04-16-2016, 07:06 PM | #111 |
Rep 682
Is this something that can be ordered for PIA?
2017 440i Gran Coupe xDrive MPPSK M-Sport Estoril Blue II w/ Individual Golden Brown Full Merino & Fineline Anthracite Wood
Track Handling + Premium + Cold Weather + Technology + Driver Assistance Packages |
04-17-2016, 03:41 PM | #112 | |
Rep 3,071
04-17-2016, 06:36 PM | #113 |
Rep 682
Sad. I'm actually surprised not more people on the forums have the MPerf LSDs, was trying to figure out if it was because it didn't look like a PIA item.
04-17-2016, 08:34 PM | #114 |
Rep 4,321
Port installed yes,
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
04-29-2016, 10:11 PM | #115 |
Rep 10,394
Simple answer. It's not a cosmetic (visual/auditory) modification and it's expensive.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
04-30-2016, 12:02 PM | #116 | |
Rep 4,321
Not necessarily needed on the street....
05-01-2016, 04:48 PM | #117 |
Rep 902
Drives: 13' F30 385xi VNV Speed Custom
Garage List 2013 Mercedes SL63 ... [0.00]
2010 VW Tiguan 2.0 ... [0.00] 2015 Tesla P85D [0.00] 2014 Mercedes S63 AMG [0.00] 2007 Mercedes GL450 [0.00] 1967 Ford Mustang [0.00] 2013 BMW F30 335xi [0.00] |
How many people with xDrive have gone for an LSD either M-Performance or Quafie? It's probably the next thing I'll spring for and have gotten little feedback from other xDrive owners. Anyone have a review or experience with it.
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
05-13-2016, 07:26 AM | #118 | |
Rep 681
Really really satisfied! Now the handling is more similar to a RWD but with the grat traction of the AWD!
BMW M3 G80 Isle of Man
05-13-2016, 08:54 AM | #119 |
Rep 469
Sounds like a good combo
DD: F48 X1 xDrive25i '20 - https://f48.bimmerpost.com/forums/sh....php?t=1703083
For fun: F22 M240i '19 - https://www.2addicts.com/forums/show....php?t=1644646 Previous BMW: Fully loaded F30, 335i https://f30.bimmerpost.com/forums/sh....php?t=1681247 |
05-13-2016, 09:13 AM | #120 | |
Rep 4,321
05-13-2016, 10:19 AM | #121 |
Rep 3,958
Which gear oil to use?
Documents of Main group 33 from ISTA+ attached.
What type gear oil would the M Performance LSD use compared to the standard open rear differential? |
05-14-2016, 09:39 AM | #122 | |
Rep 584
05-15-2016, 07:29 PM | #123 |
Rep 10,394
Castrol SAF-XJ aka Castrol Syntrax Limited Slip 75W 140
05-20-2016, 08:33 AM | #124 |
Rep 4,321
BMW told me there is no need to change the oil (or even a way to change it) for this LSD.
Boostinwithfish12.00 |
05-20-2016, 09:34 AM | #125 |
Rep 3,958
You would have to extract it with a vaccuum pump. Or you may be able to open up the rear cover after removing it.
05-25-2016, 08:25 PM | #126 | |
Rep 10,394
They may suggest something like 4 yrs for occasional (2-3x/yr) track use. Hint.
05-26-2016, 08:43 AM | #127 | |
Rep 3,958
The follow-on questions would be what's a streetable lockup %? There seems to be a lot of posts in a variety of forums that say 40% is about the upper limit, but there's less consensus on lockup % during decel/coast. Last edited by Polo08816; 05-26-2016 at 09:00 AM.. |
05-28-2016, 12:10 PM | #128 |
Rep 3,958
DIY tools question...
I'm wondering if anyone has done removing/installing the rear diff themselves and can comment on the special tools required for the job.
1. Does the exhaust system need to be removed in order to do swap out the rear diff? It seems like ISTA+ has you remove the complete exhaust system in order to disconnect the main drive shaft. 2. What tool (or alternative tool) did you use to get the left and right axles off? Pictures attached. |
05-31-2016, 08:17 PM | #129 | |
Rep 3,958
05-31-2016, 11:31 PM | #130 | ||
Rep 1,349
Drives: BMW F80 M3
06-01-2016, 01:12 PM | #131 |
Rep 3,958
If you would, that would be great.
I'm just wondering if one or two pry bars would be sufficient. https://www.ecstuning.com/Search/Sit...Bar/ES1899378/ The BMW 33 5 120 tool set costs about $750-800. Pretty expensive for what is basically a pry bar. |
06-01-2016, 01:34 PM | #132 | |
Rep 1,349
Drives: BMW F80 M3
