06-24-2015, 06:20 AM | #8823 | |
General
10539
Rep 41,178
06-24-2015, 09:52 AM | #8825 |
General
10539
Rep 41,178
PM sent.
06-24-2015, 12:39 PM | #8826 | |
9
Rep 53
Thx man. |
06-24-2015, 12:40 PM | #8827 | ||
9
Rep 53
06-24-2015, 04:36 PM | #8828 |
28
Rep 109
re-coding 2013 F30 after service.
Hello, I had my 2013 F30 328i (US) coded (with e-sys 3.22.5 & psdzdata 2.49.4) about two years ago. Now it will have its first service in July (yes, I didn't drive it much). I was told they will re-program the car. Does any one know what is fixed or added by this new sw? If it is not necessary I will choose not to re-program it. If it can not be avoided, what will I need for re-coding? Is it going to be more difficult than before? Thanks!
06-24-2015, 04:38 PM | #8829 | |
General
10539
Rep 41,178
Same as always, in that you need E-Sys and PSdZData light, but now you also need E-Sys Launcher 2.x. PM me when the time comes.
06-24-2015, 05:49 PM | #8830 |
Rep 6
I have a doubt, I need to change and encode the fem module, I have to do the procedure with the new module already installed or have to make a "backup" of old before starting, with the new module the ignition does not work, what i need to do? Thanks Shawn for your support.
06-24-2015, 09:52 PM | #8831 | |
General
10539
Rep 41,178
06-24-2015, 10:24 PM | #8832 |
Rep 578
is FEM_01 the same as FEM_Body?
I was recently using NCD-CAFD tool to view the affected modules when doing a retrofit. It listed FEM_01... I don't have just a FEM module.. i have FEM_Body & FEM_GW... so which one of those is FEM_01???
06-25-2015, 04:45 AM | #8833 | |
General
10539
Rep 41,178
FEM_GW has no CAFD, thus it is not codeable.
06-25-2015, 11:05 PM | #8834 |
Rep 1
Download
Hi, I want to start coding my 2014 F30 and I thought the cable I purchased came with the software and token but it didn't. Does anyone have a link where I can download it. I've noticed some really good cheat sheets, but any advice on the "easiet" things to try first would be appreciated. Thanks!!
06-26-2015, 05:54 AM | #8835 |
General
10539
Rep 41,178
PM sent.
06-26-2015, 08:09 PM | #8836 |
Rep 578
I should have posted that was my thinking.. hence why i was code default FEM_Body b/c it had a CAFD of the 2...thanks
Sorry if this isn't the correct forum/post... but looking for the Rheingold software to help tshoot why my comfort access (and rear PDC) is no longer working after trying the OEM backup camera retrofit. Even if i remove 3AG & 508, code default affected ECU's.. (veryify PDC is removed)... Add 508 back & code default affected ECU's... PDC is no longer working (Error No Parking assistance is available, something..something..something... service is required). My rear PDC retrofit was working just fine until i tried to add the camera. Really pissed that my comfort access is no longer working... hate having to grab the key out of my pocket... |
06-26-2015, 08:32 PM | #8837 |
95
Rep 214
Drives: 2019 X3 m40i
Enableing BMW Live/Bluetoogh tether - 13 f30 CIC
So I just successfully recoded a lot of lost functions from my most recent dealer visit. Thank you Shawn for the updated software!
Since I am no longer a paid subscriber to the BMW Online services I decided to try the activation of Bluetooth (data) tethering to enable BMW Live/Internet browser. It didn't work. I followed all the steps in the F30_Coding_Reference_Guide_v1.6. Any suggestions? Additional data: F353200 322 COMFORT ACCESS SYSTEM 6AA BMW TELESERVICES 6AB CONTROL TELESERVICES 6NF EXT.CON.OF THE MUSIC PLAY.I.MOBILPH 6NL CONNECT. BLUETOOTH A.USB DEVICES IN 6NR APPS 6UH TRAFFIC INFORMATION 6VA CIC CONTROL 6WA INSTRUMENT CLUSTER W. EXTENDED CONT 609 NAVIGATION SYSTEM PROFESSIONAL 610 HEAD UP DISPLAY 615 EXTENDED BMW ONLINE INFORMATION |
06-27-2015, 07:01 AM | #8838 |
Rep 8
I am trying to code NBT retrofitted to E93
I need VO that I can use for coding. I am traying to create it manually but failing when calculating FP Can somebody help and provide fa.xml for from F33 or help to create it containing options I have Thanks in advance If that matters, CAFD_00000DED_003_004_010 Last edited by vamis; 06-27-2015 at 07:19 AM.. |
06-28-2015, 08:47 AM | #8839 |
70
Rep 316
Drives: X1, i3 BEV
Looking to start coding my 2015 F36. Can someone send me links to the correct e-sys and psdzdata? TIA
06-28-2015, 08:56 AM | #8840 |
General
10539
Rep 41,178
PM sent.
06-28-2015, 01:50 PM | #8842 |
General
10539
Rep 41,178
PM sent.
06-28-2015, 03:40 PM | #8844 |
General
10539
Rep 41,178
PM sent.
