BMW X3 Forum
BMW X3 Forum
      12-28-2012, 08:43 AM   #111
noka
Drives: 2013 x35i M-Sport
The trouble with the M-Mobility kit (I also had with my '03 M5) is that it expires after some time (2-4 yr?) and needs to be replaced, even if not used. Even if that were not true (e.g. some drugs can work well after expiration date), would you want to chance it when you need to depend on it? Also, although I never did get to use it, I heard it can really mess up the inside of the wheel, especially one with TPMS sensors. I also have AAA and the BMW Roadside Assistance (as you probably do as well). However... you might want to check out this thread if you have not already, w.r.t. towing/flatbedding the X3 (not related to a problem with a flat but just to be aware in case you find yourself without power/ignition):
http://x3.xbimmers.com/forums/showthread.php?t=649204
2013 x35i (Space Gray, MSport, CW/CWII, DHP, Premium, Premium Sound, Technology, BMW-Apps)
Retired: '09 C300 4Matic, '09 GTI, '06 750i, '05 C55, '04 R32, '03 M5, '02 GTI, '01 M5, '00 M-Coupe, '00 540i/6, '99 M3 Coupe, '98 M3 Coupe, '96 328i,... '86 4000 CS Quattro... too many to list.
      12-28-2012, 08:56 AM   #112
Rodion
Finland
27
Drives: X3 (F25)
Here is my humble winter set-up. Works like a charm. (sorry about big images)
A detailed view:
And general view:
      12-28-2012, 09:53 AM   #113
MJM
BMW CCA Boston Chapter - Member
MJM's Avatar
Drives: 2011 E90 M3, ZCP
Thanks noka, I am very familiar with what some call "Car Wash" mode of getting the transmission into neutral. (Not that any of my cars go through anything but a "Touch-free" car wash when its too cold to hand wash.)
I am also aware of the expiration dates for the mobility kits. Buy the time that happens, I will need new tires anyway, so a new can will be replaced at that time.
      12-28-2012, 10:19 AM   #114
Nahoa
Drives: F25 35i Mineral Silver/Black
A detailed view:
And general view:
The studded tires are a bit of overkill with so little snow, no?
      12-29-2012, 07:03 PM   #115
Harplayr
Drives: 2011 BMW X3 28i, F25
Originally Posted by walendvay View Post
I use nokian Hakka 7 run flat. 225/60-17. I find the performance on ice packed roads to be amazing! They are on a set of dedicated Borbet wheels from my old E83.
I've got a set of Borbet wheels from my old E83. Do these fit the F25 without any modifications?
I was planning on selling them and getting a new set of wheels for the F25, but if these will work then I just saved a lot of money.
      01-29-2014, 05:07 PM   #116
335xs2dinan
335xs2dinan's Avatar
141
Drives: 08 E92 335xi, 22 G80 M3
Originally Posted by E92LNGCGY View Post
I actually went with a narrower tire (225/50/18) they recommend the 235's.
how did this narrower tire work out for you? just picked up an X3 35i and wanted to go narrower but tirerack telling me that they didnt recommend it though they didnt really explain why. i was looking at 225/55/R18 Latitude Alpins and couldnt find a reason why this wouldnt work when 225s are a recommended size for 17 inch wheels? anyone know if it will be okay to order the 225/55R18?
      01-29-2014, 06:24 PM   #117
E92LNGCGY
Drives: F97/Q5/982 GT4
It is great. I think the only reason they are not recommending 225 is because of the lower contact patch but there is absolutely no issues at all.
      01-29-2014, 06:34 PM   #118
northX3
29
Drives: 2011 X3 35i
Studs are not really meant for snow. They are there for the ice underneath. Cold, wind and snow ends up making a nice slippery ice layer over the tarmac.
I have studded Hakka 7, and I live in Quebec, so I understand the need to have studs. The difference between studded and stud less Hakka 7s (tried both) is to be tried to believe !
      01-30-2014, 03:16 PM   #119
335xs2dinan
141
Okay great thank you for the quick reply! they told me the handling would be poor with them but im going to go push forward with this size now.
xbimmers
