You might want to click this
05-12-2011, 11:38 AM | #89 | |
Mad Linux Guru On The Loose
1130
Rep 5,404
Drives: 2008 335i Sedan, 2023 M3
We should probably do this some weekend. I have no idea where to look for corn fields unless I am in Iowa, LOL
05-12-2011, 11:38 AM | #90 |
Rep 3,730
I thought LM's care was for sale?
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
05-12-2011, 03:15 PM | #91 |
That guy
117
Rep 5,740
Drives: 2015 Cayman GTS
Why limit power? If you want power that's capable to break the tire loss you need to turn dtc off. Give me max power, I will take responsiblity for controlling it.
05-13-2011, 10:44 AM | #92 |
Rep 5,876
Anyone else try datalogging with the traction control off? I'm starting to realize that this throttle blade action that's seen, given it doesn't impact the load curve, meaning it doesn't impact acceleration, has no merit for being a concern at all...its just the ECU doing its thing to provide a perfect load curve...if there were boost spikes or AFR lean runs or major timing dropouts then I'd be worried...at the moment, with the logs I have on relatively low boost, these curves look perfect especially part throttle/post shift
keep in mind on this car 16psi was 440-450whp on pump gas, so 14psi tapering down to 12psi should probably be around 400whp peak with RBs and pump gas (94 octane) |
05-17-2011, 04:52 AM | #93 |
Rep 395
Idk what the hell is wrong with my car, when i completely take off traction, press and hold, i feel a loss in power in 3rd!!!!!!!!!?????? i rip through 1st and second, but third it dies, though i used to chirp the tires with DTC pressed once slight wheelspin, but on all OFF and third gear (AT) i even hold the wheel firmly because i would anticipate the wheel spin but nothing happens and it feels slow.
05-17-2011, 09:11 AM | #94 | |
Team Zissou
3084
Rep 10,198
06-01-2011, 07:55 AM | #96 |
#Hashtag
10
Rep 245
I believe that you need to contact Rob Beck directly. I'm not sure what his username is on this board but on another bimmer forum he goes by Rob @ RBTurbo or something along those lines.
06-01-2011, 09:57 AM | #98 |
Rep 4,771
06-01-2011, 10:00 AM | #99 |
Rep 3,730
He's also extremely busy building the next set of turbos and probably isn't answering PM's. Just FYI for anyone interested in contacting him.
