09-26-2014, 08:39 PM | #67 |
Rep 586
Here's the 17x9.5 35et 275/40 squared mounted on F30
No mods or tricks other than 3mm spacers and camber plates on front!
G05 - M Performance roof spoiler
09-26-2014, 09:30 PM | #69 | |
Rep 586
09-26-2014, 09:43 PM | #71 |
Diligentia Vis Celeritas
559
Rep 1,476
Drives: 335i
That's a bad ass setup...
Ahead of the curve for specF30
10-22-2014, 07:27 PM | #74 |
559
Rep 1,476
Drives: 335i
I had some problems with mine. They were rattling and clunking at low to mid speeds (especially as the car would unweight coming over a bump), and making weird binding noises when steering at low speed. I took them off after my track weekend. Although now I REALLY miss the camber!
So you guys aren't having issues with noises with yours?
10-22-2014, 08:07 PM | #75 | |
Rep 586
New parts that I have installed from GC was the speed bumps, new washers and bushings. Talk to Jay@groundcontrol.
10-22-2014, 08:10 PM | #76 | |
Rep 586
10-22-2014, 08:41 PM | #77 |
Rep 1,084
Yeah, I've already contacted GC. I was curious if anyone else has had success here.
I have the same binding and rattling/clunking at low to mid speeds as DVC. Donovan at GC has asked me to verify strut nut torque and to take pictures. Since I only received the bits yesterday (direct from GC) I assumed that I'd received the latest parts, and so didn't check for blue bushings. A shop (familiar with GC camber plates for other cars) did the installation for me. Last edited by rwalker; 10-23-2014 at 09:56 AM.. |
10-24-2014, 01:00 PM | #78 |
Rep 586
I do get rattling sounds time to time but got a lot better than what it was. Blue bushings fixed the majority of noise and some other discrepancies.
10-25-2014, 09:53 PM | #79 |
Rep 1,084
Update: my spring perches are not rotating smoothly. They're binding a bit. The spring winds up and then pops bit by bit when turning lock to lock.
I found another issue of which those considering these plates should be aware: the stock strut tower braces won't fully clear the shank nut without a little work. Pushing the strut brace rearward and installing a couple of washers between the plate and the brace to elevate the end slightly should clear it up (looks to me like Forgiven may have done this). Here's a pic of mine installed: Note how far back I've pushed the brace to clear the nut. I'm not using washers. Those using stock springs will likely not be able to use the full range anyway (owing to spring<=>tower interference). |
10-26-2014, 12:00 AM | #80 | |
Rep 586
10-26-2014, 09:49 AM | #82 |
559
Rep 1,476
Drives: 335i
Really appreciate the pics and detailed descriptions of addressing the issues, guys - hopefully this will work for me as well.
10-27-2014, 11:34 PM | #83 |
Rep 586
Not that i am aware of..but I did get the set without the blue bushing at first.
10-27-2014, 11:43 PM | #84 |
Rep 1,084
I spoke with GC today and they're really doing their best to make this come out right.
Current theory is that I've had an installation issue. GC is covering all the bases with replacement parts in case the issue is on their end. I should know more in a few days. On the side of good news: my car veritably rips into corners. Front end grip is great at -2.5deg camber. Last edited by rwalker; 10-28-2014 at 10:20 AM.. |
10-28-2014, 12:02 AM | #85 | |
Rep 586
10-28-2014, 12:05 AM | #86 | |
Rep 586
Still in learning curve with new this new mod but I am loving it! I need some roll bars later..lol
10-28-2014, 09:39 PM | #87 |
Rep 1,084
Sweet, congrats. I hope I can get my M235i in shape for the Penultimate Autocross 11/15. If not, it's back to the M Roadster (now a somewhat consistent 2nd in class).
10-29-2014, 12:04 AM | #88 |
Rep 586
Sweet! Are you going to the BMW CCA SD? Isn't that on 9th? Seen a stock 228i at the event and thing was flying! Can't imagine what m235 would do..
