Bmwhat app (Carly for BMW)
05-30-2018, 07:57 AM | #1299 |
18
Rep 54
So I've used Carly to code a few things over the last couple of days and it's mostly worked great. One thing I'm having trouble with though is getting rid of the seat belt chime. Ideally I'd like to keep the passenger side chime and just remove it for the drivers side so that it doesn't go off every time I start the car. I've tried a few times now coding for either side or both chimes to be removed but it never sticks. There are 3 options:
Seat belt warning • off • on Various settings for the seat belt warning. (codable in CSM) Seat belt reminder driver • off • on Seat belt reminder for driver is active/ inactive. (codable in CSM) Seat belt reminder passenger • off • on Seat belt reminder for passenger is active/ inactive. (codable in CSM) I've played around with the latter two and no dice, do I need to do the first option as well? What is the first option for? Any help is much appreciated. |
06-12-2018, 09:15 PM | #1301 | |
10
Rep 84
Is it worth it to buy the app? Seems like there's limited coding options. Any feedback much appreciated |
06-12-2018, 09:46 PM | #1302 |
Rep 10
06-12-2018, 09:57 PM | #1303 | |
10
Rep 84
http://support.mycarly.com/knowledge..._campaign=home |
07-06-2018, 03:36 AM | #1304 |
101
Rep 257
I have the full version of Carly for BMW because I bought it ages ago and I like it. It's enabled me to code things and fault find on my E90 and my wife's Mini R56. I wouldn't be as keen if I had to to pay for it annually though like you have to now.
If you have a windows laptop, you might as well buy a cable and learn how to use the software (although this is a much less user friendly option) and for some things you end up having to do this anyway. I recently purchased the full Carly for VAG app along with the "VAG Plus" Carly adaptor to do some coding and service resets on my parents cars (they are an Audi household) as I couldn't be bothered to learn how to do it with a cable and laptop. The functionality was shockingly poor (I can't even express how useless this is). I was trying to use it on an A3 and a Q3 and I found it of literally no use other than code reading. It couldn't even reset the service indicator. Take a look at Carista. It seems to be more keenly priced and seems to work well for BMW and VAG IME. |
litebulb68.00 |
07-06-2018, 11:53 AM | #1305 | |
45
Rep 303
08-03-2018, 10:50 PM | #1306 |
Rep 2
Can anyone tell me if this is possible in Carly?
Found in another non-Carly thread.
Carly has coding options to open windows etc with key fob, but I tried and it didn’t work. Can anyone tell me if this is possible to translate to Carly? _________________________________________________ E93 coded Key FOB to open/close windows/mirrors and convertible top I have sucessfully coded to my car with NCSexpert to enable the key FOB to open/close the windows/mirrors/convertible top!! There has been alot of people looking to code this feature in without Comfort Access! With Comfort Access this function was already set to work, but not such an easy task without CA! I have finally after many attempts got it to work and coded my car to operate that is not equipped with COMFORT ACCESS!!!!! Here are the modules and script lines that I had to change. I have the original software for my car as it has never been updated! I am not sure if this will work with newer cars with software upgrades, but please try and get back to me to see if this works for you! There are not too many people that have coded this feature to work to open and close the convertible hardtop, I hope this will help others. CAS MODULE (set both of these lines to aktiv) KOMFORTSCHLIESSUNG_FB FH_KOMFORTF_MIT_SUBST CTM MODULE (all of these lines need to be set to aktiv, some may already be set to aktiv!) I am not sure its the same with CVM module.. KOMFORT_OEFFNEN_FBD KOMFORT_LADE_POSITION KOMFORT_SCHLIESS_FBD SCHEIBEN_ANHEB_OEFF_FBD SCHEIBEN_ANHEB_SCHL_FBD NFRM MODULE SPIEGEL_KOMFORT_EINKLAPP or ASP_KOMFORT_EINKLAPP |
08-04-2018, 09:58 PM | #1307 |
Rep 17
I tried to read the live parameter gauge display and whenever I tap start, my engine runs erratically and the idle fluctuates. Have anyone experience this when logging?
I have JB4 installed. |
09-18-2018, 08:44 AM | #1309 | |
Rep 940
Edit: It worked! My car is a 2008, not sure of the build date, but I was able to code a couple things using the Carista app through the bluetooth OBD adapter I already had. I've tested the windows up with fob long press, mirror fold with fob long press, and I got the DRLs to be halos only, which is the main thing I was after in the first place. For a fully productive night, I also modded my headlight switch to get the rear fogs working. Anyone know what the tri-bar section of the taillights is called? I'd like to use that as a DRL and the Carista app details multiple sections of the taillight that can be used, but I don't know which to choose. PS: DO NOT follow the video guy's lead of using the HID headlights as 'approach lights' or whatever and have them come on gradually. Applying varying voltage to the ballasts is bad news, I tried this and thought I blew out a headlight, the system did NOT like it. I changed mine to come on immediately when the car is unlocked. Last edited by dcorn; 09-19-2018 at 07:58 AM.. |
bmwhat app, coding |
