Next Level Auto Brokers
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Cosmetic and Lighting Modifications
      02-04-2016, 01:15 AM   #89
Status Gruppe MNF
Status Gruppe MNF's Avatar
220
Drives: 03.5 M3 / 2015 M3 Individual
Originally Posted by jwzimm View Post
As has been stated previously, you CANNOT install a conductive shield (CF is conductive) over an RF sensor and expect good results. The reason some CF diffusers might allow the CA feature to work is that they would be of inferior construction and the CF is very thin or possibly not genuine.
Our diffusers are built from 100% pre-preg CF. I believe ours work usually is because of the angle of ours and the fact that it does not extend in towards the center of the car.
      02-04-2016, 07:45 AM   #90
jwzimm
jwzimm's Avatar
Drives: '16 M3
If the diffuser covers the antenna for the kick-feature and it is sufficiently conductive it should attenuate the signal and make the system function unreliable.
It may depend on the number of plies of CF that are being applied or even the tow orientation of the stackup.
The point is, you are installing a small Faraday cage over an antenna. You will see signal degradation.
2008 Honda S2000 - Current
2016 F80 M3 - SOLD!!
2011 e92 X-Drive Coupe - SOLD!!
      05-03-2016, 05:59 PM   #91
hockyfrk07
hockyfrk07's Avatar
14
Drives: f80
Has anyone found a solution to this? Disabling the kick feature an option? Apparently you could only access the trunk if you unlock it with the keyremote if you disable the kick feature. Does anyone know if this is true? Its annoying trying to close my trunk a millions times before it actually closes. I dont care much for the kick feature and can live without it.
      05-09-2016, 11:53 AM   #92
Ferg
Master of my own domain!!
Ferg's Avatar
153
Drives: F82 M4/F15 X5
Would like to know this as well.
      05-09-2016, 11:59 AM   #93
dinonz
Drives: 2016 M3 MWM ZCP
Originally Posted by dangreene View Post
+1 Mine opens randomly quite often. Including in the pooring rain a few days ago resulting in a wet boot!!! (*Trunk..... I'm an Aussie!)
Thinking of changing diffusers bechause of this!
Changing diffusers won't help - it's a feature of carbon fibre (*Fiber..... I'm a Kiwi!)
The BMW installation instructions say to deactivate the kick feature because of this.
      05-09-2016, 08:26 PM   #94
SMOKE EM IF U GOT EM!!
SMOKE EM IF U GOT EM!!'s Avatar
Drives: 06' E90 330, 20' F97 X3m
2006 330i SPORT  [7.34]
Originally Posted by Ehronius View Post
I don't mind losing the function, I just don't like how it randomly opens when I pass by or when I already have the trunk open and I close it but keeps opening. So can this be coded off?
Originally Posted by TooFan328i View Post
Ditto. Agreed!
Yes mine works perfectly fine w the cf diffuser and kick function. Not having issues w the kick function at all. Guess I got lucky in that regards. The issue I'm having is when washing and drying the car. It just pops open randomly. Slippery when wet I guess
LIVE FAST..DRIVE FASTER!!
      05-09-2016, 08:26 PM   #95
JoeyBananas
Drives: NA
How do you deactivate it?
      05-09-2016, 08:35 PM   #96
dinonz
Then yours probably isn't CF
Seriously - it's a fact that carbon conducts electricity, so will interfere with the sensors - if yours isn't interfering, then it could well be that it's not really CF.
      05-09-2016, 08:38 PM   #97
dinonz
http://f80.bimmerpost.com/forums/sho...91&postcount=5
      05-10-2016, 07:10 PM   #98
Certainly cf. There's plenty of people here whom confirmed theirs are working w kick function as well. Replica or OEM. It's hit or miss I guess. Again that's not the issue I have stated wether it's cf or not. Just that it's popping open when it's wet as many others have said. Works perfectly normal when the car is dry. Thanks for the input though. It's good to know
      05-10-2016, 08:01 PM   #99
dinonz
If installed by BMW, they are supposed to turn off the kick feature - clearly others don't, and have variable results as you've experienced.
      05-10-2016, 09:06 PM   #100
Brasko
#LSBM3
Brasko's Avatar
1424
Drives: 2016 BMW M3
Regardless of CF diffuser or not, the trunk "kick open" function can be activated by pushing on the center of the rear bumper. See attached pic and give it a try.
/// M3
      05-13-2016, 11:15 PM   #101
$hah$
$hah$'s Avatar
Drives: F80 MG/MT/ZCP & 2023 X7
2023 BMW X7  [0.00]
2018 BMW M3  [0.00]
This happened to me the other night leaving the gym parking lot. Put my ticket in the machine to exit the garage and once I started to inch out to merge on the street my trunk randomly popped open and the car behind me started honking giving me a heads up. Other times I wave my foot for what seems forever and can't get it to pop open for the life of me. Weird/ bugged out feature. I'm thinking some magnetic waves of the garage's lift/ lever triggered it.
      05-13-2016, 11:43 PM   #102
hockyfrk07
hockyfrk07's Avatar
14
Drives: f80
According to the dealerships I spoke with, turning off the kick feature isn't possible. Is this confirmed?
      05-14-2016, 12:22 AM   #103
dinonz
BMW's published instructions state that it must be turned off - and it can be turned off by coding. That's confirmed.
      05-15-2016, 05:51 PM   #104
jpacc
jpacc's Avatar
106
Drives: M4 MACAO BLUE
2016 BMW M4  [9.00]
hello
i did have read all about this and i just installed the carbon fibre diffuser here is a pic of what i did and its working most of the times more response from the left part than the right don't know why
      06-15-2016, 08:39 PM   #105
Chopstick217
Chopstick217's Avatar
Drives: BMW 2020 M8 F92 Donington Grey
Anyone else have success with the OEM rear CF diffusor?
      06-22-2016, 01:49 PM   #106
sandjam
Drives: 2016
So I installed the Status Gruppe CF diffuser today. They told me the kick sensor would not be affected. The kick feature has worked perfect since I got my car a month ago. After installing the Status Gruppe it no longer works with the kick motion.
So I tried kicking my leg further underneath. Almost lost my balance and shin scrapped on diffuser edge.
      06-22-2016, 01:59 PM   #107
dinonz
So I tried kicking my leg further underneath (my shin actually touched the diffuser) and then it popped open. What I figured out is it was not the kick motion. It was that I actually touched the diffuser (when my shin touched it). So I experimented and if I touch the diffuser, anywhere (and I mean a very light, barley touch) it opens. Or just barley touch it with my leg, it opens even with jeans on.
Here the rub. It will only work if the car is not in sleep mode. So if you lock car, it will still work until it goes into sleep mode. Once it does it won't work. So essentially if you go into the store and come out 30 minutes later it won't work unless you wake up car first by unlocking it. So what's the point of having it.
Keep in mind my car is only a month old with latest 58.3 BMW software from factory if BMW changed anything, but this is crazy.
Once again - this is not a fault with the car.
By installing a CF diffuser you have placed a faraday cage in front of the sensor. This will alter its ability to function correctly. This is expected behavior.
iatacs19462.50
      06-22-2016, 02:52 PM   #108
sandjam
Drives: 2016
I had to look up Faraday cage, haha but that makes sense.
      06-22-2016, 04:41 PM   #109
dinonz
Yeah. The BMW instructions for their diffuser include coding the foot release to be inactive for that reason. To make it worse, I've heard of issues with water flowing over the diffuser tripping the release if it's not deactivated.
      12-03-2016, 09:17 PM   #110
AIRPOWER
AIRPOWER's Avatar
Drives: 2015 6MT YMB M3, 1974 Corvette
2015 BMW M3  [9.67]
I put a rear diffuser on on my '15 M3 and lost the kick feature until I relocated the sensor to the left hand side of the bumper cover. Works great since doing that.
AIRPOWER
f80post
