03-21-2023, 12:51 PM | #1431 | |
138
Rep 294
Connect the power supply It is necessary to close the contact to the housing as indicated in the picture. And turn on the HU SD662 4/64 electrical board HU turn on in recovery mode Control - touch up down Confirm - continuous movement to the right Then you copy the firmware to the SD card. You can use 1.0.7 Nexai or try 1.2.1 Nexai. There is no need to rename the firmware. After that, in the recovery mode menu, select Apply update from the Sd card If neither one nor the second version of the firmware works the second option use 1.0.7 Nexai or try 1.2.1 Nexai 1) Download the firmware for the device and rename it to: Ksw-S-M600_OS_v-ota-only-reset-data_factory.zip 2) Format a flash drive or microSD memory card in FAT32 3) Set the volume name of the microSD card or flash drive: _KSWOTA_ 4) insert a flash drive or microSD card into the device and launch, and wait.... everything will be installed in 10 minutes, periodically the screen will blink and reboot, do not touch anything. After downloading, Android automatically creates a file in the root of the flash drive and changes the volume name to prevent recovery mode from looping. According to my observations, with the release of the latest firmware for A10, A11 and A12, the update order has become conditional. Someone had no problems updating A11 2.2.3 immediately to A12 1.0.7Nexai or higher. As well as the first A12 versions immediately on the last one, As well as the updated A10 to A10 3.9.4. As someone is lucky. And someone on the contrary, without the necessary order could not move forward. UPD: Especially happy users managed to trigger the recovery mode when the HU is turned on with the system loaded in a fairly simple way. Сopied the compressed config file in the Mac OS system to the OEM folder by standard means. Mac os creates temporary files by default when archiving. And somehow this causes an interesting reaction in some android. Last edited by Shamanix; 03-21-2023 at 03:10 PM.. |
03-21-2023, 01:12 PM | #1432 | |
138
Rep 294
If I were you, I would ask for a discount from your seller and update the firmware right during the installation of the HU in the car. Here is a detailed instruction https://hifimaxnavi.com/blogs/news/h...oid-navigation Firmware and config/OEM are the same for all manufacturers Only the MCU differ Last edited by Shamanix; 03-21-2023 at 01:19 PM.. |
kelly660.00 |
03-21-2023, 01:39 PM | #1433 |
Rep 15
03-21-2023, 01:56 PM | #1434 |
138
Rep 294
There is notification management in the settings. As well as the developer mode in android settings gives additional privileges. Disable in Advanced settings TXZAssistant
03-21-2023, 08:08 PM | #1435 |
Rep 15
03-21-2023, 08:27 PM | #1436 | |
Rep 54
So, I will ask them whether they can do this update at the time of installation. |
03-21-2023, 09:02 PM | #1437 | |
1050
Rep 2,369
Drives: E63 645Ci
kelly660.00 |
03-22-2023, 01:17 AM | #1438 |
138
Rep 294
03-22-2023, 01:42 AM | #1439 |
138
Rep 294
With all that he has said, I doubt he will do anything on his own with HU. And even more so when it is written on each column, you do the update at your own risk. In fact, he doesn't need anything else besides the camera.
kelly660.00 |
03-22-2023, 01:55 AM | #1440 |
1050
Rep 2,369
Drives: E63 645Ci
True, but still you don't need an installer whom you pay an hourly rate to just push a button for you. Besides if that is a genuine Android 12 unit there is no need to update anything, it just needs one line added to the factory_config.xml.
03-22-2023, 02:04 AM | #1441 | |
138
Rep 294
Meet https://wetransfer.com/downloads/219...2010238/aae9ac Android 12 1.3.0. Nexai |
RedErik1050.00 |
03-22-2023, 02:18 AM | #1442 |
Rep 18
can someone tell me if the devices have smart view/screen mirroring or a link to mirroring from devices for smartphones? If not, it would make more sense for me to upgrade to an original Bmw Id6 system with Smart View and Apple carplay. I have already retrofitted it to my F30 nbt evo but considering for my other car F31 with nbt. What is important for me is that it can be used a screen mirroring. Can someone check this in android 12 or 11 Systems. Thanks. Best regards
03-22-2023, 02:33 AM | #1443 | |
138
Rep 294
03-22-2023, 03:52 AM | #1444 | |
Rep 54
Moreover, with so many queries sent to the supplier, I doubt if they will respond now. As I mentioned to RedErik earlier, my 8" Tab is doing a decent job (see pics - day/night & 3 diff positions). My cousin is getting me the 5" monitor + camera from US in April 1st week (which I plan to keep near the ashtray - not sure if it will look good on the dash). Moreover, it will be always on (not connected to reverse light) for rear viewing. Any suggestions on where to position it is most welcome. I can still cancel that order if the supplier (EUROCARFIT) responds positively. Actually, their factory is also in China eventhough they have a Spore address on the website. So who knows.... |
03-22-2023, 04:22 AM | #1445 |
Rep 18
I spoke to some sellers from Alibaba, they said they don't have screen mirroring. Would it be possible to send me a picture to confirm? Are there different versions? Would it be possible to let me know where you bought it from?
03-22-2023, 04:51 AM | #1446 | |
1050
Rep 2,369
Drives: E63 645Ci
03-22-2023, 05:09 AM | #1447 | |
1050
Rep 2,369
Drives: E63 645Ci
Completely not my cup of tea, but as I said before, whatever floats your boat buddy. |
kelly660.00 |
03-22-2023, 08:48 AM | #1448 | |
Rep 54
The risk (hardware not software) I was referring to is buying the unit say Hifimax and doing the entire install by myself including prying open the facia,cables, etc. I remember seeing a video by Kies Motorsports with all those T20s, T30s, etc. I know you guys are there if I am stuck, but still... BTW, even if I have to buy from hifi...I didn't see an F30 LCI trunk handle camera for 2016 mfg. (https://hifimaxnavi.com/collections/car-camera) Do these guys have any periodic sale or coupon codes? I couldn't find any ALS version (https://hifimaxnavi.com/products/bmw...39463836516446) Moreover, I won't get warranty in India if I import. Would you recommend the 4/64 with ID8 and Android 12 from EUROCARFIT without seeing the system info screen? Last edited by kelly66; 03-22-2023 at 09:12 AM.. Reason: typo |
03-22-2023, 08:57 AM | #1449 |
1050
Rep 2,369
Drives: E63 645Ci
As I said before, if they say that this 6/128 unit doesn't support ID8 it means either it's a fake or they have no clue what they're talking about. Every single genuine A12 unit comes with ID8 by default. If that doesn't, most likely it's a fake so I wouldn't bother waiting on update and simply pass on this one.
kelly660.00 |
03-23-2023, 05:37 AM | #1450 | |
138
Rep 294
Okay, I'll post the photos tonight |
03-23-2023, 09:01 AM | #1451 | |
Rep 14
I have another issue during package veryfication i have notification that footer is wrong. Please see attached photo. Any idea? What i did wrong? I already tried with 1.0.7, 1.1.4, 1.1.7... I tried with original name and also changed to : ...ota-only....zip Thank you for any sugestion. Best regards, Jacek |
03-23-2023, 09:38 AM | #1452 | |
1050
Rep 2,369
Drives: E63 645Ci
