05-15-2017, 12:52 AM | #89 |
Rep 47
Thank you for responding. Do you plan to rectify the problem or will leave the car without the plates? I want to see if the Ohlins can eliminate a good chunk of wheel gap even with camber plates (given the Ohlins are not designed for slammed looks).
05-15-2017, 10:53 AM | #90 |
Supreme Allied Commander
3897
Rep 54,605
Drives: F80 M3
05-15-2017, 10:54 AM | #91 |
3897
Rep 54,605
Drives: F80 M3
Altering the spring rate and length can get you the lowering you are looking for.
05-15-2017, 11:14 AM | #92 |
Rep 846
If not Swift, how long does Ohlins rear spring take?
2012 X6 35I (Gone) 2013 650 GC (Gone)
2014 M5 Comp PKG (Gone) 2015 X6 50I (Gone) 2017 M3 Comp PKG 2017 MINI JCW 991.2 GT3 (coming) |
05-18-2017, 04:14 PM | #93 |
Rep 1,753
I just ordered the 900lb rear spring from the M2 kits.
I talked with Jake at Ohlin and he said it should work fine. I will have them installed in a couple weeks and report back. The original 1300lb spring is too much for street use and makes the end of the rebound stroke very harsh and abrupt when recovering from larger dips/bumps in the road.
18? Camaro 2SS 1LE
16' M3 MG Ext. /SO Int. (DCT, Ohlin R/T, 19" wheels) 15' Audi S4 13' Audi TTRS (APR stage 1, MSS springs) 09' C6 Z06 08' M3 Interlagos Blue: 6sp, Tech. |
05-18-2017, 07:01 PM | #95 |
Rep 1,753
It shouldn't be too bad, that's 400lbs lighter that what I have now.
I still want firm, I just don't want abrupt/ jarring. As of now a big bump/dip activates the traction control and almost lifts your butt out of the seat near the end of the rebound stroke. 400lbs less should take that away, but leave the firm/tightness
18? Camaro 2SS 1LE
05-18-2017, 07:28 PM | #96 | |
115
Rep 331
Also, for those of you that do have Ohlins installed, can you set any more camber without a plate kit? |
05-18-2017, 07:43 PM | #97 | ||
Rep 1,753
18? Camaro 2SS 1LE
05-18-2017, 09:06 PM | #98 |
115
Rep 331
Do you mean fixed front for Ohlins stock hardware or for OEM suspension. I'm aware of the OEM's limitations. Also is the stock camber setting for the Ohlins greater than the stock OEM's (Approx. -1.5°)?
05-18-2017, 09:14 PM | #99 | |
Rep 1,753
You can always add camber plates.
18? Camaro 2SS 1LE
05-19-2017, 07:56 AM | #100 |
116
Rep 283
Highly recommended! With a bit more negative camber the suspension is awesome and steering is way better.
Kraut-Hero & (occasional) San Franpsycho
05-19-2017, 01:13 PM | #102 | |
3897
Rep 54,605
Drives: F80 M3
TC says yes, but some spools will need to be made for the Ohlins struts. All the interested parties please PM or email me so I can generate a list for TC. Last edited by HP Autosport; 05-19-2017 at 01:31 PM.. |
05-20-2017, 01:01 PM | #103 | ||
Rep 883
05-22-2017, 01:17 PM | #105 |
Rep 621
Just because I'm curious, I looked at the coat of those parts - did I read correctly was this about a $3k + install labor fix?
If so that's pretty salty to fix a manufacturer problem! Just got mine and didn't notice a thing about pulling until I read this thread - now I'm worried every time the car drifts right on me that I'll think it's broken!
2021 M2C, HS / 6MT
2019 Mini Cooper S Hardtop 4 Door / 6MT 2022 Mini Countryman All4 JCW No longer with me: 2018 Golf R, 2017 F80 M3, 2016 F30 340i xDrive |
05-22-2017, 01:35 PM | #106 | |
Libertarian
71944
Rep 4,035
05-22-2017, 01:36 PM | #107 |
3897
Rep 54,605
Drives: F80 M3
05-22-2017, 01:49 PM | #108 |
Libertarian
71944
Rep 4,035
05-22-2017, 01:51 PM | #109 |
3897
Rep 54,605
Drives: F80 M3
05-22-2017, 02:23 PM | #110 |
Libertarian
71944
Rep 4,035
