07-30-2014, 02:28 PM | #68 |
3593
Rep 6,819
We have not been able to bring in a F10 M5 for a test fitment with our 19" EC-7's yet to confirm if they'd be able to clear the M5's brakes. Once we are able to test these wheels on an M5, we'll be sure to post the information that we learn in the F10 M5 section.
08-15-2014, 06:55 PM | #69 |
3593
Rep 6,819
Anthracite EC-7's are a great look on Blue M3's. Here is an example from one of our dealers:
Feel free to give us a call with any questions regarding fitment or availability. |
09-08-2014, 04:35 PM | #70 |
Rep 3,742
That does look excellent! Any shots of anthracite on Space Gray? Trying to decide between silver and anthracite on a Space Gray E92. Thanks!
09-09-2014, 10:43 PM | #71 | |
3593
Rep 6,819
Timujin352.50 |
09-11-2014, 01:42 PM | #73 |
3593
Rep 6,819
You can absolutely use the 18x9.5" ET22 and 18x11" ET25 EC-7's with 255/35/18 and 295/30/18 sized tires on your e9x M3. However, that would cause quite a bit of understeer due to the large difference in staggered tire sizes. We would recommend the front tire size to be 275/35/18 to better match and stay similar to the OEM tire size stagger. The 18x9.5" ET22 EC-7 surely does clear the StopTech ST-60 380mm BBK without any issues, one of the very few 18" wheels that are able to.
09-13-2014, 06:47 AM | #74 |
Rep 119
then how about 265/35/18 18x9.5 on the Front and 295/30/18 18x11 on the rear?
I don't wanna put 275/30/18 on the front cuz I did that before and it rub |
09-15-2014, 01:07 PM | #75 |
3593
Rep 6,819
You can surely use the 265/35/18 on the 18x9.5" ET22 on the front, you would just experience a little more understeer due to the extra difference in staggered tire sizes with the 265/295 staggered combination. This would not be an issue if you mainly street drive the car though.
01-03-2015, 01:47 PM | #78 |
Rep 427
Drives: 2013 BMW M5
Any group buys coming up??
01-09-2015, 04:50 PM | #79 |
1445
Rep 2,662
Keep your eyes peeled in the coming months for any information on group buys.
01-22-2015, 01:50 PM | #80 |
1445
Rep 2,662
Good things come in all finishes and sizes. Get your EC-7's today!
Our staff is available to answer any fitment questions that you might have.
03-12-2015, 01:18 PM | #81 |
Rep 487
Hi David,
http://www.flickr.com/photos/58871469@N04/15519730990 http://www.flickr.com/photos/apexrac...n/photostream/ http://www.flickr.com/photos/apexrac...n/photostream/ Above: I like this look. Few questions: 1) What's the size and offset of these wheels in the pictures? 2) What tires are they and what size? 3) I currently have stock calipers but plan on a StopTech 6 piston setup in the future. What size wheels do I need to get? 4) For #3, will it fit w/o rubbing? I have stock ZCP suspension now, but plan to lower it a little bit later (not sure what setup yet).
2004 M3 E46 LSB 6MT
2008 M3 E92 6MT 2024 M4 Competition xDrive |
03-12-2015, 04:13 PM | #82 |
Rep 487
I found they're "BMW E92 M3 in Space Gray with our 18x10" ET25 EC-7 wheels in Satin Black finish"
Would be great to know the tires on here and if it's a square setup + above questions thanks
2004 M3 E46 LSB 6MT
03-12-2015, 06:31 PM | #83 |
Rep 487
For the stud conversion kit, which one do you recommend for the E92 with the 18x10 ET25's all around?
2004 M3 E46 LSB 6MT
03-13-2015, 11:00 AM | #84 | |
3593
Rep 6,819
These are the 18x10" ET25 EC-7's in the Satin Black finish. This customer is user Arif[ on this forum, and he had mentioned he used Michelin Sport Cup tires, though did not specify in what size. We would think that they are 275/35/18 as that is the most standard tire size for this car. The StopTech ST-60 380mm BBK would be compatible with our EC-7's in 18x10" ET25, along with the ARC-8's in the same size. The 18x10" ET25 squared setup with 275/35/18 s a direct bolt on set up with street tires, and some R-compounds such as the Nitto NT01 would work without the need of aftermarket suspension or camber plates if you plan to move on to those in the future. The square setup will be beneficial for track use due to its more neutralized feel. It will also allow you to rotate your tires to maximize their life span. Some owners don't feel the understeer of the E9x M3 and prefer to stick to the staggered setup to maintain the feel of the stock car and avoid any unwanted oversteer caused by a square setup. Since you should not need to use any spacers at all, the 75mm stud length would be the recommended size for the stud conversion kit.
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by Expert@ApexWheels; 03-13-2015 at 11:07 AM.. |
04-09-2015, 11:46 AM | #88 |
1445
Rep 2,662
You can expect a PM from our staff shortly. Thank you for your patience.
