07-22-2021, 02:10 AM | #111 | |
Rep 984
07-22-2021, 09:42 AM | #112 | ||
Rep 1,009
Pure F82
Commanderwiggin2056.00 |
07-22-2021, 10:15 AM | #113 | ||
Rep 1,204
575RWHP F87 M2C - ECUTEK RACEROM with flex fuel tuning by Bend Calibration 1000+RWHP E46 M3, Lab22 Built Turbo S54, Bend Calibration Tuned - BMW Half Mile Record Holder |
07-22-2021, 10:24 AM | #114 |
Rep 961
Will the stock tune run with these injectors for smog?
If it doesn't that blows as you'll have to reverse all that time/effort to stock, is my assumption correct?
M4CS Frozen Blue
ARM DP's/Resonated Mid-pipe | SPL links | Hotchkis bars | JRZ RS2/camber plates | K&N | Koyorad HX | Powerflex purple | Rouge | Spiegler | Speed Eng. snorkel | Vargas CBC/hub | Wagner IC | xHP | Xpel stealth ppf |
WarMachineM356.50 |
07-22-2021, 10:40 AM | #115 |
Rep 1,009
Injectors are still oem and should not have anything to do with emissions. Likewise for the tune, unless you have a decat/Stg2. Not sure about running these injectors with stock mapping long term as it would run rich.
Pure F82
WarMachineM356.50 |
07-22-2021, 12:00 PM | #116 |
Rep 961
Thanks Junkie lol. Just for smog that's it.
M4CS Frozen Blue
07-25-2021, 12:23 PM | #117 |
Rep 984
Thanks Commander!
Just to clarify on the whole procedure, so first I fit the EU5 injectors and then I load the Bend calibrations custom tune without turning on the car. Then I do the recalibration procedure through ISTA for the injectors and then I can turn on the car and do some pulls so I can log it to then send across to Ian for revisions? |
07-25-2021, 12:29 PM | #118 | |
Rep 552
Drives: 2018 M4 ZCP 6MT
My installer didn't have access to my BM3 account after calibrating the injectors, but was still able to drive around (nothing aggressive mind you) without any issues prior to loading the tune.
2018 F82 ZCP 6MT: FBO, Kratos KRAS55Bi, EU5 Injectors, Dorch HPFP Lift Kit, Stage 3 LPFP, Bend Calibration Zeitronix ECA-2, BM3 Flex-Fuel Tune by ABP
For Sale |
09-10-2021, 09:57 AM | #120 |
Rep 26
09-10-2021, 10:27 AM | #122 |
Rep 26
09-10-2021, 10:45 AM | #123 |
33
Rep 55
09-10-2021, 01:20 PM | #124 |
Rep 1,009
Only with meth, because you're not making 680whp on 93 alone
Pure F82
12-11-2022, 09:01 PM | #125 |
Rep 940
Hey guys, if i get the Eu5 injectors, will i be able to just select the EU5 injectors under map settings? Or will i need to contact my tuner to have all my custom tunes updated?
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
12-14-2022, 09:08 AM | #127 | |
Rep 937
He tuned my car with stock injectors and pure high flow turbos to 672 hp, If you include meth injection. |
12-17-2022, 11:22 AM | #128 |
Rep 1,074
I just wrapped up my Final revision with F80 paul for full e-85 stock injectors. So he would be able to code the new injectors in and have to retune it? Will it be able to push more power on the stock turbo?
Instagram: M2_Medusa
12-17-2022, 01:33 PM | #129 | |
Rep 5,203
If you did do the M5 injectors they should be coded and the small fuel adaptation setting reset. Make sure you have pictures of the flow numbers from the side of the injectors, and know which went where.
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
12-18-2022, 05:59 AM | #130 | |
Rep 1,074
I'm going to end up going to EU5 and lift kit eventually. Those two together can handle 700/650 upgraded turbos right?
12-18-2022, 06:11 PM | #131 |
Rep 5,203
That plus a Stg3.5 Brushless LPFP and you can get 700-800.
12-18-2022, 07:19 PM | #132 |
Rep 1,074
what brand
