2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes SHOW OFF YOUR 20"s
      01-14-2022, 10:55 PM   #89
spacegray528
Drives: 2011 BMW 528i
Originally Posted by Blue Angel View Post
^ Sharp!
Thanks, just need to drop it some.
      01-14-2022, 11:13 PM   #90
550bye
550bye's Avatar
Drives: 2011 550i
2011 BMW 550i  [5.67]
Stance SF07 - 20x9 on Toyo Extensa 245/40 in the front and 20x10.5 on Toyo R888R 285/35ZR20 in the rear.
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R.
Appreciate 3
      01-15-2022, 07:37 AM   #91
Blue Angel
Blue Angel's Avatar
1043
Drives: 2011 323i and 2016 535d
Originally Posted by IS500 View Post
How are neomax holding up and how do like them .
They're decent. Not perfect but decent. I'm willing to bet that they're still a good value vs a KW V3 given they're half the price, but they really could use more compression damping.
One of these days I'll do a full review.
      01-15-2022, 10:13 AM   #92
IS500
26
Drives: F10 550
That’s good to hear, looking forward to the review
Thanks
      01-16-2022, 09:18 AM   #93
Makk3
Drives: E92 M3
Originally Posted by 14AWBayArea View Post
What ET do you have on these?
I was offered a good deal for BBS CH for F11 but I don't know if they fit. Wheels are with the following specs:
20x9 ET24 front
20x10,5 ET24 Rear
Does anyone know if they are suitable for the touring?
      01-16-2022, 10:14 AM   #94
Blue Angel
Blue Angel's Avatar
1043
In my opinion, ET24 is going to be very aggressive on the rear unless you're using a narrow tire, like 245 or 255.
      01-16-2022, 10:44 AM   #95
remmib
General
remmib's Avatar
Norway
1571
Drives: 2013 F10 520d M-Sport
20x9 ET24 front
20x10,5 ET24 Rear
I think the CH comes in ET35 too, I'd recommend that.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      03-11-2022, 09:09 AM   #96
Taylorguy74
Enthusiast
Drives: 2016 550i M-Sport
Originally Posted by jayster0966 View Post
My contribution.
What offsets did you go with on these?
2016 550i M-Sport
2008 328i M-Sport (Sold)
2007 Z4M Roadster (Sold)
      03-16-2022, 09:24 AM   #97
jayster0966
jayster0966's Avatar
Drives: 2011 535i
35 offset.
      03-17-2022, 04:15 AM   #98
Kf10x
Drives: BMW 535i
Square 275/35-20 Indy 500 on 20 x 9.5 Fast FC04 et30 F and et33 R:
This setup
John H.230.00
      03-17-2022, 04:16 AM   #99
Kf10x
Drives: BMW 535i
Would 20s be daily drivable in SoCal street?
      03-17-2022, 02:54 PM   #100
Blue Angel
Blue Angel's Avatar
1043
20's on 245/35 and 275/30 runflats (the original BMW setup) is pretty harsh on bad roads and tough on wheels. Lots of bent wheel/blown tire possibilities on potholes.
Using regular non-run flat tires is better as the tires can absorb impacts easier. Going with a taller tire is what I did, which is even better again. 275/35 is 1" larger diameter than stock 275/30, so more sidewall to absorb bumps and less chance of bent wheels.
EDIT: BMW not BEM
Kf10x3.00
      03-17-2022, 03:41 PM   #101
Kf10x
Drives: BMW 535i
Cool thank you, I’m not sure if 20s are for me. I know 19s will be the same price but maybe I’ll get bigger sidewalls
      03-17-2022, 08:25 PM   #102
Blue Angel
Blue Angel's Avatar
1043
Good luck!
Kf10x3.00
      03-30-2022, 05:51 PM   #103
Wht550jersey
13
Drives: 2011 550i
Specs ?
      04-03-2022, 04:00 PM   #104
myalpine535i
Drives: 2016 535i M sport
Originally Posted by bake View Post
OEM M5 wheels
wheels and specs? i have the same model etc... and have been eyeing these. thanks
      04-08-2022, 03:22 PM   #105
BMWGoogler
Drives: 2011 BMW 535ix
Advice on fitment
Hi fam, I'm completely new to wheel choice and fitment, but I'm looking to move to 20" wheels on my F10. I'm thinking of the staggered wheels/tires, and whether they'd sit tucked, flush, etc. I'm hoping for flush or close to it, and I don't want any rubbing or having to run goofy camber or anything. Will these pretty much bolt on and be good to go?
2011 535i xdrive- stock drive height, but I'm considering lowering some
TSW Chicane - Gloss black w/Mirror Cut Face on Michelin Pilot Sport AS3+
Front:
20x8.5 5x120 ET:35
245/35r20
Rear:
20x10 5x120 ET: 40
275/30r20 - or - 285/30r20
      04-09-2022, 07:31 AM   #106
Blue Angel
Blue Angel's Avatar
1043
Those sizes will fit fine, you shouldn't have any issues.
The stock spec for the front is 20x8.5 et33, so you're 2mm less in the front but it will still fit well as the front F10 fitment is pretty good from the factory.
The stock staggered rear is 20x9 et44 and is too far inboard, needing a 10mm spacer to look correct. Your et40 setup only moves the tire outboard by 4mm, and aftermarket 275s are a bit wider than the OEM tire so it should look good.
Some 285s are quite a bit wider than 275s, but should still be ok. Some have tried 285s on the 343m M5 rear wheels which are 20x10 et34 and they rub, forcing them to change to 275s. You have 6mm (1/4") less offset so either tire should be ok.
      04-11-2022, 12:37 PM   #107
BMWGoogler
Thanks, I appreciate it. The shop has 275s as well as 285s. I could switch to the 275s.
      04-14-2022, 03:29 AM   #108
aumazdelete
aumazdelete's Avatar
Drives: 2012 BMW 535 xi
That thank lip A+
      04-14-2022, 03:30 AM   #109
aumazdelete
Trunk lip dope
550bye1391.00
      04-16-2022, 04:10 PM   #110
550bye
550bye's Avatar
Drives: 2011 550i
Trunk lip dope
Thanks.
2011 550i (N63)
5post
