04-11-2020, 04:37 PM | #89 | ||
Güdentyte
1179
Rep 1,214
Here's a full list BMW M PERFORMANCE M SPORT RETROFIT BRAKE KIT - RED - BMW (34-11-2-462-268) It comes with brake pads. I'm shopping for the same at the moment for my M3 CS. However, ordering it online requires you to submit your VIN on any of the BMW parts stores and if the VIN doesn't specify that the parts will fit (even though we know they're interchangeable), I have seen them rejecting the order. SKU: 34-11-2-462-268 Description: Kit Includes: -INSTRUCTIONS -HARDWARE -BRAKE PADS -PROTECTION PLATE, LEFT -PROTECTION PLATE, RIGHT -BRAKE DISC, VENTILATED, PERFORATED, LEFT (400x36) -BRAKE DISC, VENTILATED, PERFORATED, RIGHT(400x36) -BRAKE DISC, VENTILATED, LEFT (380x28) -BRAKE DISC, VENTILATED, RIGHT (380x28) -BRAKE CALIPER, RED, LEFT (19") -BRAKE CALIPER, RED, RIGHT (19") -PROTECTION PLATE, RIGHT -PROTECTION PLATE, LEFT -BRAKE PADS -BRAKE CALIPER, RED, LEFT (18") -BRAKE CALIPER, RED, RIGHT (18") -BRAKE PAD WEAR SENSOR, REAR -BRAKE PAD WEAR SENSOR, FRONT LEFT
CURRENT - 991 GT3 | Future Classic 1M | Model 3 | T4R TRD Pro Lime Rush
SOLD - MB M2 CS | SMB F80 M3 CS | E90 M3 | E90 335i | E46 M3 Vert | E39 M5 | E34 525i |
FrankMstein1041.50 |
04-18-2020, 10:11 AM | #90 |
Rep 518
The coding is S2NHA for the M2C brakes. Without the coding, mine felt like it had air in the system despite pressure bleeding 4 times. The coding makes a massive difference to the pedal feel and needs to be done IMHO.
Montaver2276.50 FrankMstein1041.50 |
04-24-2020, 10:39 AM | #91 |
Rep 896
Drives: OG M2
What are the coding values and can this be done in BimmerCode?
05-10-2020, 10:28 PM | #92 |
Güdentyte
1179
Rep 1,214
Installed a set this weekend on my M3 CS. Gained approximately 26lbs total over the blue brakes according to my bath scale.
05-19-2020, 03:37 AM | #93 |
Rep 896
Drives: OG M2
Did we ever figure out what coding needed to be done? Retrofitting these on my F87 soon...
05-31-2020, 11:44 PM | #94 |
Rep 896
Drives: OG M2
Do we need to replace the dust shield? Also bump if anyone knows the necessary coding...
06-05-2020, 04:12 PM | #95 |
Rep 499
Drives: '18 F80 6MT / '16 F31
This may have been answered – but i couldn't find it...
When upgrading to a 6piston front setup, what's stopping people from using the swapped OEM F8x 4piston on the rear. (It looks identical to the 4piston you'd be buying in the upgrade kit.) |
06-05-2020, 05:30 PM | #96 |
Rep 518
06-05-2020, 08:44 PM | #97 |
1172
Rep 2,181
Rear rotor thickness is incorrect for the front caliper. Rear caliper mount is also incorrect.
06-16-2020, 03:27 AM | #99 |
Rep 896
Drives: OG M2
Would I be be able to code this with bimmercode or will I have to get a pro?
06-22-2020, 08:08 PM | #100 |
57
Rep 145
samsamdar - trying to do the same thing myself. See my post in this thread https://f80.bimmerpost.com/forums/sh....php?t=1374158 for where I'm at.
Did you manage to figure it out? theMpower - how noticeable was the change? I *think* I've done the required changes as per my link above and maybe it's a placebo, but it feels "marginally" better. But it's not night and day different and it's still a long pedal. |
07-02-2020, 05:51 PM | #101 |
18
Rep 55
Dust shields
I had the same question. Fronts are easy (well, heavy, but easy). Rears do seem to require the entire wheel carrier to come off to remove the dust shield. As I'd like to transfer those over to my ohter car, I don't want to cut them, meaning that the CCB dust shields must be ordered and installed. Right? Or am I being stupid not seeing something obvious?
07-04-2020, 08:03 AM | #102 | |
1172
Rep 2,181
ak_NorCal17.50 |
07-04-2020, 06:47 PM | #104 |
1172
Rep 2,181
07-05-2020, 02:21 PM | #105 |
18
Rep 55
okay, then I am stupid.
07-05-2020, 02:30 PM | #106 | |
1172
Rep 2,181
This is the 380mm M2C rear rotor installed in an M3C (with CCB rear caliper) with standard dust shield: |
07-05-2020, 02:42 PM | #107 |
18
Rep 55
I'll retry.
Thanks, very helpful. I will retry as that is not what mine looks like. The inner edge of the rear dust shield certainly hits the outer edge of the disk. I;ll check what I did wrong. Again, thanks for the picture to show that it should work... Greatly appreciated.
07-06-2020, 03:25 PM | #108 |
18
Rep 55
I must have different parts then
The 370 mm rotor fits as snug as your 380 mm rotor, and the cutout for the caliper is big enough for the standard non-CCB caliper, but certainly not for the M2C caliper. I am starting to think that for 2018, the dust shields were different.
07-06-2020, 06:44 PM | #109 | |
1172
Rep 2,181
Definitely you have something else as a dust shield. |
ak_NorCal17.50 |
07-06-2020, 07:04 PM | #110 |
207
Rep 354
Recently picked up a set of M2C rotors/calipers and will be doing this install this weekend. Ive read you don't have to cut the rear shields but in this video he does.
https://f80.bimmerpost.com/forums/sh....php?t=1721457
