work to drive it with the tail out. I was able to hold high yaw rate with out the power cutting, and with the tires spinning. At that point I was concentrating more on balancing throttle (high power setting, second gear) and steering because the skid pad is not level (camber changes). I did try another test which caused the E-LSD to definitely work. Accelerated hard across drying area with low yaw I felt a few pulses from the back when I hit the wet area again, right wheel hit it first, then both wheels on dry, then right wheel on wet, then both on wet. Obviously happened quicker then I can describe it. Half way to the track, I realized I had left my digital IR pyrometer at home and it would have been helpful to take rotor temps. (After coming off the skid pad, the rears are ever so slightly blued -- certainly not like when coming off the track.) Next test will be July, so maybe we can work on something with more granularity.
Alan
08 135I (AW/Coral Red - delivered 3/15/08 -- 13 Audi S4, 83 SC (trackster), 90 C2 (Sally's Carrera), 04 Avalanche Blingmobile |
06-08-2009, 12:41 PM | #72 | |
Philaf_666
14
Rep 163
Before I had the front sway installed, there was a lot of body roll. After the install, the front of the car felt flat and stiff but the rear end felt like it was bouncier than before. Actually, it might only be a feeling due to the front being more flat and stiff, but it really felt like the rear was going from side to side more than before while hard cornering. After installing the rear M3 subframe bushings, rear sway and stiffer springs in the rear, that feeling is gone. Since all was installed at the same time, I'm not sure what cause that feeling to go. So my understanding is that if you play with the front of the car, you also need to adjust the rear accordingly. |
06-08-2009, 02:22 PM | #73 | |
22
Rep 302
What you just described is correct. My bad. |
08-12-2009, 10:38 AM | #75 |
13
Rep 231
First let me thank you for sharing your experience for people like myself who only know enough to get in trouble. I just started a thread to get some opinions for drifting a 135i. My first question is do they have a good LSD available for the 6MT yet? Even if I have to do a little welding I don't mind. Next what suspension mods would you suggest to drift this car? I will have it on the street alot and also to some tracks. but I have a lift so I don't mind making major changes to suspension for a day of themed driving. (plus I love to work on this thing)
08-14-2009, 07:18 PM | #76 | |
22
Rep 302
On the front they run ~1/16" total toe out = 1/32" out each side On the rear they run 3/16" total toe in = 3/32" in each side As much camber as they can get all around, which is about -2.4*F and -2.0*R |
08-14-2009, 07:25 PM | #77 | |
22
Rep 302
2) KW V2 or V3 coilovers + front camber plates + non-staggered wheels/tires. If you want to go overkill, add an aftermarket rear sway bar. The KW's are an excellent compromise between street and track duty. They are a bit stiffer than a typica ///M suspension, but not by a whole lot. And for the love of god, save the drifting for an open track day! Please! Hope that helps everyone. Whats new with your cars? Has anyone tried the mods or setup suggestions we've talked about? Not too much is new with me. I have a fun summer job and am working a lot. Tomorrow I have the privilege of testing the HP Autowerks 335i at CA Speedway; definitely looking forward to that. I also spent a large portion of my semester/summer working on this at CSUN: 440lbs, 100+hp, 6-speed pneumatic paddle-shift with no-lift-shift... and no seat! |
08-14-2009, 11:03 PM | #78 |
Rep 97
cool, I will be there at cal speedway with speedventures, so I will try to say hi. I will be trying out the 135i with the dinan suspension with stock tires, I tracked there bone stock in may with bmwcca and had a ball. Now I have the stage 3 (springs, shocks, sways, camber plates), so hopefully it'll be fun. I am trying to chew up the tires, so I can get the fender flares and then get a square setup and hope the wife doesn't notice.
I will be in the red and green groups so please don't blow the doors off my car too badly when flying by...thx Last edited by vasracer; 08-14-2009 at 11:04 PM.. Reason: typo |
08-14-2009, 11:11 PM | #79 |
Rep 1,239
Jeff, I just read the entire thread and this is very helpful. Ive had my 135 for a year now and I just ordered the KW V2's.
I recently switched from the run flats to so non run flats and the suspension seemed to get much more floaty. That combined with Oktoberfest coming up and me wanting to try some of the driving schools prompted me to go ahead and order the KW's. Here are my questions. 1. I am planning on doing the suspension install myself. Im pretty handy and I have all the tools, but Ive never done something like this before. (other than installing a leveling kit on a truck a couple of years ago) Is it pretty doable in a day? Is it something I should even be considering? 2. I see lots of posts mentioning the camber plates. Is this something I should really do if I am going to be on the track maybe 3-4 times a year? 3. Should I go ahead and do a front swaybar while I have everything apart? Hotckis? Other suggestions? Thanks, Kenny
● 2015 Cayman S (Current), 2011 1M BSM #297 (Sold), 2008 135i (Sold) ● |
08-15-2009, 06:23 PM | #80 | ||
22
Rep 302
That 335i was awesome. Hope you had a good day and get home safely. Quote:
2) I sure think so. Lack of front camber is by far the biggest problem with strut-type suspensions... and to really make the coilovers worthwhile, you need camber! Without them, the car will understeer pretty badly. 3) If you have to choose between the two, I'd recommend camber plates over a sway bar. But, if you have the budget for a sway bar, I thought the H&R solid front bar matched up very well with the kit KW spring rates. (I recommend keeping the rear bar stock unless you enjoy sideways motoring.) |
08-16-2009, 01:43 PM | #81 |
Rep 1,239
Thanks for the help. Any opinions which camber plates I should be considering? Best bang for the buck?
Edit..... I think I have decided on the Vorshlags. I was ready to order but I need to know what spring perch to order. I was guessing the 60mm perch's but wanted to make sure before I order them. I guess I will call tomorrow. Thanks again for all the help.
● 2015 Cayman S (Current), 2011 1M BSM #297 (Sold), 2008 135i (Sold) ● Last edited by tkbr0wn; 08-16-2009 at 10:26 PM.. |
08-16-2009, 11:23 PM | #83 | |
15
Rep 189
Jeff - thanks for the settings. I'll try those next month. As for negative camber front, I have made a few modifications to get -3.2 drivers side and -3.6 passenger side. As you know, since the strut tower hole is so small, you can only slide the Vorshlag plates over so much before the top nut hits the flang. Well I took my dremel tool and lengthened the slide hole where the strut mounts and cut a notch in the shock tower to allow the strut top nut to more more inboard. Combine that with the M3 lower arms and we are now in -3+ degree territory.
08-17-2009, 11:35 AM | #84 | |
Supreme Allied Commander
3897
Rep 54,605
Drives: F80 M3
08-17-2009, 12:26 PM | #86 | |
22
Rep 302
Also, I would guess that 210lbs/in is softer than the stock spring rate. It's definitely too soft for any kind of 'sporty' application. If you *have* to do only springs, I'd go with something that's been pre-tested like an H&R spring kit. At least then you know they won't bottom out / coil bind / be way too soft / be way too stiff. |
08-17-2009, 01:06 PM | #87 |
3897
Rep 54,605
Drives: F80 M3
08-18-2009, 11:20 AM | #88 |
22
Rep 302
Wow. That puts it at about 106lb/in wheel rate = 212lb/in front ride rate... that's soft!
