12-07-2017, 04:12 PM | #67 |
Rep 1,499
So I received my Turner Motorsport front strut brace today. Does anyone know what I should torque the strut bolts to? Also, those of you who have the TMS brace, did you adjust the length of the bar or leave it as received? I"m also assuming I should tighten the brace hardware (bolt with nylon lock nut). It comes very loose.
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI). SPI Films Blog/DIY Vids |
12-07-2017, 05:30 PM | #68 |
Rep 1,499
Nevermind...I found it on newTIC.info. Strut tower bolts torque spec is 56 N-m (41.3 ft-lbs)
kevinjt151.50 |
12-07-2017, 05:38 PM | #69 | |
Rep 3,549
JaredG_F301106.00 |
12-07-2017, 06:51 PM | #70 |
Rep 1,499
Cool! Thanks!!
12-18-2017, 02:41 PM | #71 |
23
Rep 68
Upper adn Lower front Ultraracing strut tower brace fr f30
Hi
I've an F30 320i i've installed upper front Strut tower (Ultraracing)UR-TW2-3744 and I bought the lower front one UR-LA2-2543,, but the problem was that I have to remove the Underride protection (part number 31146850067) Does any one has a way around this?? Maybe one had cut through the underride protection ?!! Ah btw,,, the front upper strut tower brace really does a good job in holding up the front of the car,, I wish I can install the lower one without having to remove the shield, Thx |
03-25-2018, 02:58 PM | #72 | |
Rep 1,597
03-25-2018, 03:12 PM | #73 | |
95
Rep 228
03-25-2018, 03:25 PM | #74 | ||
Rep 5,460
Drives: F30
03-25-2018, 07:14 PM | #76 |
Rep 5,460
Drives: F30
03-25-2018, 07:34 PM | #77 | |
95
Rep 228
03-27-2018, 09:10 PM | #78 |
Rep 1,597
04-25-2018, 10:31 AM | #79 |
23
Rep 68
I'm Egyptian ,, we have a store that buys them from abroad and sells them here , sorry mate but I don't know where u can get them , but I can tell u one thing ,, they're the most reliable/cheap braces you can get
04-25-2018, 10:33 AM | #80 |
23
Rep 68
04-25-2018, 10:40 AM | #81 | |
23
Rep 68
But we were tired to try where exactly it won't fit ,, A friend of mine told me I should AutoCAD it and see where exactly it could be pinched , if any,,, I thought of contacting ultraracing They shouldve put this into consideration I've searched alot on the internet for a solution ,, found that some f30 thier underide shield is made of like fabric material ,, like the one that surrounds the wheels ,, so it could be pinched easily But here in Egypt roads have allot of bumps and holes ,, so a metal under shield is a must |
04-25-2018, 05:12 PM | #82 |
23
Rep 68
Rear Lower F30 Ultraracing member BraceCode: UR-RL2-2545
here is a pic of the underbelly after installing the rear lower brace (Code: UR-RL2-2545),,, sorry the quality is so bad
taken by Oneplus5t, my old iPhone6s was much better If you can see the front lower shield ,, and the new rear lower brace |
04-25-2018, 05:23 PM | #84 |
23
Rep 68
front lower member brace ultraracing Code: UR-LA2-2543 cannot install
here is the picture of the front lower one,,, see there is no under shield here
BMW F-30 330 (2016) FRONT MEMBER BRACE / FRONT LOWER BAR Front Member Brace / Front Lower Bar Code: UR-LA2-2543 |
04-26-2018, 10:13 AM | #86 |
Rep 1,597
The rear lower brace does not look like it will do very much. It looks to be trying to prevent scissoring of the end of the rear axle carrier but there is already a solid strut nearby already doing that. The front brace and the strut bar look solid. How does it feel with all the bracing?
04-28-2018, 08:17 AM | #87 | |
23
Rep 68
The back one also did a good in corners ,, even ones beloow 60km |
04-28-2018, 08:22 AM | #88 | |
23
Rep 68
