08-28-2020, 01:52 PM | #1211 | |
1050
Rep 2,370
Drives: E63 645Ci
08-28-2020, 06:38 PM | #1212 | |
74
Rep 237
RedErik1050.00 |
08-28-2020, 09:35 PM | #1213 |
Rep 7
Hey guys I need help and i cant make a thread yet idk how im new but I have one question, I have a 320i 2014, and it seems that I have an Entry NBT system, would i be able to still get an 10.25 android screen for NBT with no issues? or would I have to do something to the headunit?
08-28-2020, 09:37 PM | #1214 | |
Rep 7
08-28-2020, 10:13 PM | #1215 |
Rep 5
Don't know if this was posted before but I tried searching and did not find anything. Just picked up a new unit and the problems I have are
When I switch to the BMW UI and try to play music from my phone it plays for a few seconds then pauses by itself. I can unpause it but it will happen again after a few seconds. Nav and radio works well. Second is when I try to switch back to Android side bluetooth is disconnected and when I try to manually connect nothing happens. I have to reboot the unit for it to manually pair itself. It is a SD625 4GB/64GB unit. Any help would be greatly appreciated. Thank you! |
08-30-2020, 01:04 PM | #1216 |
Rep 4
Hi people,
2 days ago I finally got an android unit for my F31, now I have an issue with audio quality coming from the android side (when I listen thru the Idrive it sounds great) but thru the aux-in it sounds muffled, no bass, and a little "noise" that sounds like static, I've messed with volume @android side & Idrive and the static is barely noticeable now, but the lack of bass and poor quality overall still remains. I had to run a jack cable to the aux-in in the armrest because there was no sound even though the fiber optic cables were plugged to the quadlock of the android system. Anyone has got this problem and maybe have a solution? Some people said to remove the 4pin plug from the aux-in, but I'm using it (maybe remove 1 or 2 pins but not the ones needed for the sound?) I'm running OS version 1.8.2 and MCU Version 41587dLZH-NBT dated 200617 Thank you! |
08-31-2020, 10:24 AM | #1217 | ||
134
Rep 399
08-31-2020, 07:35 PM | #1218 | |
Rep 4
Can you provide a link for that cable you mention? Thank you so much! |
09-01-2020, 06:51 AM | #1219 |
Rep 210
I just received the package with navifly 4g/64gb with built-in carplay and blue anti-glare 1920 screen. I noticed that in the canbus cable there is a speaker connected and also there is a separate microphone. My current Android 7.1.1 works without external microphone or speaker. Do you know if I should leave them connected?
09-01-2020, 06:56 AM | #1220 | |
1050
Rep 2,370
Drives: E63 645Ci
As for the external microphone - use that. It will be much better than the built-in one. The built-in one is just crap... the crappiest crap of craps |
mike7810.50 |
09-01-2020, 07:02 AM | #1221 | |
Rep 210
I have always the voice guide turned off, so will not use it. Thanx for the detailed description.
Regarding microphone, I use microphone only when using my iphone to talk through bmw bluetooth. In that case, I think it is used the bmw microphone right? I dont know if through carplay, Android uses its own microphone though... (I rarely use the google maps microphone function to say a road) Quote:
09-01-2020, 08:11 AM | #1222 | |
1050
Rep 2,370
Drives: E63 645Ci
09-01-2020, 09:47 AM | #1224 |
1050
Rep 2,370
Drives: E63 645Ci
09-01-2020, 11:34 AM | #1225 |
Rep 425
Ok Guys. Firstly thanks for all the help and guides listed in this thread and the links etc.
I've gone from not having a clue to having my unit exactly the way I want it with a custom splash screen and customer ID6 tiles linking to the apps I want. Had everything working perfectly UNTIL hald an hour ago. Autokit gives me a black screen and immediately exits. Tried rebooting but the same thing happens. Has anyone had this before? Know how to fix it? |
09-01-2020, 12:34 PM | #1226 | |
Rep 425
09-01-2020, 02:47 PM | #1227 | |
134
Rep 399
09-01-2020, 04:54 PM | #1228 |
Rep 210
I in the middle of installation. Anyone knows the pass for factory menu?
BMW G30 530e M Sport (2019)
ID7 - 12Kwh Battery Remapped to 388hp/644.9N.m KN Filter |
09-01-2020, 05:03 PM | #1229 |
1050
Rep 2,370
Drives: E63 645Ci
09-01-2020, 05:15 PM | #1230 | |
Rep 210
09-01-2020, 06:18 PM | #1231 |
Rep 210
Anyone with navifly and front camera. I have connected the camera in dvr video in but no signal on dvr app. When I connect the front camera rca to rear camera connector it shows fine.
Any ideas?
09-02-2020, 01:13 AM | #1232 |
Rep 210
Also, I have another problem with navifly. I cant get my dvb-t2 to work. Actually I dont know where to connect the following connector
because this leads to white connector for screen connection. But navifly already has a cable with the same white connector which contains only rca inputs... the tuner does not came with remote control, tv control was done by touch screen and a tv app in android... The ugode dvb-t2 tuner was working in Android 7.1.1 screen from ugode. Any ideas? |
