11-13-2018, 12:06 PM | #1189 |
98
Rep 118
From what you guys have said it seems that 18x9 ET30 front/rear should work on my 435 xdrive on stock suspension. The difference in opinion seems to be tire sizes, anywhere from 235-255/40. I'm planning on running a winter setup with winter performance tires. I'm not buying APEX wheels but I was told by APEX that fitment will depend on tire compound and brand.
11-14-2018, 12:15 AM | #1190 | |
42
Rep 126
f32ftw98.00 |
11-15-2018, 07:55 AM | #1191 |
Rep 969
Can I post here now?
11-15-2018, 06:19 PM | #1192 |
Rep 1,288
Drives: 2014 435iX, FBO
umm... that is staggered.. not square.
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S |
11-15-2018, 09:55 PM | #1193 |
42
Rep 126
11-16-2018, 08:06 AM | #1194 | |
Rep 1,288
The issue is that this will change your height ratio to a non standard size on 1 axle. See this thread I did way back which is a compilation of many other people's work in 1 spot. Certainly for X drive this is not a good setup, but I don't know if you are xdrive - suspect not. This should show you what I am saying, but it assumes that you are putting the tires on the right width of rims. (IE: a 245 on a 8.5" and a 265 on at least a 9" wide). I think this will negatively affect your handling. https://f30.bimmerpost.com/forums/sh....php?t=1479508
11-26-2018, 08:12 AM | #1195 |
42
Rep 34
Drives: 2013 BMW 328i M-Sport
Greetings everyone...
Here is my current set-up... - BC coilovers (extreme low kit) w/ swift springs (F)14K - (R)18K - CCW LM20, Polished w/ Gold ARP hardware - (Front)18x10.5, +6 (A), 215/40/18 - (Rear) 18x11, +20 (O), 245/35/18 - Megan Racing Rear Camber Arm(s) (Front upper & Rear/Upper) ** No pull or rolled fenders Last edited by Spanky_F30; 01-13-2019 at 05:44 AM.. Reason: Additional info.. |
kedafoe61.50 awmenard142.00 Tirkos13.50 335JTSD21.50 F30_SixSpeed1170.50 cdwalls704.00 stickman130933.00 Stlthnmrdrd156.50 |
11-27-2018, 01:03 PM | #1196 |
1046
Rep 2,153
11-27-2018, 01:13 PM | #1197 |
142
Rep 322
I'm looking to fit 10.5 all around with a +30 offset, seems like it should work based on your specs. |
11-27-2018, 02:38 PM | #1200 |
1046
Rep 2,153
you're not going to have inner clearance on 10.5 +30 up front.
11-27-2018, 08:43 PM | #1201 |
142
Rep 322
Do you think spacer could help?
11-28-2018, 01:24 AM | #1202 |
1046
Rep 2,153
I mean yea... or you can get correct fitting wheels in the first place.
11-28-2018, 07:02 AM | #1203 |
Cheapskate
4464
Rep 4,995
11-29-2018, 09:26 AM | #1204 |
Rep 969
12-01-2018, 10:24 PM | #1205 |
67
Rep 43
Some awesome pics in here guys! I just got my 2014 335i and was looking at a set of 19x9.5 +35 front and 19x11 +45 rear. What do you guys think? A little bit of stretch, dropped on coils and fender roll? Should be able to work without a problem from what ive seen in this thread.
Also whats your guys' opinion on having wheels professionally re drilled at a shop to fit our bolt pattern? Any have any experience with this? |
12-05-2018, 12:31 PM | #1206 | |
1046
Rep 2,153
12-05-2018, 06:36 PM | #1207 |
67
Rep 43
well if its the inner clearance thats the problem i could always use a 5mm spacer. I was more worried the outside would be too aggressive but from what i read in this thread seems like people have done it.
12-06-2018, 11:27 AM | #1208 |
1046
Rep 2,153
what's up with everyone wanting to use a spacer? get correct fitting wheels so that you don't need to use spacers??
12-06-2018, 02:10 PM | #1209 |
67
Rep 43
Whats wrong with using a spacer? Its either buy 2000$ set of premade wheels and throw a $50 spacer on or spend close to $4000 on wheels with custom width and offset...If you know of any wheels 19x9.5 front 19x11 rear with bmw bolt pattern that are 2k or less do let me know.
12-06-2018, 02:25 PM | #1210 | |
1046
Rep 2,153
aggressive, f30, low, slammed, stance |
