07-12-2016, 01:46 PM | #89 |
Rep 8
07-12-2016, 03:42 PM | #90 |
67
Rep 263
8,8" retrofit is only possible if you have newer radio professional from 7/2014 on (HU Entrynav). Therefore you need the L7 High 8,8 screen.
But this is a different story. This thread is about "BMW Integrated Navigation" retrofit. No clue whether this is compatible with 8,8" and split screen etc. Noone seems to have tried it here... |
07-13-2016, 09:06 AM | #91 |
Rep 8
07-15-2016, 04:58 AM | #92 |
Rep 24
Hello everyone,
I will start by thanking Shawnsheridan and Radair Successfully installed integrated navigation to my 2013 F10. I worked straight away, but without voice. My car have HU_CHAMP2 instead of HU_ENTRY Tried all setting in of MUTE but with with no effect. Then tried to add Ho-Word "NAVI" to but bit confused how to do..... I read the thread on HIFI coding (how to change FA ) and followed it step by step now I am stuck at step 5 I can see HO-wort but was not able to figure out how to add "NAVI". Do i have to press right click on Ho-wort and then click edit to add "NAVI" Secondly do i have to add NAVI in inverted comma's or only NAVI. I attached 2 pictures, first is of the mute which i coded Second is of Ho-Wort...... Please help Thank you GSB Last edited by drguru; 07-15-2016 at 01:46 PM.. Reason: spelling mistake |
07-15-2016, 07:01 AM | #93 | |
General
10539
Rep 41,178
07-15-2016, 12:00 PM | #94 | |
Rep 24
I successfully added NAVI to Ho-Wort but with no effect still no voice by integrated navigation. suggestions please ? Thank you gsb Last edited by drguru; 07-15-2016 at 01:47 PM.. Reason: spelling mistake |
07-15-2016, 12:05 PM | #95 |
General
10539
Rep 41,178
What did you do after adding NAVI to FA? By itself, that does nothing. You still need to Load Modified FA, Activate FA, and Code car.
07-15-2016, 12:13 PM | #96 |
Rep 24
Thank you Shawn for the quick response.
I did load FA. last step was write FA FP , but haven't activated after that. i will do it. What coding do i need to do ? thank you GSB Last edited by drguru; 07-15-2016 at 12:18 PM.. |
07-15-2016, 12:18 PM | #97 |
21
Rep 92
07-15-2016, 12:20 PM | #98 |
General
10539
Rep 41,178
At a minimum, you need to VO Code your Head Unit (HU_CHAMP, HU_ENTRYNAV, etc.), so start with that.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 07-15-2016 at 01:00 PM.. |
07-15-2016, 12:58 PM | #99 |
Rep 24
Thank you for your lightning response
I coded few options of one by one on HU_champ2, but nothing worked for me till now..... Will try again after a moment and let you know the result. thank you gsb |
07-15-2016, 01:45 PM | #100 | |
Rep 24
I am posting some pics please let me know what to code. i will delete pics later as they take too much space.. i will b highly obliged thank you gsb Last edited by drguru; 07-15-2016 at 02:29 PM.. |
07-15-2016, 01:53 PM | #102 | |
General
10539
Rep 41,178
VO Code: Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE. You need to VO Code your Head Unit control unit.
07-15-2016, 06:45 PM | #106 |
General
10539
Rep 41,178
07-15-2016, 07:54 PM | #108 | |
General
10539
Rep 41,178
After you added HO-Wort = NAVI to FA, did you write the updated modified FA to car VCM? See the complete VO Coding Process here: E-Sys - VO Coding Guide.pdf: https://mega.nz/#!1xpU2DqY!eVG7F6k0d...dVSDBnKk8Rzg90 We need to be sure that when you VO Coded your Head Unit (HU_CHAMP), HO-Wort = NAVI was in the FA that was activated at the time of VO Coding.
07-16-2016, 01:55 AM | #109 |
29
Rep 208
07-16-2016, 05:02 AM | #110 | |
Rep 24
Will post the picture which i took after connecting wires... orange--- pin 40 voilet ---- pin 34 white which you can see lose was later connected to pin 10 please correct me if i am wrong. thank you gsb |
integrated, navigation |
