11-18-2015, 11:27 PM | #90 | |
63
Rep 351
if you already have an android device that particular setup would cost: $40 OBDII cable $3 OTG cable $99 flasher module $49 stage II map $49 e30 map $240 and 30-40 minutes of your time if you want the monitoring module so you can see gauges on the device and log runs, it's an additional $69 if you don't have an android device, there are several cheap tablets available online for i think around $50 either way i would highly encourage you to do it yourself, the process is extremely simple and even if you start from scratch the cost would be less than $450
N54 powered
MHD tuned |
Bimmer TV125.00 |
11-19-2015, 12:27 PM | #92 | |
63
Rep 351
http://www.e90post.com/forums/showthread.php?t=1096242
N54 powered
MHD tuned |
11-21-2015, 09:08 AM | #95 | |
Rep 2
Getting ready to flash my vehicle. Question, did you leave your door open while doing the flash? Thanks.
11-22-2015, 08:21 PM | #96 | |
63
Rep 351
one thing to make sure not to do is push the key during the process (dumb i know, but without thinking i did that and it turns off the ECU and interrupts the flash). you'll have to start over from the beginning if you do that.
N54 powered
MHD tuned |
11-25-2015, 10:44 AM | #99 |
3442
Rep 79,211
Drives: C6 Z06, 09 335i, 10 335xi
11-30-2015, 04:56 PM | #101 |
Rep 538
I must have bad luck! I got (2) k+d cables new and (2) otg usb adapter cables with an LG p769 android ver: 4.1.2 and still get no cable detection error (
12-01-2015, 12:07 PM | #106 |
113
Rep 367
Drives: E88 135i
The Google Nexus 7 supports OTG and is not too expensive. I got the base base model and it's been solid. I just keep it in my glovebox and pull it out when ready to flash. Works great!
'10 N54 135i Cabrio || ///M-Sport || SCHWARZ/BEIGE
Mods: JB4, Trebila Custom tune, FBO, Fuel-It Stg2 LPFP, Berk Street Performance w/ Berk Resonated Midpipes, & lots of little body/OEM+ mods |
12-01-2015, 03:51 PM | #107 | |
63
Rep 351
would be wonderful if someone could develop a bluetooth solution capable of supporting the amount/rate of data transmitted with the MHD software. i know there are existing bluetooth OBD devices but don't believe they are compatible. flashing and particuarly gauge monitoring via bluetooth would make for a nice clean cord-free cabin
N54 powered
MHD tuned |
