Ess supercharger
05-17-2014, 10:51 AM | #89 |
Rep 22
I have a '11 328 e93 with 25k: Forgive my ignorance, but is this the first time a n52 has be SC?
Of course the power is intoxicating.....what are downsides? I know that's a "dumb" question, but specifically will a SC kill reliability of this pretty durable NA engine? Other than that, I love the idea--more power to ya. |
05-17-2014, 10:57 AM | #90 | |
Rep 10,120
As a former N52 owner I'd be a bit wary about using forced induction on a engine that has a aluminum block. |
05-17-2014, 12:51 PM | #91 |
Rep 3,015
The N52 is not even aluminum. It is magnesium mixed with aluminum. I suspect it is weaker than a truly aluminum block however I do hope it is strong enough to be boosted.
05-17-2014, 01:26 PM | #92 | |
Rep 552
My e92 is less than a year old. I currently drive in the manual mode only (always preferred stick shift) and anyone with auto tranny getting a SC I advise practice using the manual mode to get very comfy with it. In manual mode the gear is locked and the tranny will not be overloaded with boost unless you choose to do so. On the plus side, I remember reading threads about the gm trannies being more capable than the base manual. It's a calculated risk and I am very tempted to get one. Price is reasonable but by no means cheap. |
05-17-2014, 07:08 PM | #96 |
Mike: Everyone's Pal
2046
Rep 2,972
Drives: F80 M3
to everyone questions mileage. Ive been reading extensively about ess on the e46 forums regarding the automatic 330i
granted an e46 isn't what we have, but its good to compare. now, I also am quoting a great post on SCs "a supercharger only engages at WOT (wide open throttle, like "passing gear" in a normal car) and therefore for daily driving the supercharger is not engaged and accordingly there is no additional engine wear....and depending on how the engine has been prepared there may be virtually no difference in mileage from a non-supercharged car. there is no question forced induction (supercharger or turbocharger) when engaged adds extreme heat and creates engine stress, so certainly overuse of a supercharger will shorten life span....and if the engine is not properly prepared or if the boost is too strong for the engine's internals could result in engine failure. but if the engine is properly prepared, properly maintained and good heat management practices are in place (intercooler regardless of the boost and running high octane - octane is not a performance enhancer....its fights heat by preventing pre-ignition. in a normal engine pre ignition causes knocking, but in a performance engine pre ignition can cause a burnt piston or scored valve.). so in terms of engine functions & stress at normal pace no difference on a supercharged engine - non supercharged engine......." Therefore, if we act in good faith and don't abuse the the extra power, we'll be OK.
[CENTER]
2021 6.2L Trail Boss, 6" BDS lift, Chevy Performance intake, 35" Nitto Grapplers, 20" Fuel wheels |
05-17-2014, 09:04 PM | #97 | |
Yiannis Gazis
97
Rep 734
Drives: 2007 328xi
2nd Bimmer - 2013 335is | Alpine White | DCT | Loaded
1st Bimmer - 2007 328xi | SGM | e90 | Premium | Navi | Gloss black trim | Cold | AA headers | 3 stage intake manifold | AA stage 3 tune | AFE stage 2 intake | Cyba Scoops | OEM Blacklines | OEM LCI mtech front bumper | OEM LCI hood | OEM gloss black kidney grills | Orion v4 LED halos with blackout headlights | Valentine 1 Radar | Sport wheel with paddles | kw v1 coilovers | VMR 710 | Continental ExtremeContact DW | |
05-17-2014, 11:23 PM | #98 | |
483
Rep 2,283
05-18-2014, 02:17 AM | #99 |
Rep 611
Just got bak from bimmerfest this afternoon, all i can say is this is even better then pic on instantgram, very clean and almost stock looking. Best part for n51 owner is ESS acutally had it installed on an n51 128i. So it aint just based off n52's map.
Also met roman at the booth, he explained everything pretty much, even gave his personal comparason between this vs n54. Basically n54 not as smooth as superchared n51 or 52. This kit still need some fine tune according to roman, but im sure it will be done very soon. |
05-18-2014, 11:45 AM | #100 | |
2040
Rep 2,682
The more integration and testing in real world the better it will be for customers and developer |
05-18-2014, 02:43 PM | #101 |
Rep 4,732
Drives: Alpine White '13 550i
Well...I guess my plan for Work wheels will have to just be put aside.
05-18-2014, 04:34 PM | #102 |
255
Rep 2,547
How will the boost come on? Will it only be at WOT or will it come on in a progressive manner?
05-18-2014, 04:54 PM | #103 | |
Rep 611
N51- PI - PE - ESS Tuned - SSK - CDV Delete - AFE Header - B12 - Mfactory LSD
05-18-2014, 05:17 PM | #105 | |
FSAE Dude
62
Rep 759
Idk where you quoted that from, but that is not how superchargers work. In the picture it was a dynamic air pump (centrifugal supercharger). It is attached to the accessory belt of the car and makes boost proportional to RPM. So it does make more boost at higher rpm, but it is always making boost. As far as durability, I cannot say which aspect of our engines is the weakest. I know we have a cast crank so that might be a good suspect. However, I think we should be safe. Assuming we make about 300-350hp, that would be a 50% increase roughly. So in theory we would want an OEM factor of safety of about 1.9 to run this SC for a while. Racecars are commonly engineered with a factor of safety of 1.4 for established parts. Since this was the first time BMW used a mag-aluminum engine and it is a road car, i would assume the factor of safety would be around 2.5 or so. That puts us well within the range of safe power numbers for the existing engine and internals. I dont actually work at BMW so I cant say for sure what the N51/52/53 were built to handle, but I think we'll be fine. The only thing i would worry about is my x-drive center diff if i would go with this. ive heard that those arent the most durable
2007 TiAg 328xi: AA Tune, AFE intake, Full exhaust, 335xi Brakes, H&R RSB, UUC FSB, H&R Sports, Billy Sports...BBS SR 17x8
1985 Gazelle Beige 325e: Poly everything, e24 3.25 LSD, 225 lb weight reduction, Corbeau FX1, Shifter machined by me, roll bar, harness, all the other goodies. My "Racecar"...15x7 BBS RA |
05-18-2014, 05:19 PM | #106 |
FSAE Dude
62
Rep 759
yes. a centrifugal supercharger is in the picture. For low boost, a positive displacement supercharger (twin screw) doesnt really make all that much sense
05-18-2014, 06:21 PM | #107 |
Rep 10,120
05-18-2014, 06:32 PM | #108 |
Rep 9,004
ESS' current system for the M54 is a twinscrew - it offers more torque and power at a lower RPM than a centrifugal system does. I won't be doing either, but it's nice either way.
05-18-2014, 10:25 PM | #109 | |
17
Rep 319
05-18-2014, 10:41 PM | #110 | |
Rep 3,015
