08-08-2022, 11:28 PM | #1102 |
Rep 22
08-09-2022, 12:32 AM | #1103 |
Rep 10
Coming from the Porsche Macan forum about this issue. I also tried the "fix" to hold down the MOST fiber, and it didn't work. This seems to be an issue with the DSP on the mr12volt box.
However, no issues were present when I returned to the PCM (main nav radio). This further backs up my point of the mr12volt DSP being bunk. I have contacted them, and they have passed the info onto the engineers. Personally, I think it's a bad batch. A bunch of guys on the Macan forums are having the same issue, except for the ones that have preordered the unit. JOJO82 nah dude |
08-09-2022, 12:45 AM | #1104 |
Pingu
239
Rep 486
08-09-2022, 04:45 AM | #1105 |
Rep 22
08-09-2022, 08:24 AM | #1106 | |
Rep 5
08-09-2022, 06:30 PM | #1108 |
Rep 5
Have spent a while trying to code things and can't get it to work. CD Changer is enabled and everything looks like it should but nada... Anyone know of any good coders in the South West of England?..
georgebmwM3312.50 |
08-10-2022, 03:28 AM | #1109 |
47
Rep 56
I’ve secured the most cable, now no movement at all. I’ve used cable/zip ties. My clicking noise seems to have improved but not gone completely. Clicking is much less frequent.
Support did get back to me and are looking further into the issue. I had both a preorder unit and a replacement unit, both have the same issue. I still suspect the most connector in the unit has some sort of issue. The securing method may help but it does not completely resolve. |
08-10-2022, 07:12 AM | #1110 | |
Rep 3,997
08-10-2022, 12:41 PM | #1111 | |
Pingu
239
Rep 486
The connectors or something in the fiber connections are faulty. This is a defective product. I hope the vendor will address the issue. |
08-10-2022, 12:43 PM | #1112 | |
Rep 3,997
08-10-2022, 12:48 PM | #1113 |
14
Rep 16
FWIW, I have the new P2000 unit and all my MOST connections clicked in securely. I didn't even consider the possibility of it not being a secure fit.
Did you check if the cable isn't kinked or loose on the other 2 ends? |
08-10-2022, 12:58 PM | #1114 |
Pingu
239
Rep 486
They're all good. This problem is widely documented in this thread. There's a guy a few posts back who joined from the porsche forum to say this issue is widespread over there. It's not just me, but I appreciate the insight.
They're all good. Move the MOST connector around on the end that plugs into the blue box itself. It has more play in it than it should. Lots of folks have posted about it. |
08-14-2022, 10:45 PM | #1115 | |
313
Rep 309
Drives: 2008 BMW M3
08-14-2022, 11:02 PM | #1116 | |
Rep 1,073
This may just be a coincidence, but my unit was also a pre-order. I've tried to listen for this issue, and I seemingly don't have it. The behavior isn't any different than the original p2000. |
08-15-2022, 05:13 AM | #1117 |
Rep 11
So I posted earlier about how securing the connector (with floss!) improved things for me.
An update: I'm finding now that there is still some crackling noise, and at times I lose the fibre-optic connection completely, which stops the P2000 interface from working at all. When I tried to re-seat the connector and tighten it again I found it very hard to get into a position where it would be stable. I tried cable ties and even just holding the connector down hard to test if it would work. From my testing it seems when you move the fibre-optic line that brings the signal IN you get all the problems. The fibre-optic line that takes the signal OUT from the P2000 seems to be able to move without much issues. I've tried modifying the plastic housing of the connector to make it tighter, or to make the gap between the fibre-optic lines smaller and it's still very temperamental. I've also tried a different new fibre-optic cable completely. I'm convinced that some P2000s have a bad MOST female socket connector... The reason I say this is because I have a 2x P2000 units for an Audi (first unit had no bluetooth and I got a replacement), and I don't see how the MOST connection is significantly better there, yet they work perfectly. My Audi units were pre-order too, but coincidence? |
08-16-2022, 10:10 AM | #1118 | |
Pingu
239
Rep 486
08-16-2022, 02:25 PM | #1119 |
Pingu
239
Rep 486
Yeah now getting MOST ring break errors in code scanner. This MOST splitter harness is junk. I found these are sold on eBay/Amazon/all over the internet by what looks like the same manufacturer so I don’t think mr12volt actually built this component. But it is odd the one guy says his Audi box doesn’t have this problem because they all use the same MOST splitter.
08-16-2022, 04:47 PM | #1120 | |
47
Rep 56
For example the new CIC DSP socket is different to the one on the older cic lights hardware version that did not have the problem, see one of my previous posts. |
08-16-2022, 07:01 PM | #1121 |
14
Rep 295
For me the factory mic somehow works for taking calls. I didn't have to change any settings. I did plug in the provided mic, but when I put it in the cigarette lighter tray and close the lid, to my surprise I was still able to talk on the phone!
08-17-2022, 12:21 AM | #1122 |
Pingu
239
Rep 486
Def noticed over the years that vendors on these forums tend to get away with a lot for whatever reason (maybe due to vendor sponsorships and the moderator censorship that comes with that) and folks don't seem to push back when a product is questionable or at worst, faulty.
I find this clipping/popping really irritating and it annoys the shit out of my wife, because it sounds like rocks hitting the windshield when you're at speed. The Carplay interface is nice of course, but that is the same utility provided by every other Carplay interface available for this platform. The audio side is what I would assume attracted most people to this device, but with the MOST bus interruptions it is bordering ununsable. Since a few people chimed in that this topic was being discussed on the Porsche forums, I checked out the threads over there. We have not been as pushy and demanding as the Porsche folks have and I found two threads detailing the issue and the demand that was made to the vendor that it be fixed. https://rennlist.com/forums/porsche-...l#post18301184 https://www.macanforum.com/threads/m...4#post-2714169 Those are the specific posts but others chimed in as well. Apparently mr12volt are well aware of the issue and are targetting an early September fix, so we will see. |
