BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > HID Kit for 328i
ARMA SPEED
      01-13-2013, 03:22 PM   #67
WonderWoman
WonderWoman's Avatar
Drives: BMW 328XI MW F3O
I've got 6000 hid fogs put in. Haven't had any problems since they were installed. Took maybe 20 mins and looks great. Match almost perfectly right away, after a little while to break them in they'll be perfect. If you're thinking about doing it, do it now! :P
      01-24-2013, 10:18 PM   #68
finaloption
finaloption's Avatar
Drives: '13 f30 n26
getting both high and low beams overkill?
      01-25-2013, 12:13 PM   #69
bmwluvr24
Driving Mika all over California.....
bmwluvr24's Avatar
Drives: 2008 E60 M5
Received my fog and low beam kits! Thanks Underground Euros! I will post pics once done.
2008 E60 M5 Sepang Bronze Metallic, gloss black grills and gills, LED side markers, 12mm spacers all around, stud conversion kit, custom exhaust with Magnaflow mufflers and x-pipe.
      01-26-2013, 10:18 PM   #70
T_flare
25
Drives: 2012 328i
let us know you access both lamps? I looking for advice before I install mine
      01-28-2013, 02:19 AM   #71
bmwluvr24
bmwluvr24's Avatar
Drives: 2008 E60 M5
I will take as many pics as I can during the install.
      01-29-2013, 06:53 PM   #72
finaloption
Drives: '13 f30 n26
soooo.. any luck on those pics?
      01-29-2013, 08:16 PM   #73
Casualvic
26
Drives: 328i xdrive
Originally Posted by 2k12f30
Originally Posted by brian99997 View Post
Picture and which color did you pick?
Morimoto Elite Systems 5k FTW anything more you start to lose lumens and the detail on the road etc.
I would recommend nothing short of this company. HID's, this is what they do, day in and day out, nothing else. Me personally, I use companies that specialize on one thing so I know they are focused on what I need. Tons of cool stuff on the website for complete retrofits to kits. My profession has me working with this type of lamp system on a much larger scale (upwards of 15000 watts) so I understand the entire premise behind it. Components are key here if you want to do it right, and for automotive aftermarket I have found nobody that does it as well as these guys. Either way read about Morimoto on google, you'll see the reviews are tops and they come with a 5 year warranty to boot.....
Have fun.....
I ended up ordering these in 6000. hopefully they rock!!! Theres no way I was paying 150 for something with an alien on it! lol
      01-30-2013, 01:19 AM   #74
Robz_328i
Drives: Bmw 328i 2012 Luxury Executive
truth is hid is aftermarket point bottom line. They come from the same place and just sticking different label on them. Its aftermarket and will not be compatible as your own car. Trust me on that i been all around the hid possible. I was driving a volvo before and those hid expensive and less expensive does the same dam job. Point is- if you drive a bmw you don't want it like a honda 1990 with those killing dead headlight.
      01-30-2013, 01:20 AM   #75
Robz_328i
Again if you're planning on buying which is still your choice, it all does the same thing.
      01-30-2013, 05:23 PM   #76
bmwluvr24
bmwluvr24's Avatar
Drives: 2008 E60 M5
Well, I went to get them installed today only to have one of the installers tell me that these are not what he would use and that they are junk. He continued by saying that even if he did install them, he would have to remove the bumper. Ummm.......bullshit. I am just going to do it myself and take pics as I go. I just need to find a good mounting spot for the ballasts.
      01-30-2013, 05:33 PM   #77
MSport28
MSport28's Avatar
Drives: F80 M3 / G30 540
If I could figure out how to post pictures on here I photographed my install as well, step-by-step. The install was a royal pain because you have to access the rear of the headlight housing through the wheel well lining panel. Also, the "clips" that hold the stock bulb in place are annoying. Nonetheless, the mod is very doable and makes a HUGE difference.
      01-30-2013, 06:56 PM   #78
DesertSmokeBBQ
DesertSmokeBBQ's Avatar
Drives: 2014 F30 335i M-Sport
2013 BMW  [0.00]
Originally Posted by ****************
Originally Posted by NiceNotRiceBMW
Anyone know where I can buy a bulb for the DRLs? I want a white to match my 6000k hids I put in. Link/pm??
We are make thing them will be about a month maybe sooner.
Are the DRL bulbs available yet?
'14 Estoril Blue II F30 - 335i - ZMM - ZPP - ZTP - ZPS -
2TP
Traded 9-1-13 '13 Estoril Blue II F30 - 328i - ZMM - ZPP -ZDY - ZTB - 403 - 465 - 494 - 4DX- LC (Black) - 6NL
      01-30-2013, 10:13 PM   #79
Casualvic
26
Drives: 328i xdrive
since there is a round circle that covers the hole to get to the bulbs........will the ballast fit inside there??? because I dont think you can mount them outside of headlight right??
      01-31-2013, 02:51 AM   #80
loz3rxfreak
19
Drives: 2012 328i
http://www.ebay.com/itm/130826331101...84.m1497.l2649
these actually work nicely for the drl bulbs. i have them installed on my car currently.
      01-31-2013, 12:07 PM   #81
UndergroundEuros
Drives: 335I Alphina White
No we weren't happy with the sample we got we want brighter
      01-31-2013, 05:54 PM   #82
bmwluvr24
bmwluvr24's Avatar
Drives: 2008 E60 M5
Ok, so my dealer installed my low beam kit and fog light kit. They look fantastic!! I was there with the technician, so I could see how he was doing this. It was very straight forward, but I would not say easy. He did have to cut a hole in the fog light entry port, but that is no big deal as the wire harnesses have water proof grommets already attached! GOOD call on that one UE! The most annoying thing that he ran into was the clip to attach the bulb. He had to bend it a little to get it back into the housing. It fit perfectly after he did this. He also mounted everything inside of each wheel well behind the arch shroud. It looks VERY clean and there is no way to tell they are aftermarket. Seriously......these HIDs look great! Thank you again to Danny and the gang at Underground Euros for making error free kits with such high quality! I am impressed. I will post pics soon.
      02-01-2013, 12:30 AM   #83
DesertSmokeBBQ
2013 BMW  [0.00]
$300 for DRL bulbs seems a bit steep, no?
2TP
      02-01-2013, 12:34 AM   #84
loz3rxfreak
19
Drives: 2012 328i
Oh wow he must've changed the price. I bought them for 23.99
      02-01-2013, 10:50 PM   #85
bmwluvr24
bmwluvr24's Avatar
Drives: 2008 E60 M5
Here are a few pics with the low beam and fog kits installed. I am will have the high beam kit installed next week.
      02-02-2013, 08:50 PM   #86
Casualvic
26
Drives: 328i xdrive
Im installing low beam hid soon, where am I going to mount the ballast?? And will it be screwed down or zip tied or ???
      02-02-2013, 09:54 PM   #87
bmwluvr24
bmwluvr24's Avatar
Drives: 2008 E60 M5
The tech at the dealership zip tied mine into the frame work in front of each wheel under the fender well shroud. It is a perfect place as long as you 3m double side tape it and then zip tie all of the wiring up inside. It is very clean as well. You will see what I am talking about once you remove the shroud. Oh yeah, you will need to remove the wheel as well to get a really clear view of what you are doing. My car was on the lift at the shop, so things were easy to see.
      02-02-2013, 09:59 PM   #88
Casualvic
26
Drives: 328i xdrive
Im confused because to get into the headlight to the bulb, you have to remove the circle thingy.... Are you talking about the ballast being inside the headlight with the circle thing shut? Or did he leave the circle part removed to let the wires go into the bulb? I tried looking at it and yes...I will definitely have to take tires off...there hardly any room to properly see
