BMW M3 Forum (E90 E92)
BPM
      05-11-2013, 10:18 AM   #89
OilPatch
OilPatch's Avatar
Drives: VW TDi & BMW M3
2013 BMW M3  [0.00]
2010 VW Jetta TDI  [0.00]
Just placed my order for the EU switch from ECS, just because I'm OCD like that
2013 E92 M3 | Le Mans Blue | 6 Speed Manual | Competition Pack | Premium Pack | Cold Weather Pack |
      05-11-2013, 11:21 PM   #90
pilotchip
Air Traffic Controller
pilotchip's Avatar
Drives: 2012 E92 M3
2012 E92 M3  [0.00]
Well done! I almost bought the switch, but it's way more rewarding to have it "hidden."
I released BOTH the top and bottom buttons and the "force headlights on" when the switch is on "Auto" works like a charm - let's call it a "twofer"!
Bimmerfest 2013! | Event Map
2012 E92 M3 - Check out my mods - My other BMW is an airplane.
Last edited by pilotchip; 05-13-2013 at 12:30 AM.. Reason: Headlights confirmed working!
      06-29-2013, 02:17 PM   #91
beats
beats's Avatar
225
Drives: 2015 911 GTS
Super easy. Hardest part was prying the clips on the black button back to release the button... If you have them, good plastic tire irons work in place of a trim pulling tool. Worked awesome...
      08-06-2013, 09:27 PM   #92
OilPatch
OilPatch's Avatar
2013 BMW M3  [0.00]
just installed my euro switch, thanks for the write up
      08-27-2013, 12:40 AM   #93
creaminz
creaminz's Avatar
Drives: E90 LCI
thanks!! this was super helpful!
      08-27-2013, 08:41 PM   #94
NAV8TT
NAV8TT's Avatar
Drives: 2013 ///M3 E92 DCT ZCP
Excellent post. Done in 15 min. Thank you. This will help in Florida given the sudden blinding pouring occasional rain. Thanks buddy.
      08-28-2013, 02:02 AM   #95
gimmethemuumuu
Drives: '17 F80 M3, SO/Bk
Just did this tonight. Both buttons. Since I have an '08, I had to perform the Lego mod. However, in my case, it was the dowel rod and Duplo mod
This creation, combined with one or two felt pads was sufficient to bridge the gap between the buttons at front and the circuit board at the back.
Thanks, OP, and all who contributed to the thread!
Updates:
Rear fogs work just fine. However, I'm getting no dash lights indicating such on my very early-model 2008 launch E90. Also, unless I gummed up the top, instant-on headlight button (certainly a possibility), I'm not getting this functionality--lights on auto, press button: nothin'. I'll update later if things change and I'm able to get this button to work as intended.
OK, so maybe I was smoking something the other night. Turns out, the rear fog dash light is working for me. I think I may have not seen it the previous night. Then, when I was checking it during the next day, the headlights weren't on. Therefore, it makes sense that the rear fogs wouldn't come on then
      09-16-2013, 06:14 PM   #96
Gasman1
Drives: SGM E92 M3
Did this mod the other day. I must say those rear fogs are bright! All in all a good, cheap mod that does not take all to long (about 30min). Thanks OP!!
      09-17-2013, 02:31 PM   #97
rich22
51
Drives: E92 M3 Race Car
Just did it, 15 minutes. Thank you!
Rich
      09-17-2013, 02:38 PM   #98
gimmethemuumuu
Awesome!
Anyone with a 2008 unable to to get the top button working to instantly turn on the headlights when in (A)uto mode? I'm wondering if I didn't get things put together right there or whether it's possible with an '08?
      12-22-2013, 04:31 PM   #99
Billj747
Billj747's Avatar
Drives: Everything
Originally Posted by mdosu View Post
Just completed this on my 08, had to use the lego concept to get it to work. I used a bic pen cap glued to a strip of an old credit card to form the T, Overall, I likely will only use this in the handful times when driving through heavy rain.
THANK YOU.
My 09 E90 didn't have the extension either and I couldn't find a good spacer but the bic pen cap was the perfect solution - perfect fit in the button, easy to cut down to size (I cut it a few mm past where the end of the clip is molded into the cap), and rigid. I wrapped the cap in 2 layers of electrical tape so there was a snug fit into the button and so there wasn't plastic on plastic rattling. I hot glued the bic cap to a rigid plastic sheet cut down to make a "T" to hit both buttons and test fitted it so the detent of the rubber buttons on the circuit board was tight against the button (so the button does not sag).
Done in less than 15 minutes and works perfectly. Why don't we get these functions in the states?
      12-26-2013, 03:07 PM   #100
Bavarian Beast
Too many wagons on the bahn.....
Bavarian Beast's Avatar
98
Drives: LMB 2011 BMW e93
Anyone know which fuse controls the rear fogs?
      12-29-2013, 05:57 PM   #101
dman229
2008 e92 M3 MT
Drives: 2008 e92 M3 MT
OK I finally found the time to retrace my steps and the clue is that both contacts need to be pressed simultaneously. Since I had to do a makeshift "lego mod" (mine is an '08)
it was tilted slightly when depressing the switch.
Mod now works ! awesome.
      02-18-2014, 07:01 PM   #102
Mean M3
Drives: 2013 E92 M3, 2015 F15 35i
Awesome DIY. Great write up. Finished in 15 minutes. Thanks.
      03-06-2014, 12:45 PM   #103
chadwick
18
Drives: 2023 BMW 540i
Worked like a champ on my 2010 with a 12/17/2009 build date (tab removal; no legos or fuse needed).
      03-14-2014, 09:34 AM   #104
B8bydesign
B8bydesign's Avatar
Drives: '11 BMW M3
2011 BMW M3  [10.00]
Do you have to purchase the whole ECS Euro Headlight Switch assembly just to get the rear fogs button? I assume even if you can find the individual button, it will not light up without the true Euro Headlight Switch. If you do, can you swap back in a blank from the stock assembly instead of the front fog button to accurately reflect the M3 lighting configurations after performing this mod (since we don't have front fogs)? Thanks in advance.
New: '11.5 e90 M3 | DCT | Space Gray/Novillo | ZCV | ZCW | ZP2 | ESS 625 | BPM | M Performance | iPE | BC Racing | BPM | iND | LUX | Volk | Coby | Recaro
Sold: '11.5 e92 M3 | DCT | Mineral White/Novillo | ZCP | ZCV | ZCW | ZP2 | M Performance | ACM | BPM | iND | Thule | LUX | Macht Schnell | Broadway Static | Rogue Engineering | BBS | Challenge | Metak
      03-14-2014, 09:40 AM   #105
kscarrol
kscarrol's Avatar
Drives: 2021 X3 M40i, 1974 2002 Tii
I bought the Euro switch from ECS, it does not have the front fog switch. I have included a link to the proper switch with chrome trim, for cars with rain sensor but no front fogs.. It is an easy swap, took 5 minutes. Just be careful popping off the dash trim pieces so you don't scratch them... More expensive route than the DIY but I like the properly labeled button on the Euro switch.
http://www.ecstuning.com/BMW-E90-M3-...hes/ES2500537/
2021 X3 M40i
1974 2002tii, Inka, 5 sp manual
BMWCCA # 327475
      03-14-2014, 09:48 AM   #106
B8bydesign
B8bydesign's Avatar
Drives: '11 BMW M3
2011 BMW M3  [10.00]
Just saw that! Thanks. I had clicked on a link in this thread and it directed me to this piece:
Then I saw they offered it as you described which satisfies my OCD, ha.
      05-19-2014, 11:21 PM   #107
dj_dub
IG: @dj_dub
dj_dub's Avatar
1808
Drives: 2010 BMW E90 M3 - SG/FR 6MT
Thanks to this DIY, I finally did this mod…but opted to purchase the OEM Euro Headlight Switch instead. Very happy with the outcome! Thanks OP for creating this thread!
IMG_4780a by dj_dub, on Flickr
IMG_4809a by dj_dub, on Flickr
IMG_4821a by dj_dub, on Flickr
IMG_4820a by dj_dub, on Flickr
CarboProject CF Plenum | Dinan CF Intake | ESS Tune | RKP X-Pipe | Akra w/CF Tips | MFactory CF DS | CSF Cooling | AST 5200 | Hotchkis F/R Sways | SPL/Ground Control/Fall-Line Arms | DEFIV Diff Brace | StudioRSR Rollcage | 3-piece BBS RT88 | Michelin PS4S | Brembos F/R | Recaro Profi SPG XL | CAE Ultra Shifter | Perf Elec Wheel V2 | BAVSOUND | GT4 CF Front Lip/Canards/Rear Wing | Arkym CF Rear Diffuser | Forcewerkz CF SS | Varis CF Lower Tray | Turner Skidplate | BayOptiks Headlights
      05-20-2014, 08:51 PM   #108
Flea7
Flea7's Avatar
Drives: E92 M3 6MT/F48 X1/F430/F12
2016 X1  [0.00]
2008 E92 M3  [0.00]
2005 Ferrari F430  [0.00]
2014 Ferrari F12 Be ...  [10.00]
Does anyone know if we have the wiring for the front fog like the non-M e90's and 92's???
Just wondering if i can use the top switch if it's already wired.
Thanks,
      05-20-2014, 09:42 PM   #109
adc
Drives: 2018 F80 M3 ED
Thanks,
There are no front fog lights on the M3, so no there is no wiring.
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
      05-20-2014, 10:21 PM   #110
Flea7
Flea7's Avatar
2016 X1  [0.00]
2008 E92 M3  [0.00]
Thanks! I thought maybe they used the same wire harness as the non M's
m3post
