06-15-2023, 08:48 AM | #11815 |
Rep 17
Just installed the DroidUK product. All seems pretty good but one main gripe is the "ok google" seems to barely pick up my voice, I practically have to shout for it to detect and then it clearly can't hear me properly. It's like it's not using the car microphone for that. Any chance this is true? In which case what would it be using, my phone microphone maybe? Anyone else had this?
thanks |
06-16-2023, 06:31 AM | #11816 |
Rep 4
Hi All,
I'll leave this link here in case anyone needs it. Andream just replied to my message. Download link(v3.6.0.5.gpe.b2): https://mega.nz/file/udp3BKLR#Pvz5Oz...NbnRK_28isiFHk |
06-17-2023, 10:33 AM | #11817 |
Rep 2
Black Screen : 2014 BMW X3 (F25) NBT
Problem: The CarPlay interface now just displays a black screen
Background:
Current Status:
What works:
What doesnt work:
Questions:
06-18-2023, 09:18 AM | #11818 | |
Rep 25
06-19-2023, 01:34 AM | #11819 | |
Rep 15
This is most likely a problem with the microphone. You first need to know if the device has a built-in microphone, or whether it supports an external microphone. Maybe so Google can hear you. Of course, if your car has original car bluetooth, you can try it with the original car microphone, but I don't know if it will work. Maybe you can ask the seller if it supports it. I'm using andream's device, I guess this should be about the same. Hope this helps you. |
06-19-2023, 07:44 AM | #11820 |
Rep 101
Drives: 2017 430i coupe M package 6 sp
Is there a non-Chinese made option for the box? Really don’t want to install Chinese electronics
06-19-2023, 09:10 AM | #11821 |
127
Rep 339
To be honest with you, almost ALL second generation electronics or any that are sold at a substancial discount are Chinese made hardware. Unfortunately due to the global supply chain, there is no way around this. Coperations will always look towards cheaper and cheaper manufacturers of their products. And unfortunately, in reality you can't get much cheaper.
06-20-2023, 03:42 AM | #11822 | |
Rep 26
2. Same like above. 3. This is normal. |
06-20-2023, 04:07 AM | #11823 |
15
Rep 71
06-20-2023, 08:29 AM | #11824 |
Rep 25
Does anyone have issues with their MMI fitted to a retrofitted CIC? I retrofitted a CIC unit and it all works fine, I wired the CID and controller directly to the quadlock. When I add the MMI, sometimes on startup the controller does not work and the MMI gives a CAN error, then after a few minutes it all starts working.
Does it matter where they are wired into the canbus? I've checked all the wiring and can't find an issues, idrive works fine on it's own, I was leading towards and issue with my MMI, but was wondering if I need to relocate my canbus connections from the quadlock? |
06-20-2023, 02:59 PM | #11825 |
Rep 14
Hello everyone. I have a problem with the sos system. There is an error on the board. Below are the errors that I can't remove:
B7F337 - microphone error B7F8C3 - head to cid. Connection error B7F8CB - CID My ver. mmi: MCU Version 20.10.10.110 |
06-20-2023, 03:08 PM | #11826 | |
Rep 818
i don’t have any sos error |
06-20-2023, 03:14 PM | #11827 | |
Rep 14
06-20-2023, 03:16 PM | #11828 |
Rep 818
if you remove the mmi box, does it go away? you didn’t post what box you have, just mcu which doesn’t help anyone.
remove box, chk if error goes away then re-install box. the mcu/firmware has nothing to do with this error. |
06-20-2023, 03:30 PM | #11829 | |
Rep 14
CUST Version: EW_B2_1.6.9R3_n MCU Version: 22.10.10.110 HW Version: B_N2_1_G I have two microphones in the car. I connected the cables to microphone No. 1 (driver). I think an error is generated here. |
06-20-2023, 03:37 PM | #11830 | |
Rep 818
i’d connect the microphone how it was. that cable that comes with the device for the mic is not needed. at least wasnt for my NBT (2016). |
06-20-2023, 03:47 PM | #11831 |
Rep 14
I have a nbt, car from 2014.
06-20-2023, 03:48 PM | #11832 |
Rep 818
06-20-2023, 07:02 PM | #11833 | |
52
Rep 48
You can try to turn off the Can protocol in the settings. |
fe7565557.50 |
06-20-2023, 09:19 PM | #11834 |
Rep 6
Hello, some cars should not be connected to the microphone adapter cable, but if you connect it, the sos problem will occur. There is also the problem that the fiber optic cable is not connected properly. Please disconnect the microphone adapter cable and check the connection of the optical fiber cable.
06-20-2023, 11:54 PM | #11835 | |
Rep 14
06-21-2023, 05:53 AM | #11836 | |
Rep 14
MCU NBT : https://drive.google.com/file/d/1rqz...ew?usp=sharing I'm afraid this is older software. The seller does not guarantee that the error will disappear. |
andream, android, android auto, apple, carplay, mmi, retrofit |
