10-09-2022, 03:56 PM | #10891 | |
Rep 23
10-10-2022, 03:51 AM | #10892 |
Rep 1
Update software version
Good morning everyone, a query my carplay is Andream and the version appears
SDK Version: 25.0.0.5.6.0.0 Cust Version: v2.0.0.B0.mod MCU Version: 19.8.22.15 HW version. BMW my question is can the software be updated? which version? I have contacted the seller of Aliexpress which is AIOCOAI Official Store and they do not pay any attention to me. Thanks in advance. |
10-10-2022, 01:50 PM | #10894 |
Rep 15
10-10-2022, 02:57 PM | #10895 |
Rep 36
Hi mate model number is EWM-BMCP-NBT04X Cheers Edit is there a firmware version to make AA fullscreen on waze and Google maps?
Edit: SDK Version: 25.0.0.7.0.0.2.0 CUST Version: B2_V1.6.2_1_n MCU Version:21.6.7.116 HW Version: BMW_NBT2_1_G Can anyone link me to the latest firmware for this mmi box? Cheers Or custom firmware for full screen maps? Last edited by Migz71; 10-11-2022 at 10:39 AM.. |
10-11-2022, 02:14 PM | #10896 |
37
Rep 175
After updating to iOS 16, my iPhone will not establish CarPlay with the unit no matter what I do. I've tested with two iPhones (13 Mini and 13 Pro) that previously worked with this unit, and neither wants to work with CarPlay (Bluetooth pairs, but the CarPlay prompt never appears on the phone, and the device never shows up under CarPlay on the unit).
Anyone else experience this? |
10-11-2022, 02:53 PM | #10897 | |
Rep 1,607
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
10-11-2022, 04:39 PM | #10898 | |
Rep 15
This is software for Andream B2-Version Model: AN-BMCP-NBT04X: EW_B2_V1.6.8_a_n https://mega.nz/folder/COxmGYAZ#j7RuZxZ21KAg9hmpVzhlUA |
10-11-2022, 05:27 PM | #10899 | |
Rep 818
no issues with iOS16 upgrade. |
10-12-2022, 07:36 AM | #10900 | |
Rep 36
10-12-2022, 01:03 PM | #10901 | |
Rep 15
Hope it helps!! |
Migz716.00 |
10-12-2022, 08:25 PM | #10902 |
Rep 4
Is the "HK hack" mentioned in this thread just mean using the OEM bluetooth for phone/music while using the carplay/aa UI? Spent quite a while searching this thread and didn't find a clear answer
If so, is there a trick to getting this to work more permanently? For me it seems to work for some time then ultimately I have to re-pair everything or switch back to AUX. |
10-12-2022, 09:06 PM | #10903 |
Rep 532
Drives: 2019 440i XDrive GC
Just installed what was advertised as a RoadTop MMI box for my 2019 F36 so I could get Android Auto.
Everything is working great when it is connected via USB and I've gotten it to continue working when USB is then disconnected, but it will not connect to my phone wirelessly for AA without being wired first. It connects fine to the bluetooth, but doesn't seem to want to connect to the MMI wifi for wireless AA. Any thoughts? I'd really like to not use the wire. Here is the info I have: SDK Version: 25.0.0.7.0.0.2.0 CUST Version: ER169R1 MCU Version: 22.5.14.118 HW Version: B_E_G
Current: 2019 440i xDrive Gran Coupe - Alpine White, Coral Red Dakota Leather, 8AT, MSport, THP, BM3; 2015 X5 35i xDrive - Mineral White Metallic, Mocha Dakota Leather; Previous: 2015 Subaru WRX - World Rally Blue, Premium, FBO+Tune
10-13-2022, 02:02 AM | #10904 | |
127
Rep 339
10-13-2022, 10:04 AM | #10905 |
Rep 4
Thanks. If you are using AUX, what is accomplished by setting the OEM BT to music/phone rather than just phone? Music through the OEM BT sounds better to my ears which I assumed was due to a low quality DAC in the MMI.
My main issue is the "Use OEM bluetooth for calls" setting in the MMI seems to stop working intermittently. I lose call/siri audio without being on AUX unless I start a call and switch audio output from "CarPlay" to "BMW ####" in the phone itself. Last edited by yer-eye-uh; 10-13-2022 at 10:09 AM.. |
10-13-2022, 11:07 AM | #10906 |
Rep 11
Your Audio Source has to be set to "Aux". For Siri & Calls the trick is following:
1. Siri works, if you trigger it via the iDrive Controller (just press & hold while MMI CarPlay is open). With the "HK Hack" Siri via steering does not work for me. 2. Obviously the iPhone is switching call-audio to the device you are using for the call. Therefore DO NOT initiate/answer calls via CarPlay MMI. You have to do this via the BMW System. |
10-13-2022, 11:54 AM | #10907 | |
Rep 4
I always use the steering wheel controls to answer/initiate calls/siri. OEM behavior generally works (long press=siri, short press=BMW voice). But that's a good idea, thanks. It's possible that I answered via the UI (steering wheel dial instead of phone button) without realizing and it switched the phone over to carplay instead of BT. I would consider that a bug in the MMI though I may be missing something because I'm still not clear on what the "hack" is since "use OEM BT for calls" is a feature of the MMI |
10-13-2022, 06:13 PM | #10908 | |
127
Rep 339
As a tip, increase the bitrate transfer from your phone to the highest level. From within whatever music app you are using, go to settings and change it. This also really makes a difference in sound. |
10-14-2022, 11:22 AM | #10909 |
Rep 2
RoadTop B-Version Update I got from the Roadtop store
CHLR169 (PIN: 8032) (Not cross compatible) https://drive.google.com/file/d/153N...73883e5fIaPS32 1 : Use 8GB usb disk ,format it into FAT32 2: Unzip the file and Copy ISPOOOT.BIN and GEMINI_PACK.BIN into u disk, and then update the system. |
10-16-2022, 12:20 PM | #10910 |
Rep 2
Hi.
I wondered what version of software I could update my MMI to please? The details are - SDK Version 25.0.0.5.6.0.0.0 CUST Version v2.1.0.6.lc.b MCU Version 20.6.2.0 HW Version BMW_NBT Up to now I only use wired Apple Carplay in my i3. Thanks in advance. Steve. |
10-16-2022, 07:08 PM | #10911 | |
53
Rep 65
Here's the latest version that I got from the seller: https://f30.bimmerpost.com/forums/sh...ostcount=10608 |
Steelcityuk1.50 fe7565557.50 |
10-17-2022, 06:44 AM | #10912 |
14
Rep 35
Hey everyone,
I've got an Andream NBT EVO B-version Box on my F32 running android auto with the E_1.6.9R2 firmware. Been having a weird situation lately, which was prior to installing my current firmware. From time to time the phone stops automatically pairing with the box. I found out that the reason for this was because the wifi and bluetooth of the box changed the name and I had to pair everything again. You can seem from the screenshot bellow that it has, in 3 days, assumed 3 different bluetooth names, all of which start with EW-CP8. Since this happened only from time to time, I paid little attention to it. But this has been becoming ever more frequent and I don't know why. Does anyone know why this keeps happening ? |
andream, android, android auto, apple, carplay, mmi, retrofit |
