KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
03-27-2023, 06:00 PM | #1079 |
252
Rep 159
I did not pull the liners and to my surprise, I did not rub the fender liners in front of or behind the tire. Running >3.5 degrees camber up front. I would not attempt to daily drive or street drive at all with this set up.
With a 5mm spacer it would just touch and self clear the liners but I only needed a 3mm for spring perch clearance Other tires this size may rub so be mindful of that |
03-28-2023, 12:44 PM | #1080 | |
97
Rep 130
04-11-2023, 11:44 AM | #1081 |
bigred_m3
52
Rep 12
BBS RIA
Finally got everything dialed in on the M3
04-11-2023, 02:49 PM | #1084 |
21
Rep 68
04-12-2023, 08:59 AM | #1085 |
Field Marshal
6735
Rep 1,829
Drives: '08 E92 M3
Luv this shot and very nicely dialed in too.
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
///M Power-Belgium64779.00 |
05-06-2023, 03:30 PM | #1086 |
24
Rep 99
Titan TD6 18x10.5+25 Square / 285/35/18 accelera 651’s
F: 12mm spacer / -2.1/-2.4 camber / 0 toe R: 18mm spacer / -1.7/-1.7 camber / 1/32 toe they do run small for 200tw. Very slightly rubbing on harsh bumps in front, no rubbing in rear. |
06-08-2023, 12:57 AM | #1089 |
63
Rep 84
Apex ec-7, Bridgestone Potenza RE71rs
18x10 et25. 275/35/18 18x11 et44 rear (with 15mm spacer making it et29) 295/35/18 Swift spec R lowering springs -1.7 camber front and rear No rubbing |
MisterClutch888558.00 DrFerry6734.50 |
06-16-2023, 11:59 PM | #1090 |
129
Rep 251
Drives: F82 M4
Garage List 2011 M3 Competition [0.00]
2022 Challenger Hel ... [0.00] 2017 Grand Cherokee ... [0.00] 2009 Lamborghini Ga ... [0.00] |
Has anyone fit a 285/35/19 on a stock rear ZCP wheel on stock suspension? Going for the meatiest tire possible. Again forgive me for not reading through the entire thread. Thanks!
06-29-2023, 10:46 AM | #1091 |
Rep 1,751
that's a tall rear? almost 30mm taller from a standard 295/30
06-30-2023, 03:20 AM | #1092 |
103
Rep 92
Drives: 2011 E92 M3
How did you get this to fit? I just test fitted 18x10.5 +25 on 275/35R18 nankang CR-S and it would not clear my strut. Tried a 5mm spacer and still made contact. I'm on KW HAS kit btw with Ohlins R&T sitting in my garage. I hear both of these kits dont clear the above fitment without at least a 10mm spacer, then you run into outer fender clearance, which camber plates would then be a must. Could use some guidance from those running similar specs.
2011 E92 M3 / Alpine White / Fox Red / 6MT / CNT Racing / Forgestar F14 19x10 +19 265/30R19 19x11 +25 295/30R19 |
06-30-2023, 07:25 AM | #1093 | |
Field Marshal
6735
Rep 1,829
Drives: '08 E92 M3
///M Power-Belgium64779.00 jmeenach97.00 |
06-30-2023, 12:22 PM | #1095 |
103
Rep 92
Drives: 2011 E92 M3
Yea 10mm spacer would work. However, I’ve seen a lot of people here make this setup work with no modifications. Am I doing something wrong or is it my coilovers selection
06-30-2023, 03:48 PM | #1096 | |
Rep 1,751
lots of front camber. decent amount of rear camber. also ohlins / kw are not the friendliest for aggressive specs.
07-10-2023, 08:47 AM | #1097 |
Rep 1,225
18x10.5 +25 BBS RI-A
12mm front spacer 15mm rear spacer
Jerez Black E90 M3 6MT KW-AP Racing-Volk-Varis-Akrapovic-Recaro |
08-08-2023, 04:27 PM | #1098 |
22
Rep 339
This is the exact color and setup i wanted. Did you really need the spacers though ?
09-22-2023, 07:39 AM | #1100 |
31
Rep 84
Does anyone know if 19x10 et18/ 19x11.5 et23 will fit with no issues such as rubbing assuming the tires sizes are 255/35/19 & 295/30/19?? Also, is -2.0 camber all around enough? I’m lowered on swift springs with competition pack suspension. May need slicer for this one!
