05-24-2015, 04:12 PM | #89 |
DSC Off!
307
Rep 718
I somehow snapped off the head of my fill bolt. I had the torque wrench set at 26 ft/lb. Hopefully, I didn't do any damage, and I can just use a new one.
MCS 1WNR with 600/900 spring rates / Vorshlag camber plates / Apex ARC-8s with MSI studs / Stoptech Trophy ST-60/ST-40 / Cantrell Motorsports Brake Duct Kit / Cobalt Friction XR1, XR2s or PFC-11 pads / UUC Corsa axle-back with Fabspeed HFC and x-pipe / Schroth Quick Fit Pros / HANS Sport II / AA green filter / Coolshirt with large bag / Aim SoloDL with SmartyCam / CSF Radiator
07-04-2015, 05:40 AM | #90 |
274
Rep 2,665
Drives: Goggomobil
I am new to Rheingold. I couldn't find the above when I connected to the car. Is there a user manual to navigate around Rheingold? Would appreciate any help.
F86 X6///
07-04-2015, 11:14 AM | #91 | |
Rep 936
Are you connected properly and be able to diagnose, pull codes, clear codes, etc.? If yes, then you are almost there. I will connect mine and take a few screen shots and post them here shortly. |
07-04-2015, 04:19 PM | #92 |
274
Rep 2,665
Drives: Goggomobil
[QUOTE=jimk;18199053]I've self taught myself on how to use it. It will take you a while to learn it and find the proper tools. I've spend several hours navigating through the console to become familiar with it and if I don't use it for a few months, I forget where things are and I spend a bit more time finding what I want.
Yes, managed to sort it out. Mine is under vehicle management/service function/Engine/Manual gearbox/activate transmission oil pump ...
F86 X6///
08-14-2015, 08:41 AM | #93 |
Mvua
17
Rep 75
Gear Oil
Was wondering what gear oil you guys recommend. Would Royal Purples 75W-90 be fine or should I stick with the 75W-80 from BMW?
Or any other Fluids you guys recommend.....
08' E93 M3 6M/T | 12' F30 N20 6M/T SPORT | 08' E92 N52 6/MT (SOLD).
08-16-2015, 05:39 PM | #94 |
274
Rep 2,665
Drives: Goggomobil
I went with Liqui Moly. Feel is slightly better than the OEM oil. Could be placebo.
F86 X6///
08-19-2015, 10:02 PM | #95 |
Retired Curmudgeon
3000
Rep 4,075
I've had good luck with Amsoil transmission fluid in the E46M3. Glad the liqui moly worked for you. It's a high quality product.
'19 X3 M40 Carbon Black/Oyster, '21 X7 40i AW/Black, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
08-20-2015, 12:59 PM | #96 |
Rep 10,682
Also Redline MTL is a 75W80 that should be compatible.
mobilenemo22.00 |
08-20-2015, 03:19 PM | #97 |
Haters gonna hate
15
Rep 84
I put Redline MTL in the trans of all of my manual cars, even the E36 Lemons/Chump car that has done 15-20 endurance races on a gearbox that came out of a 150k mile car and still feels great. I also use the Redline 75-90 in the diffs. Redline is great stuff!!!
08-28-2015, 08:39 AM | #98 | |
Mvua
17
Rep 75
I ended up going with the BMW fluid, $88 for 2.5 liters, used ~2.2L, lost 0.4L when checking the level after changing and driving. So I guess I'll buy more again.....however it began overflowing after I put the 0.3L that I had remaining so maybe I'm fine. If you want to ask how that happened.......my hand slipped when unscrewing the fill plug and couldn't get it back on, plus hot trans fluid doesn't help. Failing in life
01-28-2016, 12:58 AM | #100 |
16
Rep 77
Is this the one you guys are using? https://www.ecstuning.com/ES1503/
I am confused now as someone used Redline ATF. Im about to do several maintenance work on mine. |
02-22-2016, 12:11 AM | #101 |
16
Rep 77
Hey guys, I plan to do this DIY in a few days. I bought a tune up kit from ECS. When I checked their Transmission fluid in the kit contents, they only have 2 1 Quart Redline Fluid included. Based from the OP post, we need 2.5L. Can someone enlighten me on this? Do I have to order another bottle? Thanks!
Tune up Kit: https://www.ecstuning.com/BMW-E92-M3...All/ES2723119/ |
02-22-2016, 11:03 AM | #102 |
Stop the hate, get a V8
3853
Rep 8,625
It's 3.2 pints, from what I see online. That is less than 2 L.
2.5L might be the total capacity (i.e. when the trans is brand new, since you'll never fully drain it).
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
02-22-2016, 04:16 PM | #103 |
16
Rep 77
Thanks! Yes I dont plan to start the cooler to drain more oil, that's out of my skills anyway. Will probably be draining around 2L only. So I guess ECStuning figured 2L will be enough for the procedure, although it might not overfill, but still close enough to the desired capacity. They just want people to save money from buying the Redline 3rd bottle unnecessarily I guess and that's always good.
03-04-2016, 09:14 PM | #104 |
Rep 556
This is a great thread and I have used it 2x. Thanks for all the hard work you guys put in.
What is the purpose of the shield that covers the transmission other than making it smooth and possible protection? I also did the engine oil change along with it...9.5L drained out! I added 8L and it told me add a quart... really looking at the bimmerworld dipstick kit. |
03-05-2016, 01:18 AM | #105 | |
3853
Rep 8,625
LOL, $230 and you have to weld the oil pan? No thanks.
03-05-2016, 05:13 AM | #106 |
Rep 556
I have been changing the oil every 5-7K, and every 3rd DE event- the sensor is very difficult to work with and time consuming. If it were less than 4 oil changes a year then I would not care.
03-05-2016, 10:24 PM | #107 |
53
Rep 151
i half did this today on a e92 m3 2008. i didn't order a new crush washer for the strainer so i will have to go grab one from the dealer on Monday. I could put it back together and let it leak a bit but i don't wanna take it off jack stands and put it back on...eh i got another vehicle. plus i gotta flush power steering and do the rear diff fluid and change a damn thermostat.
The trans oil pump can be activated with BMW GT1 V57 with the pss autosoft software which is actually very affordable. I got it boot camped on my macbook pro with a fresh install of windows 8.1. Although, you will have to buy a usb to obd2 cable too. I got that from one stop electronics website. I spent about two hours today wandering around GT1 before I found the correct activation function. To those who are activating the pump with a 12V battery, I noticed there the notes in the program that said to be very careful only to run the pump for 30 seconds when draining. I spent about $200 for the pss autosoft, the cable and a copy of win 8.1 all together. Not bad to have the legit diag software. Also those that said the TIS doesn't mention activating pump for draining are incorrect. The TIS on GT1 V57 mentions run it for 30 seconds to complete draining and then a minute after filling then top off. |
08-05-2016, 03:25 PM | #108 |
Rep 1,407
Drives: 06' E46 M3 ZCP
Is is necessary to replace the drain and fill plug? Can the old ones be used if theres no signs of damage?
19’ F90 M5C | Signature VS-104 | M-Performance | IND | H&R
06’ E46 M3 ZCP | Karbonius | Ohlins | Vorshlag | Turner | Kassel | IND | Status Gruppe | Macht Schnell 03' E39 M5 | 100% Stock |
08-05-2016, 03:39 PM | #109 |
Rep 399
Should be fine to reuse. They have rubber gaskets, not metal crush washers.
-David
08-06-2016, 03:37 PM | #110 | |
3853
Rep 8,625
The plugs can be reused as long as the threads aren't damaged.
