BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Guide to Upgrade 6.5" Screen to 8.8" Screen HU_ENTRYNAV
GetBMWParts
      01-03-2018, 09:50 PM   #89
tpliquid
95
Drives: f31 330i wagon
Has anyone upgraded from 2018 6.5 inch to 8.8?= inch screen? I couldnt find any info on it.
      01-04-2018, 06:16 PM   #90
MarkoSK
Drives: BMW G20 330eX
Enter your VIN on realoem.com and post the screen ("Enternainment System") part number.
      01-04-2018, 09:01 PM   #91
tpliquid
95
I think this should be it.
      01-05-2018, 05:59 AM   #92
MarkoSK
65506837127
You have HU_ENTRYNAV2, which is a successor to HU_ENTRYNAV. It should be able to be coded for an 8.8" screen, however, I'd first check the coding via eSys and ENET cable.
EDIT: The non-touch 8.8" screen for your head unit should be this one: 65506822626. However, the older models *may* also work, but we haven't tried them with the newer head unit, yet.
      01-05-2018, 11:04 AM   #93
tpliquid
95
Thanks for the response. Looks like there arent any new model screens for sale yet on ebay. Guess gotta wait it out.
      01-06-2018, 02:17 PM   #94
Anastomose
Spain
Drives: BMW 420D Coupe
Originally Posted by kromix View Post
What parts are required other than the screen itself?
Screen Swap then code code:
HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480
HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display
I have a HU_entrynav with 6.5 screen and I´m thinking to change to 8.8.
Where are this codes if using esys?
Do I have to pay 100 euros if I would like to code with Esys? Correct?
Many thanks in advance?
      01-06-2018, 03:07 PM   #95
MarkoSK
You just need an ENET cable or adapter (ebay example), then just install the software and follow the included guide. If you do it yourself, the cost is just $20 (price of the cable).
      01-06-2018, 03:32 PM   #96
Anastomose
Spain
Hi
I have Enet cable, not the screen yet.
I don’t know where is those codes:
      01-06-2018, 03:40 PM   #97
MarkoSK
I've sent you a PM.
      01-09-2018, 05:32 AM   #98
Diljee
South Africa
Drives: BMW 2015 F32 420d Msport
Originally Posted by bill_f31 View Post
I'm about to upgrade the 6,5 screen on my 08/14 (HU_ENTRYNAV) F31 Touring to the 8,8 one.
My car is pre-LCI and I have already retrofitted the BMW Integrated Navigation System on my 6,5 screen.
Do you think that a 8,8 screen from an LCI model (part number 65509387453) can be retrofitted to my car or I need to instal the 8,8 screen from pre-LCI model (part number 65509292248)?
Are there significant differences between these two 8,8 screens?
Also the split screen function of the 8,8 screen needs some coding to work or it is automatically set as a menu option as long as the 8,8 screen is installed?
Any help would be hugely appreciated. Thanks in advance.
Hi Bill, how did you retrofit "Integrated Navigation System on" your 6,5 screen?
      01-09-2018, 05:44 AM   #99
MarkoSK
Here are the installation instructions from BMW.
      02-06-2018, 10:43 PM   #100
FrozoneF30
Drives: 2013 328i / 2008 M5 (smg)
No.
HU_ENTRY = can't be done.
If your car has HU_ENTRYNAV (Introduced 7/14) then you can do it.
Basically I’m screwed if I have HU_ENTRY. No work around it? Also how can you tell if you have entrynav or not
      02-07-2018, 08:07 AM   #101
MarkoSK
No way around it - only by replacing the head unit, which is a hard retrofit to do.
Best way is to check via ENET cable and eSys software. If your car was made after 7/2014, there's a good change you have HU_ENTRYNAV. Some cars (with basic/business nav) have them sooner, from 4/2014).
      02-11-2018, 05:51 PM   #102
tpliquid
95
I finally got the enemy cable what else I need check besides the resolution size of changeable?
      02-12-2018, 06:59 AM   #103
MarkoSK
Just check if you can see and select/change these two values:
HU_ENTRYNAV2 > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480
HU_ENTRYNAV2 > 3001 EXBOX > DISPLAY_VARIANTE = breites_display
      02-12-2018, 10:19 AM   #104
fergie1980
Drives: 2017 f31 msport
Hi All, I have a F31 with entrynav and about to buy a bigger screen, my current one is 65509322120, which ones can I upgrade to - seen some 8.8's that have come off a F45 and F21 - would these work?
      02-12-2018, 02:17 PM   #105
MarkoSK
What month/year was your car made?
      02-13-2018, 05:02 PM   #106
fergie1980
March 2017 I have found part number 65509387453 for a good price - will it fit?
      02-14-2018, 07:24 PM   #107
MarkoSK
If you have HU_ENTRYNAV, it should
      02-16-2018, 12:02 PM   #108
tpliquid
95
Good news is it has both available however resolution size only displays "6.5" "7.X", "8.8", and "10.X" witn no resolution behind it.
      02-16-2018, 06:07 PM   #109
MarkoSK
Well I guess they don't explicitly show the resolution now. What is new is the 7" size.
      02-16-2018, 08:02 PM   #110
tpliquid
95
I have to log in again to see. Give me 15 min
