10-18-2019, 02:13 AM | #89 |
Great Teacher
1139
Rep 1,320
Drives: 06 e91 325ix
And installed, thanks OP for the diy. Hardest part was the reconnecting the connector for the hazards and disconnecting the connector for the radio faceplate initially. What a bear.
I do actually prefer the preLCI screen font, but I’m sure I’ll get used to it. |
11-14-2019, 09:56 AM | #90 | |
Rep 18
Hello. I have NBT Professional in my car. F30 2013 december with IHKA. Pins (10 & 11) on FEM A173 * 10B I have already taken. Do I need to connect together wires from pins 22 and 23) on FEM A173 * 7B to pins (10 & 11) on FEM A173 * 10B ?? Then in one of the pins will be 2 wires ?? I think right Best regards Jarek |
11-14-2019, 12:02 PM | #91 | ||
Rep 10,473
You can splice the wires or use a Scotch Brand T Wire Tap Connector which is what I would suggest so the KCAN2 wire is not cut. |
11-14-2019, 01:31 PM | #92 |
Rep 18
I have to take the cable, connect the 10.11 A173 * 10B KCAN2 quick connector pins. Connect the other end of the cable to IHKA3 to pin 22.23.
Cable from old IHKA (pin 22.23) I have to disconnect from conector and connect my new cable Am I right?? IHKA -> KCAN_H Pin 22 to Pin 34 FEM A173*7B IHKA -> KCAN_L Pin 23 to Pin 33 FEM A173*7B IHKA3 -> KCAN2_H Pin 22 to Pin 10 FEM A173*10B IHKA3 -> KCAN2_L Pin 23 to Pin 11 FEM A173*10B Best regards Jarek Last edited by Siwysdz; 11-15-2019 at 01:28 PM.. |
myszano118.50 |
11-15-2019, 04:13 PM | #93 |
E36fiend
286
Rep 637
Drives: 2014 435i xDrive
I would not use those vampire taps, I would (and did) cut and solder the wires together. And yes, on the FEM connector pins 10 and 11 there are already wires there, I cut those and spliced in the wires from the IHKA3.
11-16-2019, 12:45 PM | #95 |
E36fiend
286
Rep 637
Nothing bad will break if you install the parts and don't code it but the panel may not work. I don't recall what happened in between installing and coding for me as I coded it right away.
11-19-2019, 07:05 AM | #96 |
Rep 2
Hello Guys,
I am a happy owner of a 2016 f36 and would like to know what parts would i need to have a dual zone digital climate control working. Thanks a lot. |
11-19-2019, 11:31 AM | #97 |
Rep 10,473
11-23-2019, 12:09 PM | #98 |
Rep 18
Hello. Today I was to encode IHKA3, but esys can't see it. Everything connected. New panel attached. The blower is working, the rear window heating indicator light is blinking, the airflow directions are on LHD, I have RHD, the seat heating reverse works, the air conditioning does not turn on, the color change white and amber works.
What do you recommend ?? I changed ihka 64119311850 to ihka3 64116820235-01 and climate panel on 64119363546-02 Bmw F30 335d december 2013 RHD Last edited by Siwysdz; 11-23-2019 at 01:44 PM.. |
11-23-2019, 03:59 PM | #99 | |
Rep 10,473
4) change car build date (Zeitkriterium) up to at least a 2015 Model Year (07/14) in VO. 5) update car to latest istep level 6) Performed a "TAL-Calculating" and then a "TAL-Processing" to update the IHKA3 BTLD, SWFL and CAFD files. 7) Run Rheingold to clear all warnings and errors before starting your vehicle. 8) Start vehicle and run it until the A/C LED stops blinking. |
11-23-2019, 04:13 PM | #100 | |
E36fiend
286
Rep 637
01-07-2020, 07:27 AM | #103 | ||
Rep 3
Can I try use LCI panel (64119363546) or is not possible? |
01-22-2020, 10:09 AM | #105 |
Great Teacher
1139
Rep 1,320
02-05-2020, 09:21 AM | #107 |
Rep 9
Same here, nothing on this? I believe I'm the 3rd or 4th person asking this from reading the thread. Can any of you gentlemen from Bimmercode chime in on this? I tried this with pn: 9363545-02 as my 328 didn't come with heated seats since I'm in Miami, could it just be the part number I'm using? I kinda didn't want pointless buttons for my non existent heated seats, tbh it would just really bother me if they didn't light up which is why I opted for no heated seats button. I have a build date of 11/2014 so it should work but it's still just white, no amber
02-05-2020, 10:29 PM | #108 |
Great Teacher
1139
Rep 1,320
Turn the lighting down and it will change to amber... until you can code it with bmwai or eSYS?
02-05-2020, 10:31 PM | #109 |
Great Teacher
1139
Rep 1,320
02-10-2020, 01:58 PM | #110 | |
Rep 12
How to code sport (white) lightning with BimmerCode? |
