BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > n55 world record HP stock turbo?
proTUNING Freaks
      03-20-2017, 03:45 PM   #89
GTBrandon
GTBrandon's Avatar
Drives: 13' M3 Competition
Originally Posted by F30_SixSpeed View Post
Originally Posted by GTBrandon View Post
Yes but dynojet are not true numbers, therefore you will never know what is actually going through the wheels, and more importantly, how close you are to the threshold of these cars.
What? Get a baseline #. Most n55 dyno around 270-280whp bone stock. Then dyno current setup with same correction and smoothing factor. Dynojets are pretty similar across the board across the country,world etc. so how are they not accurate?
Bone stock I dynoed 273whp - with roughly a 15% correction factor that's 313 hp at the crank... that's pretty accurate to the factory claimed numbers. BMW is also known to underrate some of their engines, such as the n54-n55 and M models.
Again, dynojet are not true numbers so your 273 plus 15% correction is an exaggerated number. That is not what you make to the wheels given the weight of your vehicle and resistance it adds. You make 300 at the crank on real numbers, period. Don't try and act like dynojets are precisely accurate. They are used by companies to advertise products as to show the highest hp gains, not the most realistic. If you want to try and "out dyno" somebody then dynojet is for you. But if you care about real numbers, then look somewhere else.
Current: 12' E70 X5D | 04' Yamaha Warrior
Past: 13' Audi S6 | 13' E70 X5M | 13' E92 M3 Comp | 14' BMW 335xi GT | 95' E36 M3 | 84' BMW 733i | 06' Porsche Boxster S | 15' Jeep Grand Cherokee | 06' Acura TL |
85' Honda Shadow VT700 | 05’ Yamaha R6 | 12’ Triumph Tiger
harkes1091.50
      03-20-2017, 04:04 PM   #90
Chicken_Joe
Chicken_Joe's Avatar
Drives: 2013 F30 335i M Sport. EB 6M
You roasted him fam. These cars accurately make about 240ish I think or thereabouts bone stock to the wheels. On a mustang I think with FBO minus the turbo the N55 for the F30 made about 275whp
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
      03-20-2017, 06:09 PM   #91
F30_SixSpeed
F30_SixSpeed's Avatar
1171
Drives: 335i M Sport
Dynos are used as a tool. I don't understand how dynojets are not accurate. The same correction factor is used on all dynojets... so if I go to a local dynojet, run the car, get the numbers... then drive down a couple states away to another dynojet... utilizing the same correction factor and smoothing, the numbers will be similar. So if you get a baseline and make 200 whp... add mods and make 250whp, you have gained 50whp. So how is that not an accurate representation of mods? Do they read higher then mustangs? possibly? are they Inaccurate? sorry bud you are wrong.
I simply stated you can do a baseline dyno on a dynojet (zomg even if the number reads higher) and then dyno after whatever mods you added and get another number... then look at the difference (hopefully in the positive) and you will be able to see your gains.
Keep thinking you know it all bud.
335i M Sport 6MT || PS2 Turbo, FBO, XDI-35 HPFP, BM3, KW, MP BBK, OEM+
INSTAGRAM || BUILD THREAD
FSociety3816.50
GTBrandon260.00
      03-20-2017, 10:55 PM   #92
GTBrandon
GTBrandon's Avatar
As stated in my very first post, they might give deltas but do not state true start or finish numbers. My point was, they don't tell you what actual numbers you are putting down. They will be the same across all dynojets, yes, and they will give you a delta, yes. But with a dyno jet, your starting and ending points are both higher than the actual numbers. While deltas will remain, it does not help for testing thresholds. Therefore you don't know how close you are to ruining your transmission or blowing a piston.
      03-20-2017, 11:33 PM   #93
FThirtyFive
87
Drives: F30 335i
GT, what the hell are you blaberring about honestly? LOL dynojets "might give deltas". What thresholds can you know off of a non Dynojet dyno when they all vary so wildly out there? You're not making much sense TBH.
FSociety3816.50
      03-21-2017, 11:05 AM   #94
GTBrandon
GTBrandon's Avatar
My point was, it's helpful to know the numbers that are hitting the ground from your car to see if you need to enhance any mechanical weaknesses in your car before adding more power through your engine. Might have gotten a little carried away
      03-21-2017, 11:43 AM   #95
sicmadek
Drives: 2013 335i sportline
Yall arguing over dyno numbers is like arguing about whos penis is bigger but none of you know how to use it. Meaning wtf does it matter how much power you made if you run slow at the track. This is why my truck never touched a dyno but still broke the 1/4 mile records.
      03-21-2017, 12:03 PM   #96
mookie45
mookie45's Avatar
770
Drives: 2017 AW 340i M-Sport
So are there any 1/4 mile times or 60-100 mph pulls?
FSociety3816.50
      03-21-2017, 01:39 PM   #97
J_MENIS
Drives: 435i
This is the only type of dyno I use
Click videos to see each cars setup
@Menis_F32 2015 435I Msport EWG - Muffler Delete, JB4, E30/40, VRSF Catless DP, Resonator Delete, BMS Intake, H&R Super Sport Springs, VRSF CP, Phoneix FMIC, BM3 STG2 OTS 91 - JB4 BEF
Appreciate 3
sicmadek223.00
GTBrandon260.00
FSociety3816.50
      03-21-2017, 02:07 PM   #98
sicmadek
Word this is the dyno i use
J_MENIS114.50
GTBrandon260.00
      03-21-2017, 02:20 PM   #99
f30_garcia
65
Drives: 15 F30 335, Citren Black 340
this post ran away quickly
      03-21-2017, 02:41 PM   #100
GTBrandon
GTBrandon's Avatar
I apologize for that, just curious to know differences between two dynos. Have heard dynojets read higher than mustangs, and wanted to see if there were any other data points for comparison in order to back up that claim. Now back to breaking some world records
      03-21-2017, 03:22 PM   #101
f30_garcia
65
well ordered my port injection today so I will be trying lol
FSociety3816.50
      03-21-2017, 03:50 PM   #102
FSociety
IG @bmwF9xG80
FSociety's Avatar
3817
Drives: G80 M3, X4M, G07 X7m50
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
J_MENIS props for that, i do the same way
x4 BM3 STG2 93vs 335/rwd/6mt/DP/Jb4 map2/5/7
Here I run from 30 roll against F80 M3 ZCP stock, then other runs multiple times against 335GT DP + Activeautowerke active-8 on map7, and F15 X5 35i dmetuning backend flash jb4 with 2 gals of e85 (All friends of mine, we just compare for data)
sicmadek cant wait for strips to open here
Meth for cooling, PI for Fueling ? Looking forward to another WR lol
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo
60-130 4.82s | 9.4@148mph 1/4 Hybrids
IG: @bmwF9XG80
Appreciate 4
mookie45770.00
J_MENIS114.50
Jadar1754.50
      03-21-2017, 03:59 PM   #103
mookie45
mookie45's Avatar
770
This is getting good!
      03-21-2017, 09:18 PM   #104
harkes
harkes's Avatar
China
1092
Drives: M135i, E39 M5, NSX and AE86
What is that "dyno" good for? Even worse for deltas than an actual dyno hahaha!
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China)
      03-21-2017, 09:22 PM   #105
sicmadek
What good is deltas? A dyno is a tuning tool. It will not tell you how fast you are.
      03-22-2017, 09:59 AM   #106
yoandry
yoandry's Avatar
718
Drives: G80 M3CX & X5 M50i
Nice runs Robs. Always taking advantage of those 6sp manual bad driver out there.jk
FSociety3816.50
      03-23-2017, 05:42 AM   #107
FThirtyFive
87
Drives: F30 335i
Holy shit that X4 is flying man!
FSociety3816.50
      03-23-2017, 06:45 AM   #108
Jadar
Dejan
Jadar's Avatar
Serbia
1755
Drives: 2018 Audi S3
Great runs. Thing scoots..
My boost is very identical to yours and the way it tapers. Good stuff.
FBO-PS1 and stuff
FSociety3816.50
      03-23-2017, 11:26 AM   #109
FSociety
IG @bmwF9xG80
FSociety's Avatar
3817
First video was late December/Jan i think, running my 93 map
Second video was running a little more aggressive NEW map that i should run with E30, but was running on 93 that night. (I'm expecting better results when I add E30 mix) the runs were planned last minute and unfortunately no time to add E85.
More coming soon
60-130 6.5s X4M
IG: @bmwF9XG80
Jadar1754.50
      03-23-2017, 10:49 PM   #110
J_MENIS
Drives: 435i
More coming soon
BM3 switch for me tomorrow. Will post more videos when I get the chance
FSociety3816.50
