Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > N52 Rough Idle / Performance Issues
      08-16-2016, 11:26 PM   #89
Stream
T667YM86
Stream's Avatar
Russian Federation
67
Drives: E90 325i 05'
Maybe old pressure differential sensor can cause the problem?
https://www.ecstuning.com/b-genuine-...r/13628617097/
It has ~5 revisions.
      08-17-2016, 05:09 AM   #90
alx.
alx.'s Avatar
41
Drives: F30 320iA M Sport
2006 e90 325i  [0.00]
Interesting, could this cause a CEL?
I've plugged in the OLD MAF, seems to run better with it....could be placebo or maybe it was the fact that the car wasn't warmed up but the rough idle is still there.
Bmw e46 320d '04 - Sold
Bmw e46 330ci '01 - Sold
Bmw 3-er e90 325i '06 - Sold
Bmw 3-er e92 325xi '08 - Sold
      08-17-2016, 05:18 AM   #91
alx.
alx.'s Avatar
41
I have e-mailed the dealer who sold me the MAF for a replacement unit and will keep you all updated.
      08-17-2016, 06:12 PM   #92
Three_thirty_I
Three_thirty_I's Avatar
South Africa
200
Drives: '05 E90 330i Manual
I've often wondered about the MAP sensor (pressure differential sensor as above). But not done anything further. Not sure if there is a way to clean it, if it can even be cleaned. And I don't really have any idle issues as such. The only things that I have noticed is that when it is hot outside, the idle speed is closer to 900 rpm instead of the normal 650 rpm when it's cooler or cold outdoors. Not too long ago I had one weird experience where I had started the car from cold, and while reversing out of my garage I got a text message that I had to reply to, and while sitting with my foot on the brake but in neutral and off the throttle, the idle speed jumped to around 2500 rpm (or so) and then dropped back to normal again. This was for literally a second or so. Weird.
BMW E90 330i (M) '05 (His) | (Hers) BMW E46 320i f/l (M) '03
      08-18-2016, 04:05 AM   #93
alx.
alx.'s Avatar
41
Same thing happened to me but not to 2500 but 1200 ish. I see it's relatively cheap at around $50-60 in romania. I've sent the MAF back for a warranty claim and they will send me a new unit, too bad it's going to take a couple of weeks.
      08-18-2016, 04:13 AM   #94
Stream
T667YM86
Stream's Avatar
Russian Federation
67
My engine did the same thing when i disconnected maf-sensor.
      08-18-2016, 04:16 AM   #95
Phil325i
Phil325i's Avatar
624
Drives: E92 325i MSport Coupe
Yes you can clean the MAP sensor (I used electrical contact cleaner) but they're not that expensive to replace. Yes, I get the rev 'jump' on cold start. I think it's part of the transition routine in the DMF software from stone cold to warming cycle. I sometimes feel a slight 'jerk' from the engine 200 or so metres down the road from a cold start (when I haven't taken a text!). Same thing.
      08-18-2016, 08:18 AM   #96
alx.
alx.'s Avatar
41
Heh, starting to think these engines are designed like this.
      08-18-2016, 09:20 AM   #97
stewey
71
Drives: 2006 325i 6MT
Installed the new MAF last night. Sadly the idle is still rough. I'll give it a few days to adapt and think about what to do next :/
      08-18-2016, 09:29 AM   #98
alx.
alx.'s Avatar
41
Damn and i was excited to get my replacement MAF. Checked for codes? If you have INPA delete the codes that should show up and run it.
      08-18-2016, 08:24 PM   #99
Three_thirty_I
South Africa
200
Well, I should maybe price a new part for interest sake, and then just also try spraying some electrical contact cleaner into the current one to see what happens afterwards. And apart from that strange cold idle jump when it happened, there were no noticeable driving issues once I got going, so it could be that it is somehow part of the warming up cycle. Still a weird thing though.
Maybe disconnect the battery for 30 minutes or so and then see how it goes - adaptations will have to relearn with the new sensor.
      08-19-2016, 08:18 AM   #100
alx.
alx.'s Avatar
41
Driven with the old MAF for three days now and no codes this car is really trolling me hard...
      08-19-2016, 11:20 AM   #101
Three_thirty_I
South Africa
200
I know that feeling! Nothing nicer than intermittent issues! I mean nothing worse of course.
      08-19-2016, 11:22 AM   #102
SSJTrunks523
Drives: '07 328xic '11.0 M3 DCT
Love to get this pinned down. I'd rather not have to retire my winter DD :'(
2011.0 E92 M3 M-DCT ZCP ZTP ZPP Black Wrapped Jerez Black + 2007 E92 328xic 6MT
2007 YZF-R6 + 2001 Honda Shadow ACE
1989 RS Camaro - HO 350, Dynomax headers, flowmaster AT exhaust, 4.56 gears
2015 STI Launch Edition
      08-19-2016, 02:33 PM   #103
alx.
alx.'s Avatar
41
Could it be an internal issue with the vanos/valvetronic? I'm even thinking a blown valve or two.
      08-20-2016, 09:14 AM   #104
stewey
71
Yes, I need to clear codes and see if anything new pops. Actually, the car has been running pretty good the last couple of days. Fuel economy is awful. I'm going to give it more time, but maybe it's good enough??
      08-29-2016, 07:47 AM   #105
alx.
alx.'s Avatar
41
Update: sort of random but still an update, the idle on my way to work today sat at a smooth 800 without any dips(without AC on). Usually it sits at around 600-700 and it's very erratic.
What could cause this?
      08-31-2016, 01:38 PM   #106
alx.
alx.'s Avatar
41
Installed the replacement MAF but i see no improvements, still pulsating at idle. Do i need to reset adaptations or anything?
      08-31-2016, 04:48 PM   #107
Taskmaster
Japan
2470
Drives: M235i 6MT / E92 328 Msport 6MT
Why not?
      08-31-2016, 08:51 PM   #108
Three_thirty_I
South Africa
200
I would definitely reset adaptations so that it can relearn with the new part.
      09-01-2016, 02:43 AM   #109
inthehat
Drives: E92 325i SE Black
For what its worth my car always feels better once adaptions have been reset without changing anything else but its only short lived before the issue is noticeable again.
spotted this yesterday
https://wiki.bentleypublishers.com/d...or+fault+codes
i'm still not showing any codes.
i've now got INPA, ISTA-D+P happy to try any suggestions anyone has. what I really need but don't think it is capable of is logging live driving parameters anyone know how to do this?
      09-01-2016, 03:19 AM   #110
F22_Raptor
F22_Raptor's Avatar
Drives: 2008 328i
Have you checked the Eccentric valve sensor? Its the little black cable next to coil #1. just pop it off and see if there is any oil inside.
