The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - Florida > / / / OFFICIAL FixxFest #9 - Bradenton Drag Strip, Florida - Nov. 17th-18th, 2012 \ \
      11-16-2012, 06:47 AM   #67
JStang
JStang's Avatar
563
Drives: FDB M3 CS
Originally Posted by spool twice View Post
sorry to hear!
ii'm still debating if I should go, I have a "plausible fuel pump" code that showed up 2 days ago w/ a timing dip @ 4,500rpm in all of my current logs. It's been colder than normaly and I have been running E85, so I'm thinking it's just a fluke. Car fires up, no signs of a weak fuel pump, log shows a healthy pump so IDK if I should run or not.
Cobb tune? I have had the 2AAF codes for a while but just sent some logs to PTF and he recommended that I change my LPFP before getting tuned for E50. I am trying to run this tank to E today and throw a half tank of race gas in for FixxFest.
Do you get your E85 from Bollinger's?
      11-16-2012, 05:08 PM   #68
spool twice
Rainbow Racer
spool twice's Avatar
Drives: BMW M4cs
2019 M4cs  [0.00]
JB4 G5, yes 2AAF too. I get my E85 from Bollingers and also in Ft. Meyers. I've been running on the Bollingers for the past 3 tanks. For some reason, my car doesn't seem to perform as well w/ Bollingers E85 vs. the one I get in Ft. Meyers. I've tested it in the test tube before, both have hovered around E80-E86 (the higher content favoring the Ft. Meyers one). I wonder what the remaining 15% is mixed with?
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ]
Current Car: F82 M4cs | TT-RS | On Order: i4 M50
      11-16-2012, 06:23 PM   #69
werke-t
Drives: 2020 X3M Competition
Cya guys tomorrow,
Jstang lip looks slick
      11-16-2012, 07:22 PM   #70
JMARS
Not Baned
Drives: e92 M3
At Hooters where is everybody???
      11-16-2012, 08:22 PM   #71
AK 335i
AK 335i's Avatar
48
Drives: black 335i E90
alaska
- Proven Power Tampa Built 6466 ST N54 6AT WR 711whp 637wtq -
      11-17-2012, 10:19 AM   #72
tphaeng
tphaeng's Avatar
82
Drives: derrrty
Anyone looking to meet up before? I'm probably going there around 1:30/2ish.
      11-17-2012, 03:35 PM   #73
AK 335i
AK 335i's Avatar
48
anybody run yet?
      11-17-2012, 06:53 PM   #74
tphaeng
tphaeng's Avatar
82
Drives: derrrty
There were some 335 and 135's out there that ran some good times. I'll let them post their results tho.
      11-17-2012, 06:53 PM   #75
M3_Dylan
Drives: 2008 BMW M3
Did you guys see that e90 with a sti hood scoop..... Epic fail!
KW V3's / AA Stage 2 Supercharger / Catless Mid-pipes / AA Mufflers / Apex Arc-8's / PFC 09's
      11-17-2012, 06:54 PM   #76
tphaeng
tphaeng's Avatar
82
Drives: derrrty
Yeah. lmao! I had to do a double take on that one cause I wasn't sure of what I saw. Lol
      11-17-2012, 07:21 PM   #77
spool twice
Rainbow Racer
Drives: BMW M4cs
2019 M4cs  [0.00]
my run was crappy, I couldn't get traction I was getting 2.4-2.5 60ft's all day
r/t .076
60' 2.359
1/8 9.074 @ 90.30 mph
1/4mile 13.487 @ 111.94 mph
tune, DCI, methanol, E85/93 octane, 6MT. My car wouldn't boost past 16.5psi for some reason(?) even though I have my additive set to 7 (19.5psi), kept getting a plausible fuel pump code, and kept missing 2nd gear. Only ran 4 times because it was an epic fail and quit.
Then I over-purged my meth on 7/5 on one run, missfired right off the line because of that, and managed to miss 2nd as well. I ran 21.xx @ 40.xx mph on that run
Fun even nonetheless, Jstang ran a great time!
-Loe P.-
      11-17-2012, 08:48 PM   #78
JMARS
Not Baned
Drives: e92 M3
Hahahahaha
He was a couple of cars down from me lol
I won 1st Place for the BMW 2006-up Wohoo!!
HUGE thanks to GeorgiaTech335coupe for all the help troubleshooting some bugs on the single kit!
      11-17-2012, 08:57 PM   #79
tphaeng
tphaeng's Avatar
82
Drives: derrrty
I saw ur car Jmars. That thing was SICK. Did u run ur car today?
      11-18-2012, 07:10 AM   #80
spool twice
Rainbow Racer
Drives: BMW M4cs
2019 M4cs  [0.00]
Hahahahaha
sweet car! when I first looked into your engine bay, I was like WTF where are your cone filters? then I saw the exhaust manifolds and finally got it
Also E90company, thanks for the advise on running with on push of the DTC button (DTC light in dash), it helped with my 60ft times that day.
-Loe P.-
      11-18-2012, 04:37 PM   #81
JMARS
Not Baned
Drives: e92 M3
Thanks man!
      11-18-2012, 07:16 PM   #82
JStang
JStang's Avatar
563
Drives: FDB M3 CS
Good meeting some of you guys at FIXXFEST this year. I was able to take a spin in JMARS single setup after he got it up and moving. His car pulled as hard as any 335i I've ever been in and he was only hitting around 20 PSI. Once these guys get the kinks worked out they are going to be legit!
I ran my car for the first time ever on the strip. I ran 5 times with my best time being my first. The slip looked like this:
R/T: .635
60': 2.242
330: 5.657
1/8: 8.398
MPH: 91.62
1000: 10.745
1/4: 12.708
MPH: 114.51
My highest trap of the day was my last run at 115.06. I was very pleased with the consistency of the Cobb tune. 1/4 mile times ranged from 12.708 to 12.904 and traps ranged from 113.62 to 115.06.
Mods are DCI, ETS 5" FMIC, AR DP's, and Dinan axle back exhaust. Tune was Cobb race gas map running VPR MS109 on stock turbos and full weight on street tires.
I was supposed to get protuned by PTF this past week but they looked at my logs and said my LPFP needed replaced. After my first run, I got a 2A2D code which I found to be a low pressure fuel code. I will be replacing the LPFP and getting protuned by PTF over the next couple of weeks and hitting the strip again.
In all honesty, I expected to be in the low 12's but I obviously need to launch better to have a shot at that. I'm assuming the LPFP issue isn't helping times either.
      11-19-2012, 06:53 AM   #83
aj555
aj555's Avatar
Drives: 2012 BMW xDrive35i
That kid should be banned from owning BMWs for that.
2012 BMW X5 xDrive35i E70 Sport Activity
(Wife's Daily Driver) 2000 BMW 328ci E46 - less than 90k miles
(Gone) 2007 BMW 335i E90
      11-19-2012, 07:53 AM   #84
JStang
JStang's Avatar
563
Drives: FDB M3 CS
HAHA I had to do a double take when i first pulled in. At first I thought it was a Subie with a BMW logo. To be honest, I don't know which would have been worse.
      11-19-2012, 10:42 AM   #85
AK 335i
AK 335i's Avatar
48
did either of the single turbos run? Jmars? georgiatechcoupe?
      11-19-2012, 11:02 AM   #86
JStang
JStang's Avatar
563
Drives: FDB M3 CS
Georgiatech335 ran but he was having issues launching not to mention he was only hitting like 16 PSI's. He talked to Shiv during the event and Shiv seems to think that his secondary map sensor was wired incorrectly.
JMARS was only hitting like 12 PSI's on his way up from Boca and GeorgiaTech335 troubleshooted and found out that his Procede was VIN locked. Once it got unlocked, it was around 5:30 and the track was closed. He took me for a ride and it pulled like crazy!
      11-19-2012, 11:16 AM   #87
AK 335i
AK 335i's Avatar
48
right on, thanks for the info hope they get it sorted out.
      11-19-2012, 06:13 PM   #88
GeorgiaTech335coupe
Drives: Black BMW 335i coupe
I ran but my car had some bugs (no meth, MAP sensor connector was messed up so a wire fell out). Also the map sensor being messed up was making my timing really bad.
I also had problems launching. Car is way too hard to launch without 2step, too much lag. And everytime I used the 2step my car would start rolling past the beams. Also, I didn't realize the NLS was turned on all the time so my shifts were very crappy.
I was running 13 and 14s 1/4 miles with 3.0s 60'. I never had a clean run that would be close to indicate what it was capable of.
I'l prob be able to run this Friday. Only have 1 bug left to troubleshoot and I think I know the problem, just waiting on Vishnu for the solution (which should be very easy and only a software or very minor wiring change).
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
