06-09-2022, 08:15 PM | #111 |
262
Rep 335
Holy shhhhhhhheeeeet that looks incredible. Especially since you can compare it to drivers side right there… the F83 seats just look so damn good!! Amazing work… can’t wait to see how you got it all to work.
Gone but not forgotten: 2005 X3 2.5 6spd, 2011 X5 50i, 2015 328d Wagon |
brettcp348.00 |
06-09-2022, 10:08 PM | #112 |
Rep 705
Thanks! Here's another angle.
06-13-2022, 02:00 PM | #113 | |
354
Rep 207
-2007 Z4M - Interlagos Blue
-2008 E90 M3 - Interlagos Blue, 6MT, slicktop -2020 X3MC - Phytonic Blue |
06-13-2022, 02:13 PM | #114 |
Rep 705
In my case, the illuminated headrest badge is pin 7 on the F8x seat wiring harness connector. I took lots of pics through my process. The color of this wire may be different in your case. I simply used a piece of wire to tap this pin 7 wire into the footwell light. Works perfect.
CTMike262.00 |
06-15-2022, 07:37 PM | #115 |
Rep 705
Got the driver's seat installed and everything finished today. Very happy with the results! No errors, only had to code a few items. I took a lot of notes, will put it all together in a guide sometime soon and post it.
06-15-2022, 08:34 PM | #116 |
Derbo Tuning
3613
Rep 3,031
did you use the E93 modules?
IG:ruhrohz_m3
Journal: Link E9x ZCP Suspension Info: Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services |
06-15-2022, 09:51 PM | #117 |
Rep 705
Yes, I moved the E93 modules over to the F83 seats. They were a direct swap, plug and play. The wiring harnesses is where the pin swapping is done. Everything works as expected - all seat movements, heat, lumbar/side bolsters, seat memory, buckle detection, and the headrest badges illuminate.
06-24-2022, 12:30 AM | #118 |
Rep 843
Has anyone been able to get in contact with the OP? Trying to purchase a rear seat bracket kit from him. Looks like he hasn't been on the forum for a few months. No reply to PM. Any help appreciated - thanks!
EDIT: think I've found his number and company
E90 M3 | Interlagos Blue Slicktop | DCT
E92 M3 | Alpine White on Fox Red | 6MT Lexus ISF Lexus GS350 F-Sport Model Y Performance |
07-26-2022, 09:43 PM | #119 |
Rep 456
Drives: 2008 BMW e92 M3
Care to pass his info along. I'm looking to do this swap as well
07-26-2022, 09:46 PM | #120 | |
Rep 843
Here's the product page: https://rebooteng.com/?product=bmw-e...-seat-retrofit
07-27-2022, 09:10 PM | #121 | ||
Rep 456
07-27-2022, 09:31 PM | #122 | |||
Rep 843
07-28-2022, 09:35 AM | #123 | |
Rep 744
The way it works is the charge in the solenoid is connected to a simple sensor that is standard throughout the maker (every BMW I seen has the exact same sensor connection). You can grab a belt from any BMW and plug it in to any other BMW and the car will "recognize" it. So, if you were able to connect the yellow/orange male-female connectors between the seatbelt and the car, you have a working charged belt and in the even of a crash (God forbid) will set off the charge and lock you in place. No coding or anything like that is required. I have also swapped out a bunch of seat belts myself, on my own cars. Hope this helps!
M3 E93
PORSCHE MACAN S: SOLD BMW X3 F25: SOLD AUDI S4: SOLD BMW E92 335: SOLD |
07-29-2022, 11:35 AM | #124 |
Rep 843
07-30-2022, 08:00 AM | #125 |
Rep 456
07-30-2022, 10:59 AM | #126 |
Rep 843
Not sure. Will need OP to chime in
09-06-2022, 09:17 PM | #129 | |
Rep 705
I'll PM you what I did put together so far. Last edited by brettcp; 09-06-2022 at 09:24 PM.. |
CTMike262.00 |
09-07-2022, 03:53 PM | #130 |
Rep 3
Cool. I really appreciate it!
03-10-2023, 07:03 PM | #131 |
///M
95
Rep 254
About to install these and just wanted to confirm that for #4 of what you need - E9x spare set of yellow seat conn
Is that these? https://www.ebay.com/itm/23482026403...mis&media=COPY |
03-15-2023, 02:33 PM | #132 |
Rep 13
Hi! Can I ask, how much of a difference did this make in seating position? My biggest criticism of the E92 m3 is how high you sit, it doesn't feel like a sports car at all. Does swapping the F8x seat make a transformational change, or more of a small incremental improvement?
