08-07-2012, 06:21 PM | #111 |
Rep 536
08 MR E92 M3
255/30/20 f - 305/25/20 b. 9.5/11.5 Klassen wheels. No rub at all even with 4 people and 150lbs of luggage in car. Can anyone help me out if I can put 325/30/20 in the back. I am not lowered. 305 is not enough tire for 11.5 or is there a fatter tire that comes in 305 than hankooks except ps2's? I wanted to put 265/30/20 and 325/30/20 dunlop sport max gt's. Front should be ok but I m worried about back. Help me out pls? |
08-09-2012, 02:21 PM | #112 |
182
Rep 388
Maybe I'm missing something, why do you want such huge wheels? What is the point, your killing the car both performance wise and handling.
08-10-2012, 12:45 PM | #113 |
Rep 536
Lol. No man. I have my oem set for track. The overall weight for these is only 20 pounds more than oem. Tire weight would be another 10 pounds. So 30 pounds on 4500 pound car doesn't make a difference in everyday driving. I mean its not like you drive the car aggressive all day long. So u don need super performance during dd. The sole reason is to protect my rims cuz I got a curb rash on one already! Damm! I just wanna put 30 series so its a bit for comfy for dd. And 19" on this car are small unless u drop it which I do not want to do. And I think you r missing out but most m3's have 20's
08-19-2012, 02:27 PM | #114 |
32
Rep 126
I am interested in buying my buddies used Blizzaks for a really good deal. But concerned the front will rub.
2009 e92 M3 Wheels: 220M Suspension: Stock Tires: LM60 245/40/19 Front 275/35/19 Rear Front tires have about 9/32 tread left. Thanks for the input! |
08-19-2012, 07:34 PM | #115 | |
Rep 547
Adding 30lbs to your unsprung weight can place more stress on your handling, braking, and acceleration. With an extra 30lbs you probably lost 0.5 - 1 second of acceleration (1 second is drastic). I know it doesn't seem like much but just throwing it out there.
2008 E90 M3: Alpine White/ Fox Red Novillo/ Brushed Aluminum | 6MT | Premium | Cold Weather | Technology | EPS | PDC | Ipod/USB |
Fuelly :: Adelei's Gas Mileage |
08-23-2012, 02:56 PM | #116 |
32
Rep 126
08-25-2012, 08:34 AM | #118 |
36
Rep 368
Car: 09 E90
Wheels: OEM 220M Spacers: TMS 15mm (F) / 12.5mm (R) Tires / Miles: OE Continental Contisport Contact 3 - (F) 245/35/19, (R) 265/35/19 Suspension: KW V3 lowered about 1.2" all around EDC Setting: N/A Alignment: Just lowered on KW V3's, going to the alignment shop today Fender Modifications: trimmed rear fender liner on both sides due to rubbing. Also trimmed the plastic tab behind the passenger side fender liner. Rubbing?: Front passenger side tire touches the fender liner slightly when front wheels are turned almost all the way to the right. Not a big deal since I hardly make U-turns going clockwise.
09-11-2012, 08:56 PM | #119 |
Rep 49
hi, im looking to rub 295 on my car is well with a wheel that has the same offset as yours in the rear, what do you mean by the plastic nub? does it actually hit the part of the fender that is painted? does it cause any visual damage or anything like that and has it gone away? sorry for all the questions but im new to this and thought you might know the answers considering your situation thanks alot
09-18-2012, 01:51 AM | #120 |
Rep 50
I have 220M (stock suspension, w/ EDC, no spacers) and just about to get a new tire set. I was thinking going with PSS but also wanted to go bit bigger in tire size if possible.
what would work on these? highest tire size for front and rear that will give me no rub at all. Thanks all for your input.
2008 M3 coupe - DCT & EDC, AA
10-05-2012, 08:48 AM | #121 |
14
Rep 212
wow great information. I m in the process of buying some wheels and just dont know what size.
I am getting. BBS LM- here are my size choices; 19x9.5 with +34 or 20+ REAR 19x11 +25 i dont know tire choice what will work? other option is to change rear to 19x10.5 +22 Whst tire size can i do?? THANKS! |
11-28-2012, 05:17 PM | #123 |
Rep 137
12-04-2012, 07:46 AM | #124 | |
Rep 1,278
i'd run a spacer up front and then it would look perfect.
PAST 2007 Black Sapphire E90 335i, 2010 Jerez Black E92 M3, 2012 Mineral White E92 M3, 2013 Singapore Grey F10 M5, 2016 Azurite Black F80 M3,
CURRENT 2017 Oxford White GT350 |
12-05-2012, 06:07 PM | #125 |
DHS
229
Rep 4,043
Drives: 2023 M4, 2020 Land Rover
Car: E92 M3
Wheels: Original Volk TE37 18 inch Spacers: None Tires / Miles: Hankook V12's, 265/35/18 and 285/35/18 Suspension: H&R/Swift EDC Setting: N/A Fender Modifications: None Rubbing?: None
2020 Land Rover Velar Autobiography
2023 BMW M4 2016 X3 |
12-22-2012, 05:09 AM | #126 |
Rep 1,376
I have HRE p43sc on order and I'm debating what size tires to go with I'm putting them on an e90.. (F) 19x9.0 ET 22 (R) 19x10.5 ET 27. I was thinking of putting on PSS and sizes F 255/35 R 285/35.. Do you guys think I'd rub? My suspension is currently stock.. I wanna try and stick with a 35 profile I don't like thin profiles. Any thoughts?
12-26-2012, 12:50 PM | #127 | |
Rep 1,130
However I would go 9.5 front and 10.5 rear to maintain the OEM 1" stagger and size your tires accordingly to maintain the OEM 20mm stagger. If you decide to go with a 295 rear I would recommend running an 11" wheel as the 295 looks very square on a 10.5" wheel and you need to sacrifice some offset due to this. |
12-26-2012, 05:42 PM | #128 | |
Rep 1,376
I was afraid of doing a 9.5 in the front i thought id def rub. Well I ordered the rims already so it's too late :/ what are the down sides of being more than 1 in? It was actually recommended.. I just checked your right they don't make it in a 285. So should I go 275 or 295? Wouldn't a 295 rub thought?
2018 F80 M3 ZCP Mineral White- Extended Shakir Orange - Full Suntek Ultra Wrapped - ///M Performance Spoiler - RKP Front Lip - RKP Side Skirts - Vorsteiner GTS Diffuser -AA Mid-Pipe-///M performance HAS kit - HRE P101
11 E90 M3 JEREZ BLK METALLIC ZCP SOLD |
12-28-2012, 12:23 AM | #129 | |
Rep 1,130
I tried running 295/35/19 PSS but at ET 22 there was rubbing. I believe ET 27-28 will work with the 295 wide rear, however I would search the forums to double check. |
12-28-2012, 04:27 PM | #130 | |
Rep 1,376
12-28-2012, 05:54 PM | #131 |
314
Rep 359
Another input for the "database"
What won't rub - even on the track 265/35-18 Michelin Pilot Cup tires on all 4 corners FRONT: 9,5x18 ET23 w 10mm spacer which results in an ET13 REAR: 9,5x18 ET23 w 15mm spacer which results in an ET8 here's a picture of how it looks
01-18-2013, 10:39 PM | #132 | ||
Rep 1,376
How is that these guys have the same wheel size in the from with similar off sets one rubs the other doesn't?? Bc I have an e90 and I'm trying to do a 255/35 in the front with a ET 22 and people are saying I will rub?? Any thoughts?
