03-01-2015, 03:33 PM | #67 | |
Rep 1,035
Sorry to hear about your issues. I'm almost positive that one or more of your spacers are not sitting perfectly flat/clean on the hub face, which means that the spacer didn't have enough recessed area in it to clear the hub lib. In fact, reading back through your posts, i noticed you got 10mm BMS spacers for your front from Burger. These are the EXACT same ones Jason from Burger told me that have only 12.08mm clearance. And if your F30 is like mine, the front lip is 13mm long, which means the lip is bigger than what the spacer can clear, which means the spacer won't sit flush against the hub face. So unless your installer grinded down at least 1mm from the lip, you are asking for sure fire vibration problems. The best way to be sure is to jack up your car and see for yourself. If you can't do that practically, then ask the installer if they 1) measured for clearance and 2) if they shaved the lip if they found it wouldn't clear. If they say no to either question, or don't know what you are talking about, then you know This was my exact issue that i posted about earlier... Good luck whatever you decide. |
03-01-2015, 03:41 PM | #68 | |
Rep 1,436
03-01-2015, 03:42 PM | #69 | |
Rep 1,436
03-01-2015, 04:01 PM | #70 | |
e92 - 335i
179
Rep 743
Yes |
03-01-2015, 04:26 PM | #72 |
61
Rep 205
I've been driving 220km/h with 12+15mm spacer. I never noticed any vibration.
320i Activeflex - JB4 - Afe Airfilter - VRSF IC - ER DP - ER CP - @Ethanol
03-01-2015, 05:16 PM | #73 | ||
Rep 417
03-02-2015, 06:03 AM | #74 |
Rep 1,436
ok so I've tightened the bolts to 103 ft/lbs & it wasn't that far off the 88 in fact some bolts didn't go beyond the 88 previously made. so I'm doubting the torque wrench i have is messed up ?! but over all the car is much better in driving
03-02-2015, 07:36 PM | #75 |
Rep 3,089
Good to know. Curious how is the car driving better?
03-02-2015, 10:59 PM | #76 |
Rep 1,436
03-30-2015, 10:33 AM | #77 |
Rep 692
Quick question. Why exactly is 15mm required for x-drive? I am about to purchase a 2014 328i xDrive M-Sport for my wife and want to order the spacers. Looks like 12mm up front and 15mm out back is the way to go. I have a 2008 M3, so the F30 is new to me...
Thanks,
Dave [SIGPIC][/SIGPIC] |
