      10-28-2017, 03:53 PM   #89
ShocknAwe
1Addict
ShocknAwe's Avatar
3245
Drives: E82 Mutt, M57 Truck
Originally Posted by tjswarbrick View Post
I can't speak directly to the N54 gearbox, !
For anyone reading it won't fit the same in the N54 cars. Hell, n54 335i levers fit differently in the 135i version. Not as big a difference as N54->N55, but there you go.
2010 135i 6MT Jet Black
N54/3 FE82 Mutt | BUILD THREAD | GARAGE SALE
      10-17-2018, 09:00 AM   #90
swanny71
swanny71's Avatar
40
Drives: 1M, M135i
Thread revival alert but wanted to contribute.
Quick post to say thanks to all who have contributed to this thread, particularly Dack
The relatively long throw on the 1M shifter has bugged me a little from day one, particularly since my 130i daily driver has the BMW short shift lever fitted and has (had) a much nicer feel to it.
Anyway after reading just about everything ever written about 1M/N54/N55 short shift kits I thought I'd give the 130i/330i short shift lever (part# 25110434219) a go since the 135i short shift lever (part# 25110434217) is no longer available.
Worked out well and very pleased with the results. The throw is much reduced, feels a little notchy but in a lovely direct 'mechanical' way. No problems with any weird off-set of the gear knob etc.
The knob is about the same height as before unfortunately. I'd have liked it to drop the same 10-15mm as in the 130i but the shifting arm sits taller in the 1M.
For future reference here's a pic of the three levers I had available during the swap.
Also measured throws on both cars using same method as Dackelone
1M with 25110434219 lever: 3rd - 4th = 41mm
130i with 25110434219 lever: 3rd - 4th = 50mm
      10-17-2018, 01:19 PM   #91
tjswarbrick
<(O0=[][]=0O)>
tjswarbrick's Avatar
Drives: 2012 N55 E88
Really provocative that, with the same lever, throws are ~ 3/8" shorter in the M vs the 130.
Didn't notice before, but I see a bunch of people who have used the "328i SSK" lever on their N55's. One reference to a 40mm-ish throw. For $60, why didn't I get this instead of the E60 550i lever I had to buy a press to bend?
I don't really want to go tearing into the guts again, but for only $60 and an afternoon of my time it could be a worthwhile further upgrade. Definitely sits lower than the one I used!
2012 E88 M-Sport 135i DSB Metallic
COBB CP, ZHP Knob, E60 SSK Lever, E92 M3 FSB, RSFB inserts, Koni Sport, Eibach Pro, UCP, MPSS, AP axle-back, MHD Stage1+ 91
<(O0=[][]=0O)>
Dackelone10638.50
      10-10-2019, 04:47 AM   #92
l1stigerlurch
Drives: BMW 135i N54
Originally Posted by Dackelone View Post
Do you mean #7 in the first diagram bellow? If so... yes, you can reuse that with a new shift lever.
The white plastic bushing(#4) for the shift lever should always be replaced. Most of the time it gets brittle since it sits right on top of the exhaust. Always replace it.
You should also buy new washers and c-clips(#6) for the rod linkage... you WILL loose one or more and then your F'd. Buy some spares they are cheap.
135i Perf shifter
Attachment 1656916
128i shifter
Attachment 1656922
Hi,
Im trying to figure out the same question. So if i understand you correctly in my E82 135i N54 I can simply buy 25117542200 plus bearing and circlip and use the old #7 from my stock shifting kinematics? This would make the job so much easier and cheaper since the original n54 135i ssk one also includes a new #7 and is a PIT to change.
      10-11-2019, 05:24 PM   #93
Dackelone
European Editor
Dackelone's Avatar
Germany
10639
Drives: N54 e82
Originally Posted by l1stigerlurch View Post
Hi,
Yes. I think by using the 128i Performance Short Shift lever(p/n 25117542200) with a new plastic bearing and two circlips - this would give you 90% of the 135i's SSK feel.
The 135i's SSK is no longer available that comes with a modified #7 saddle.
The 128i Perf SSK(lever) will give you 90% of the feel and shorter shifts movements that you are looking for.
Btw... here is the install pdf...
      10-12-2019, 11:09 AM   #94
l1stigerlurch
Awesome thank you I will try that. I actually found a original unused 135i ssk by chance but wasn’t so fond of doing the whole thing since it’s a lot more work then just changing the lever. And 90% for casual sporty driving is perfect
Dackelone10638.50
      10-12-2019, 05:03 PM   #95
ShocknAwe
1Addict
ShocknAwe's Avatar
3245
swanny71 Dackelone
Any confirmation of what transmissions this works with? I am given to understand the N55/1M have different trans than N54 with varying shifter arm angles. Also not sure how the 130 vs 128i vs other arms compare when trying to keep the lever centered in neutral.
      10-13-2019, 06:38 PM   #96
Dackelone
European Editor
Dackelone's Avatar
Germany
10639
Drives: N54 e82
Originally Posted by ShocknAwe View Post
swanny71 Dackelone
The 1M uses the N55 135's transmission.
The 130i Perf Shift lever arm is: p/n 25110434219
The 128i Perf Shift lever arm is: p/n 25117542200
I do not know what the difference is between the two shift levers. I suspect they both would work just fine. I also suspect the 130i lever has shorter throws since the 130i was BMW's sporty hot hatch at the time. Only way to know for sure is to order both shift arms/levers and see!
Since both shift levers were designed for the 1er... I would bet that they are totally PnP parts. But again... the only way to know for sure... is to order one(or both!) and give it a try.
shifter throws...
N54 = 80mm throws
N54 w/Perf SSK = 55mm throws
N55 = 70mm throws
See post #47...
https://www.1addicts.com/forums/show...=414760&page=3
Dackel
      10-13-2019, 07:10 PM   #97
ShocknAwe
1Addict
ShocknAwe's Avatar
3245
shifter throws...
N54 = 80mm throws
N55 = 70mm throws
See post #47...
Dackel
Appreciate this. Have a shiftek SSK which works but not happy with it anymore. Have to decide whether to play the BMW lever game or just go RTD.
      10-14-2019, 01:21 AM   #98
l1stigerlurch
apparently the 25117542200 is at least in germany indicated as the one for 125i but i guess it's only because there is no 128i in germany. ordered one an will try it out as soon as a i get some spare time to fiddle around without using renting a ramp or so
Dackelone10638.50
      10-14-2019, 07:13 AM   #99
swanny71
swanny71's Avatar
40
Drives: 1M, M135i
swanny71 Dackelone
As Dackelone has already mentioned this works on N55 MT's and the 1M (same box). The 130i arm I fitted was perfectly centred on the 1M - think I posted pic last year?
However, I've moved on since then. I'll do a write up soon but here's a pic of my latest DIY modified/hybrid lever that I think is perfect in the 1M.
Compared to the 130i lever the shift throw is slightly longer (it was always a little too short) but the knob sits 10-15mm lower (which I really wanted).
The method I used should enable you to create a bespoke (to you) shift feel on any BMW manual box.
      10-14-2019, 11:23 AM   #100
ShocknAwe
1Addict
ShocknAwe's Avatar
3245
As I was unfortunately expecting. Won't be able to use this as my trans is different and will likely be badly off center.
Appreciate the info regardless.
      03-31-2022, 05:29 PM   #101
Fishee
Fishee's Avatar
1060
Drives: 135i MSport
Grave digging here.
Does anyone know if the 135i shift linkage is available for purchase? I can't seem to find it anywhere, as it's been discontinued.
BMW 25110434218
It's the only piece of the BMW PSSK that I can't find!
      04-02-2022, 07:52 PM   #102
inevitab1e
49
Drives: '13 135i N55 FBO
Originally Posted by Fishee View Post
Grave digging here.
BMW 25110434218
This it?
https://www.bmwpartsdeal.com/parts/b...110434218.html
https://parts.bmwnorthwest.com/p/bmw...110434218.html
https://parts.bmwmonterey.com/p/BMW_...110434218.html
      04-03-2022, 08:33 AM   #103
Fishee
Fishee's Avatar
1060
Drives: 135i MSport
Correct part, I’ve already contacted all three - all confirmed that they do not have availability.
      04-07-2022, 01:51 PM   #104
tjswarbrick
<(O0=[][]=0O)>
Long shot - but Rogue Engineering sometimes made the arm for their shift kits. They did a shifter for the E88 1M Coupe. (Say it's not for 135.)
Could give them a call and see if they ever prototyped it, or would be willing to.
Other than that - junkyard/pick-n-pull?
<(O0=[][]=0O)>
Fishee1059.50
      09-08-2022, 09:58 PM   #105
Cadubya
Drives: 2011 135i MANual
I have an 135i N55. What’s my options for oem plus short shifter? 1M?
