DIY: Changing The Manual Trans Fluid In The 335
06-17-2014, 11:10 PM | #89 | |
Rep 610
06-21-2014, 05:44 PM | #90 | |
Rep 818
For both ZF and Getrag. I have one installed. |
06-21-2014, 05:45 PM | #91 | |
Rep 610
02-21-2015, 11:29 PM | #92 | |
Rep 1
02-22-2015, 09:12 PM | #93 |
Dustin335i
50
Rep 80
Drives: Mineral Grey M235i M/T
I've really never had a great fluid for working well in the super cold parts of winter; but I think the MTL isn't bad... and is a little smoother than the OEM fill in those cold mornings. Once up to operating temperature, the MTL is the smoothest and longest lasting of the 4 fluids I've tried. I plan to use it again, for sure.
04-25-2015, 03:07 AM | #94 | |
Rep 23
How many quarts are needed though ? Don't we have change the transmission oil filter also? Thanks in advance ! |
04-26-2015, 11:15 PM | #95 |
Dustin335i
50
Rep 80
Hey, I can't remember how many quarts are needed, but it shouldn't be hard to find.
Fortunately; there's no filter needed for the manual transmission.
10-08-2015, 06:19 PM | #96 |
14
Rep 128
This is a potential dumb question, but here it goes,
What exactly is "clutch bleeding" and do we not need it here?
________E90 335i 6MT mHD, VRSF DP, VRSF 7" FMIC, SSK, TWM knob, BAddictions DLB, CSF Rad, Rattling Turbos
10-09-2015, 05:21 PM | #97 | |
Rep 63
It is not needed here because this removes and replaces the gear oil from the transmission, not the hydraulic fluid from the clutch (they are separate systems). |
10-10-2015, 02:11 PM | #98 | |
Car Enthusiast
916
Rep 1,311
Drives: E92 328i 2007 SC
E92 328i|6MT|ESS SC VT-1 (G.2)|3 stage|22 RPD SC/Meth tune|AA Headers|Snow Performance Meth Injection|Rotiform KPS|R139|PS4S 275.245.19|M3 front|M3 side skirts|MTEC rear|Akrapovic C tips|Koni Sport (Yellow)|Eibach PS|Hotchkis SB|C high-kick spoiler|C mirror Covers|C trim|LCI tails|M3 Control arms|M3 MS|Black E trim|Black kidney's|Full LED Conv|BMW F30 370/345 BBK|ECS SS|ECS Strut Tower Brace|034 Engine-Trans-Rear Mounts
10-16-2015, 07:19 PM | #99 |
14
Rep 128
Is this possible without jacking up the back? I have a pair of rhinos and It'd be great if thats enough... I dont really want to get a hydrualic jack which would cost me more than 50 bucks
05-13-2018, 11:45 AM | #101 |
430
Rep 170
Changed the brake/clutch fluid last weekend; Replaced front/rear diff, and MT fluid this weekend. (Transfer case will be next weekend, if I can pick up the fluid this week). The car is new to me, but has 150k kms, and doesn't appear that any of the fluids have ever been changed.
Since I was doing both the front diff and the MT fluid, both the metal stiffener plate, and the plastic splash shield are removed. You only really need to remove the plastic splash shield - On my 2011 E91 xDrive it is 5x8mm and 1x10mm bolt. Loosen the fill plug - 8mm Socket. The drain plug is in the center of the picture. Remember to remove it by hand once loose. I didn't and had to screw it most of the way back in, in order to get the socket out. The bolt is quite long. Once the fill plug is out, get the oil drain pan under the transmission and pull the drain plug. I had metal shavings on the drain plug. Not sure if it is from the transmission itself, or if its from the threading on the drain plug. Put the drain plug back in and fill the transmission. I pumped just under 1.7L back into the transmission. (I say just under, as there was 300mL left in the second bottle, but I'm not certain how much overflow drained out) There is less resistance, it feels less "notchy" when shifting - Guess that'll happen when you replace old fluid with 150k kms on it... |
12-02-2023, 02:32 PM | #104 |
130
Rep 248
So this is an old threat but this information i have not come across and i add it here:
For cold climates -5 and less. I did manual transmission oil change and put inside: Febi Bisten equivalent transmission oil for OEM code: 83222339221 (because it's available everywhere in my area). Which was: FEBI BILSTEIN 40580 In short when transmission is still cold shifts were worse than the original old oil - not smooth at all. I then purchased 2L of original BMW 83222339221 oil and put into transmission and in cold temperature it is very smooth. |
Seattlesquash915.50 |
02-20-2024, 12:03 AM | #105 |
Electronics Engineer
43
Rep 136
Nice!
Loved this tip. I didn't need a second pair of hands. I just sealed a hose into the cap of the bottle, turned the bottle upside down, poked a tiny hole in the bottom of the bottle with a pick tool (no risk of plastic bits getting into the oil), then slowly pressurized the bottle with a compressed air gun. Done! No mess, no fuss, and super fast!
03-26-2024, 12:41 AM | #106 | |
43
Rep 136
The Febi oil is not synthetic and smells like engine oil, whereas the BMW MTF-LT-3 is fully synthetic and smells a bit like brake fluid. |
