What did you do to your car today?
02-04-2020, 07:38 PM | #11023 |
Rep 3,140
Second party adjuster is coming tomorrow to look at the damage. Can’t wait to get my car repaired. After the repair, I’m getting a new set of Michelin A/S pilot sport ultra performance non run flats, and having my rear window seal replaced. It started to crumble/peel apart.
02-05-2020, 08:06 AM | #11024 |
Rep 1,189
02-05-2020, 01:14 PM | #11026 |
Rep 1,189
02-05-2020, 03:42 PM | #11027 | |
Rep 4,330
my center piece has a bunch of divots in it from previous owner, and my dash piece has a bulge where someone before me tried to pull it out and tweaked it. |
dyrus5871.50 |
02-05-2020, 05:11 PM | #11028 |
Rep 1,266
Replaced my aluminum trim on my E91 with a carbon leather trim from a M3 sedan
Just need to do something with the center console trim...
2015 BMW X5 ///M | Donington Grey | Aragon Brown MRF Engineering | RG Sport | BMW Performance | Dinan | KW | Vorsteiner | Zito | iND | BMW Parts Pros | Coby 2010 BMW 328i AT xDrive E91 Touring ///M Sport | Alpine White | Saddle Brown |
Barrique91395.50 |
02-06-2020, 02:01 AM | #11031 |
Rep 733
A few days ago I hit some giant ass bumps that caused the steering to no longer be centered when driving straight. I assume I bent a tie rod. New tie rods and boots came in today, so we'll see what happens!
As a side note, it's really interesting to see how the adaptive headlights respond to the steering suddenly not being straight- the input from the yaw sensor must play a large part in it's processing. Turning the wheel straight causes the lights to dart to the right slightly, since the car veers right if the wheel is centered. |
02-06-2020, 11:09 AM | #11032 | |
Rep 624
In the NFRM, find the label PWM_FL_BEI_BIXENON and change both values to wert_01 This gives you the inner halogens, as well as the xenon high beams (shield lifted). Cheers! |
02-06-2020, 11:35 AM | #11033 | |
Rep 624
In the NFRM, find the label PWM_FL_BEI_BIXENON and change both values to wert_01 This gives you the inner halogens, as well as the xenon high beams (shield lifted). As for which bulbs to use, based on my research, I am planning on going with PIAA Xtreme White bulbs: https://www.amazon.com/17655-Xtreme-...24&sr=8-1&th=1 Cheers! |
02-06-2020, 03:07 PM | #11034 |
Rep 4,330
I didn't do it, but my brother has been working on my wheel centers. and those are the BMW floating center caps. unpolished on the right. |
IllSic_Design2124.00 |
02-06-2020, 05:29 PM | #11035 | ||
Rep 51
02-06-2020, 05:36 PM | #11036 |
Rep 5,025
02-06-2020, 05:50 PM | #11037 |
Rep 624
02-06-2020, 07:02 PM | #11038 | |
Rep 4,330
so just cleaning/polishing the factory 2004 clearcoat. I hope to finish up cleaning/polishing soon. then I'll take all of this to his house because he has decent paint gun, and we'll spray them in proper clearcoat. then probably ceramic coat them. then I can order my new summer tires. and I really need to find my wheel spacers. |
tlow982195.50 |
02-06-2020, 07:57 PM | #11039 |
Rep 624
Here's a pic for comparison. It's hard to tell, but the Xenons are on high beam in the lower shot (I can actually hear the shutter move when switching to high beams).
Cheers! Last edited by Clammy; 02-06-2020 at 08:28 PM.. |
02-06-2020, 10:32 PM | #11040 |
Rep 904
Didn't do anything to my car today. Instead, did something with it. Drove it home from work mostly on the bacroads today ( ca84 west of i280 and ca35). Really enjoyed my 6mt 328i after taking my dsg b8 s4 to work for almost a month. Anticipate driving through the back roads tomorrow again since they are mostly empty on the weekdays.
b1aze565.50 |
02-07-2020, 10:55 PM | #11044 |
Old Guy
133
Rep 305
Drives: 335is DCT
I made the jump to wheel studs with Mishimoto aluminum lugs.
[IMG][/IMG] And the new Firestone Firehawks came in and I had them mounted on the 313's. Front 235 35 19 and rear 275 30 19. [IMG][/IMG] [IMG][/IMG] For fun, there's a 275 30 19 next to my Jeep's 315 75 16. [IMG][/IMG]
BQ tune, Flex Fuel, more mods and money that I'll never tell my wife about....
