10-19-2012, 12:22 PM | #67 | |
Dejan
1755
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
I guess you can always remove the procede or JB1 and clear codes. Thats the beauty of these systems. Less money and about 30-40 more ponies.
FBO-PS1 and stuff
10-19-2012, 01:12 PM | #68 |
18
Rep 55
I have a confirmed production number from the dealer. Not sure of delivery but I would expect late december/early january.
2021 M5C/Brands Hatch Gray
2019 X7/Black Sapphire 2018 M5/Donington Gray 2015 M3/Azurite Black |
10-19-2012, 01:26 PM | #69 | |
Rep 4,321
On a more serious note, when are the bloody Dinan F30 updates coming?!
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
10-19-2012, 03:49 PM | #70 |
Rep 665
You'll feel it, but barely. 20hp/30tq isn't going to feel like much in a car that weighs this much. And remember, it's 20hp/30tq peak not across the entire power band from idle to the redline. I've spent over a decade modding cars and I can tell you first hand this isn't much. A 335i with the power pack will probably give you .2 seconds/2mph or so in the 1/4 mile as an example. That's only 2 car lengths. It's a very slow pull to get 2 car lengths over a 1/4 mile and not something that's you're going to feel pinning you back to your seat. Most people would struggle to tell which car was faster if they drove both.
10-19-2012, 05:10 PM | #71 | |
Rep 1,044
EDIT: from the graph both the new power as well as torque curves are pretty parallel to previous values, and seem to be as across the rev band as the previous values. |
10-19-2012, 06:24 PM | #72 | |
30
Rep 211
10-19-2012, 08:57 PM | #73 | ||
Rep 665
Also, if the BMW power kit is anything like the Hartge kit that came out, I thought I remembered the Hartge extra power coming at more than 80% throttle or something like that. So is it possible BMW is doing something similar where the car doesn't see the power gains unless its pretty much WOT? |
10-19-2012, 09:39 PM | #74 | |
Rep 4,959
I think my Dinan days are behind me.
Current: '23 G20 M Sport 330i
Current: '20 X253 GLC300 SUV Gone: '20 W205 C43 Sedan Gone: '18 W205 C43 Sedan Gone: '13 W204 C63 Sedan |
10-20-2012, 10:37 AM | #75 | |
Rep 665
That and the time it took to drive/flash/drive back 4 times a year ended up being probably close to 15 hours a year of my time wasted. In hindsight I wish I would have gotten a handheld plug in that I could flash and unflash in my garage at my convenience. That is what I am waiting for this go around. |
10-20-2012, 11:38 AM | #76 | |
Dejan
1755
Rep 4,197
FBO-PS1 and stuff
10-20-2012, 12:25 PM | #77 |
Rep 4,321
I'm purchasing from a Dinan Dealer, so I figured I'd be there getting service anyhow...
How are often does BMW update their ECU? 4 times a year seems like a bit much - is it a consequence of new model introductions, or is this habitual? Thanks, Shivas
10-20-2012, 12:28 PM | #78 |
Rep 3,836
Drives: Jerez E90 M3
How'd you manage that?
11' E90 M3 6MT | Jerez Black | Black Ext./Carbon | ZCP | ZCW | ZPP | ZTP | 302 | 403 | 507 | 5AC | 655 | 6FL | 752 |
15' F80 M3 6MT | Black Saphire | Black Full | ZEC | ZLP | 2VF | 2VZ | 5DL | 688 | |
10-20-2012, 12:33 PM | #79 |
Rep 4,321
I had them match the Dinan 15% special, then negotiated on the service end...remember, new car, so they are incented to add it into my financing...was honestly hoping to get the Dinan exhaust, but since it wasn't available, they tried to "make the sale" with a healthy alternative.
I got the Kidney Grilles for $185 (pair) installed.
10-20-2012, 02:06 PM | #80 | |
Dejan
1755
Rep 4,197
I think Having to reflash the Dinan software 4 times a year is way too annoying and inconvenient. If cobb does not put something out with in the next year Id like to try out the Hartge piggyback.
FBO-PS1 and stuff
10-20-2012, 06:52 PM | #81 |
Rep 7,047
My 09 135i didn't have any burble because it was an MT.
The AT's had it. The updated firmware RUINED my 135i's throttle response though. From new until the update, throttle response was pretty good. After the update, mid range response was gone, flat. In 3rd at around 4K, I would go WFO and there would be a nearly 1 second delay in the engine responding. It sucked big time. Before the update response was much quicker. Also after the update, in mid-high rpm in turns, throttle response was awful. It wasn't turbo lag, but it felt like it. It was simply a delayed response to throttle input at higher rpm. My guess was BMW did it as a band aid, thinking it might slow down HPFP failure by not giving full instant power on demand. Rather, full power sort of "ramped up" with larger throttle application. The update was done before BMW figured out the HPFP problem. But, they never reversed the throttle delay that came with that update. Instead they came out with the PPK, which most people reporting that throttle response improved. I think the PPK software simply gave back what the update took away, and BMW promoted the PPK as a performance enhancer. I called it a "bait and switch". I paid for the performance I had when the car was new. Then BMW neutered the throttle response and then wanted more money to install software that gave back the response, along with a power boost. Really pissed me off. Throttle response in my 335i is excellent in "sport" and "sport+". In "comfort" mode response is too slow requiring a larger pedal application to get the ECU to give more power. With my current "sport mode config", my "chassis" settings are sport, but throttle and trans shift mode are in "comfort". The adaptive suspension gives that option, but I really do want BMW to release software to allow us to select throttle response separately. Ideally we should be able to select the mode for steering, throttle, suspension, and trans operation, and then save that as a default. The ability to do that is already in place, BMW simply has to program the system to give us a screen where each item can be selected. BMW! I'm still waiting! And, I think I'll be waiting 3 years from now when it's time for a new car. It's so freaking easy to do and a very logical way to do it. I still can't fathom this glaring oversight. They promote giving us driver selectable driving modes, but it's still very restrictive as to what we can actually select. Yes, I'll continue to harp about this, because it's so freaking illogical in how BMW implemented driving "modes". |
10-20-2012, 07:04 PM | #82 | |
Rep 7,047
What I do know is that my 135i received a software update that decreased my over all performance, compared to how it ran before the update. That's real. Then, the PPK came out for the 135i, and one of it's benefits was better throttle response. Thus, I can see why some think BMW did this on purpose in order to sell the upgrade. The "burble" thing is cool, but I don't find it to be a "performance" issue. We'll know more if a software update happens and some performance is actually lost, while a bit later we find the PPK returning some of what is taken away. I hope it ain't true. I don't want it to be true. |
10-20-2012, 07:09 PM | #83 | |
Rep 7,047
Sure not poster knows even he's about talking nonsense more. |
10-20-2012, 07:19 PM | #84 | |
Rep 7,047
The HP isn't a big increase, but with AT the torque increase should be felt in the midrange. Also, it's not just a matter of a "peak" HP or lb ft. increase, it's more about the actual curve and what the PPK will do to that. It's possible the PPK will fatten up the curve and make it "flatter/more consistent" across the rev range. It may not show up as a major shove in the seat o the pants, but it'll show itself in faster times and higher trap speeds. I don't know, but I'm expressing wishful thinking here. |
10-20-2012, 07:41 PM | #85 | |
Dejan
1755
Rep 4,197
FBO-PS1 and stuff
10-22-2012, 01:33 PM | #86 | |
Rep 7,047
The N55 wasn't a solution to the HPFP problem, as some people promoted that conspiracy theory. BMW finally released a pump that works and isn't failing. They released an "internal" recall, meaning it was BMW/self initiated. Customers could come in and have their HPFP's replaced even if they had no problems. That was the case with my 09 135i. My HPFP was fine, but I figured may as well get it replaced now that they have the issue sorted. No problems with the new pump either. So basically, ever since that recall and that pump, any x35i engine that received the new replacement pump has not failed. Cars that had 2, 3, or more replacements finally had a functioning HPFP after the recall. I'm sure there are still some x35i turbo engines out there that didn't go in for the recall, or waited until their original pump failed, and then bring them in, and thus we're still reading and hearing about them. But for the vast majority the newest pump fixed the problem, and the failure and re-failure rate has dropped significantly. As I said, I think any failures we are hearing about now are more likely those who didn't do the recall, and I'm sure there are a few pumps here and there failing, but NOTHING like what was happening before. The 10yr/120K warranty on the HPFP is still good too. |
10-22-2012, 03:27 PM | #87 | |
Dejan
1755
Rep 4,197
The e9x is still such a great car. And I hope they come out with some tunes for out f30's soon, I need about another 50-60 hp on tap to be satisfied.
FBO-PS1 and stuff
10-24-2012, 03:50 PM | #88 |
30
Rep 105
So I talked to my dealer again about ordering the Z3B package and he said that it's not going to be available until 1st quarter. I told him that other's have production numbers but he told me that they may have production numbers but they won't be built until the package becomes available. He didn't think it would be available until 1st Qtr next year. You may want to confirm with your dealer on timelines.
