BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > CODERS E90 E91 E92 E93 in UK
      07-13-2012, 09:53 AM   #67
makkan00
makkan00's Avatar
889
Drives: F83 and F36
Originally Posted by seanblee View Post
I'm just thinking that if I buy a unit from eBay to retrofit, I'd want to get it up to the same software level as the rest of the car. I think I'm starting to understand how to do it myself (using WinKFP and the latest SP-Daten files from ISTA/P), so perhaps I'll try buying one and see how I get on. I just don't like the idea of paying one of the vendors £1k+ when I can buy the parts for £600 and an OPS head for £300 then do it myself...
You may be correct but retrofitting CIC is not that easy.
Try it, but you will require few codes to activate your CIC unless you are going for after market solution.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      07-13-2012, 10:10 AM   #68
seanblee
seanblee's Avatar
51
Drives: 2021 G21 M340i
I'm looking at the hardware activation solution with the CAN filter. I've weighed up the pros and cons and I don't think there's a big disadvantage to the hardware solution - yes, it's not as BMW would do it, but nor is fitting a CIC to a 2007 car, so I don't see the harm. Now I just need to work out how the coding works (where I think it's just a case of changing the build date and adding a couple of options to the vehicle order in CAS and NFRM then recoding CIC, but I'm not certain).
2021 G21 M340i XDrive | ACS springs and spacers
Previously 2019 VW Golf GTI Performance | H&R rear ARB
Previously 2007 E92 335i SE auto | Quaife LSD | Birds B3 ARBs | Evolve Stage 1
      07-14-2012, 07:27 AM   #69
makkan00
makkan00's Avatar
889
Drives: F83 and F36
Let us know how you get on. As this is one of the things on my wish list, though I may hardly ever use it.
      07-15-2012, 07:56 AM   #70
ROW
ROW's Avatar
10
Drives: BMW E92 330i Individual
Any coders in Cheshire area or i can travel a little depending on price i.e north to Manchester, preston or south to staffordshire direction?
      07-17-2012, 09:05 AM   #71
afsar
38
Drives: BMW X5 xDrive40d
Which year car is it? I can do it all for you if you not patient and persistent enough to learn yourself.
650i F12 - HUD, 6WA, SLI, Logic 7, Dynamic and Adaptive Drive, Comfort Access, Soft-close, top-view,
Previous X5 40d M Sports and 535d LCI
      07-17-2012, 09:05 AM   #72
afsar
38
I can code in and around West London area, I can come to east London if worth coming. I can also cover Berkshire region.
All I have at the moment is decent OBD II cable which can code all E6xx and obviously the know how for most of the retrofits. If there is enough interest I can offer CIC upgrade service too, but the equipment is very pricey so I am not spending a grand or so just for my own upgrade. At the moment upgrading CIC is not easy thing to do unless you have know how and the right equipment. Needs ICOM/OPS/OPPS + very stable power supply. If a few people agree to get this done I will buy them and should be ready to do it by mid next month.
PM me if interested.
      07-17-2012, 09:17 AM   #73
gangzoom
Drives: E90 335i M sport
Anyone able to Code my ProNav audio to HiFi? Just did Alpine install and it doesn't sound quite right, it's a 08 car but I think BMW did a full update when injectors were replaced by the last owner.
I'm based in Leicester but can travel abit, obviously will give financial compensation for people's time
      07-17-2012, 09:50 AM   #74
yeti racing
yeti racing's Avatar
Drives: 2008 E90 330d M Sport
Hi,
Bit of a Newbie question, but what does the coding allow etc?
Thanks
Jason
      07-18-2012, 03:48 AM   #75
milka
Drives: 320d M Sport
coders in london
Matt you need to write few posts before you are eligible to use 'magical stuff' AKA PM (personal message).
Once you are able to do that, send me a pm and I will sort out this for you.
Hi Makkan, can't seem to reply to your message, says your inbox is full, do you have a email / number I could catch you on? I am still very interested in getting this warning coded out.
Thanks , Matt
      07-18-2012, 02:26 PM   #76
Meshyo
Drives: E92 335I
Coding-South London and Surrey
Hey guys, I can code South West London and Surrey areas. I have so far done Fogs lights for opening/closing, 'chirps' for lock/unlock or either, and LED retrofit. Other things such as seatbelt warnings, ignition warnings (annoying!) I have been able to do. I have not yet looked into NAV/Hifi or PWM lighting coding, but hopefully in the very near future I will be able to look do this
      07-18-2012, 03:01 PM   #77
magic77
magic77's Avatar
258
Drives: ex- 335i
where abouts are you Meshyo the foglights on / off would be nice thing to have. Got it on wifes Merc usefull when out in the dark
F30 335i M Sport - now departed
      07-19-2012, 06:07 AM   #78
Meshyo
Drives: E92 335I
I'm located in Sutton in Surrey, not far from Kingston either.
Yep really good option to have on, one other one I have (which I am not sure if most have this enabled anyway but mine didn't) was BFD-Brake force display, so when a higher level of braking is applied the rear fogs come on!
Quite decent!
      07-24-2012, 04:05 PM   #79
zltm089
zltm089's Avatar
247
Drives: 335i SE Coupe Space Grey
2006 BMW 335i  [10.00]
can the remote key be coded on the 6 series convertible (640i)? so that the roof and can open/ closed by pressing the remote.
      07-25-2012, 10:17 AM   #80
makkan00
makkan00's Avatar
889
Drives: F83 and F36
It can be done. Check vendor in your region with autologic.
      07-25-2012, 11:05 AM   #81
zltm089
zltm089's Avatar
247
Hi
Its actually for my uncle who lives in surrey...
who is the "vendor" for surrey and how much roughly please?
      07-25-2012, 11:11 AM   #82
makkan00
makkan00's Avatar
889
Drives: F83 and F36
Hi
Vendors
here are these in Surrey
3- Surrey and surroundings =
B- AVC Uk Website (submitted by Hotcoupe)
C- Stourbridge Automotive LTD. Website (submitted by Billyray911)
Cannot comment on these how much would they charge.
And if you are after forum members, then its meshyo. Worth of asking him if he can code 6 series.
HTH.
      07-25-2012, 03:25 PM   #83
Sensible_
529
Drives: 2008 E90
Hi,
Great thread. Just to let you guys know as well as the normal coding bits and bobs I can code BMW Smart keys.
Proof of vehicle ownership and photographic ID Required. PM's welcome, based in north London area.
      07-26-2012, 07:29 AM   #84
deesto
Drives: BMW 120d M SPORT
makkan00,
Can you PM me with your details? I'm in London, need some help with coding.
      07-26-2012, 07:59 AM   #85
makkan00
makkan00's Avatar
889
Drives: F83 and F36
Originally Posted by deesto View Post
makkan00,
Can't do that, as you should have 10+ postings to enable that.
      07-26-2012, 08:29 AM   #86
deesto
Yeah, just figured. Working on that count !
Does this email address show? deesto@me.com
Or somewhere I can contact you outside of the forum so I can send you my query and ask for a price quote?
      07-28-2012, 11:34 AM   #87
Robin330i
Drives: E90 330i M Sport
Any coders in the north west? I want a few things coding, I was going to do it myself but I can't get my eBay special coding software to work.
E90 330i M Sport - Honda S2000
      07-31-2012, 12:25 PM   #88
fj
Drives: 335i
would also be interested in any coders in the yorkshire area
