02-21-2019, 09:05 PM | #91 |
28
Rep 98
Thank you. Being perfectly honest, there are a few blemishes but only I could see them and only if you view the mirrors from up close. They were the most difficult to wrap due to the compound curves. I could probably re-wrap them and get them perfect but as the saying goes, "Perfect is the enemy of good enough" so I'll leave them be. Nothing but compliments from people who see them!
02-22-2019, 08:48 AM | #92 | |
Rep 1,623
Next step; real carbon A friend of I start doing carbon trim peaces in his basement for his audi B7. After few tries, he did something very rs4 oem look. Impressive. But it need to be a hobby, its time consuming. but fun |
02-22-2019, 08:56 AM | #93 |
Rep 921
I like the interior, but I think I'd prefer a glossier finish on the mirrors. Seems like it'd just look like matte plastic from further away. But good work, looks well done.
02-23-2019, 04:31 AM | #94 |
28
Rep 98
I think so too. But I wanted to keep it the same throughout and since it was my first shot, most of what I read said that gloss shows imperfections more than matte so that was my logic- keeping it easy. But I think I wil order some gloss finish just to play around with it.
02-24-2019, 05:37 AM | #95 |
161
Rep 352
Serviced my rear brakes. Jurid pads, ATE coated rotors & new wear sensor. Note the original BMW pads I took off were made by Jurid. It was really a pretty easy job.
03-01-2019, 09:07 AM | #97 |
71
Rep 230
Battery replaced
Installed new battery, direct replacement, $189 from AutoZone. One thing that is different - hole for vent hose if slightly large, had to use a tiny piece of electric tape to make it snug.
03-02-2019, 01:42 PM | #100 |
71
Rep 230
03-02-2019, 02:27 PM | #101 |
Rep 3
After a cold stretch here in Seattle my trusty 2011 X3 was having some trouble starting. It would always start eventually, but seemed to be struggling. Finally got a trickle charger and tested the main battery....yep, low voltage. Charged it up, and purring like a kitten again!
03-09-2019, 01:51 PM | #104 |
71
Rep 230
My X3 with N55 comes to the end of CPO warranty, so I decided to run Velvtronic test to check the condition (wife drives it so I am not sure if Velvtronic is used in full range).
First ran "Open global VTC limit position adaptation (ABL-DIT-AS1214_TVD_VVAL_RDDP)" - this thing finds lower point of resistance on the camshaft. Takes a few seconds, simple message "Limit positions successfully learnt.". You can hear it hit the limit quite clear (engine was off). Thought it was not enough and next did "Valvetronic servomotor (ABL-DIT-T1214_TVD_VVMO2)" - this one makes you to start the engine, waits till catalytic is up to the temp, then starts moving Vavltronic in the full range every few seconds. Very clear sound on the move , and when it gets to min position engine almost chokes. Then it slowly moves the range. Mine was from 29° to 183° on the shaft. Hope it is normal. All takes about 3-4 minutes. No faults after that, ECU is clean. I think I am in a good stand. |
03-09-2019, 03:12 PM | #105 |
124
Rep 288
Drives: 2009 328i
Oil change and air filter change today at 47k miles on our '17 35i. First service it's needed since the complimentary stuff ran out. My wife racks up the miles on this thing!
03-09-2019, 04:39 PM | #106 |
1623
Rep 2,036
I did the same.
Your engine bay looks clean. Detailed?
03-09-2019, 06:44 PM | #108 |
124
Rep 288
Drives: 2009 328i
03-09-2019, 09:17 PM | #109 |
Rep 1,913
...that's what a car is for-driving! I'm retired and put 15K and sometimes more miles on my car every year.
