11-20-2021, 02:21 PM | #133 | |
2430
Rep 2,707
Drives: Built not Bought 04 Z4 VF. E70
M8rc upp8r hand r8st of y8ar
W2A Intercooled Vortech V3Si, custom ducting, Alpha N, 60# Bosch,2.62 pulley, multi port WMI, Severn Tuning(pokeybritches), Tial, magnaflow,SS race muffler, 42 design,3.91LSD, H&R, Hotchkis,ST coils,Konis, Megan camber arms, AKG SS, Nylon mounts, Poly bushings, Carbon interior, CF Aero.APEX
11-20-2021, 02:31 PM | #134 |
Rep 7,537
That's what I'm saying too, why do teams have to be transparent on what engine they use etc, it's part of the strategy.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
11-20-2021, 02:34 PM | #135 | |
General
64686
Rep 24,943
Perhaps, there's a very 'good reason why .. HAM's Brazilian Warp-Speed was worldwide questioned and put under suspicion ! I'm pretty sure that Mercedes has something to hide ! In other words : Mercedes is 'chicken for a FIA investigation regarding the Rocketship top speed . The rest of your statement is actually BS .
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
11-20-2021, 02:50 PM | #136 | |
General
61783
Rep 19,954
///M Power-Belgium64686.00 |
11-20-2021, 02:50 PM | #137 | |
2430
Rep 2,707
11-20-2021, 02:55 PM | #138 |
General
61783
Rep 19,954
11-20-2021, 02:56 PM | #140 | |
Rep 7,537
It's only BS because you can't think logically, if something doesn't suit your world view you think there must be some dubious forces influencing the outcome to be like that - it couldn't possible be that your view point is wrong. i.e. redbull not being able to keep up is because of mercedes cheating, and not because finally mercedes have solved their reliability and setup woes. Look at Lewis's last corners in the qualifying lap, merc finally dialed in the w12 where it could hook up each corner flat out.
11-20-2021, 02:57 PM | #141 |
Rep 7,537
That sucked to see leclerc not make q3, same as checo.
Killed by Death13155.00 |
11-20-2021, 02:59 PM | #142 |
General
61783
Rep 19,954
///M Power-Belgium64686.00 Killed by Death13155.00 |
11-20-2021, 03:02 PM | #143 | |
General
61783
Rep 19,954
11-20-2021, 03:10 PM | #144 | |
Rep 7,537
Also if you want to pull quote two can play that game. Maxfia? 1) Vettel suspects yellow flag was withdrawn at end of Q3 “because Max was coming” https://www.racefans.net/2021/11/20/...ax-was-coming/ 2) Ex-F1 drriver questions why Verstappen wasn't penalized. https://racingnews365.com/ex-f1-driv...asnt-penalised 3) RB allowed to fix rear wing in parc ferme over flappy issues but not mercededs? https://www.gpblog.com/en/news/99375...overnight.html This is a common technique used to shape a narrative like it is factual and concrete, but all it is looking for a snippet or quote from an article and pulling it extremely out of context to suit a narrative. It is a dirty tactic used by people unable to get real factual data and want a fast way to attempt and prove their narrative. In this case the two max supporters trying to prove their unfounded conspiracies, because you can't prove conspiracy with fact you have no choice but to pull quote.
Steeler2430.00 Chappers 715531.50 Hulk Smash1030.50 inTgr8r2434.50 ToddBlack88595.00 ________4163.50 minn1914078.00 |
11-20-2021, 03:17 PM | #145 | |
Rep 7,537
Remember occam's razor, the simplest explaination is likely to be the correct one - and circumventing fia inspection and going behind the back of every single inspection to make illegal mods is much harder to explain and justify vs. solving an engine issue that they have been trying to fix since winter testing, and progressing car setup.
11-20-2021, 03:33 PM | #146 | |
General
64686
Rep 24,943
He said also: MAX damaged the wing by touching it ! HAM => It looked like I pulled my steering wheel forwards ,I got wear on my steering column . I wasn't happy with that , that's why It's been replaced and back to normal . LMFAO
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. Last edited by ///M Power-Belgium; 11-20-2021 at 03:47 PM.. |
11-20-2021, 03:35 PM | #147 |
Rep 7,537
[QUOTE=M5Rick;28274250]BTW dingnut marko has a phd in law apparantly, so if any of your garbage conspiracies are true he would be the prime candidate to launch a law suit - seeing he has engineers to help confirm if anything is fact or fiction in terms of mercedes and their controversial parts. But since he hasn't done a single thing that should be confimration that nothing you guys say has any real weight to it.
minn1914078.00 |
11-20-2021, 03:39 PM | #148 | |
Rep 7,537
BTW mercedes have been pioneering engine tech in the turbo hybrid era since the start, I wouldn't be surprised if they managed to fix relaibility issues of their pu and now are able to use the upgrades they made to their engine for this season to its full potential. Don't forget you are the one who made micro crack and engine gernading jokes about the w12. So logically if they fixed said issue they can go full out.
11-20-2021, 03:53 PM | #149 |
Rep 7,537
Next look at the side by side qualifying laps:
1) You notice lewis in the last few corners at times has to lift off the throttle but to a lesser degree than verstappen, and he is able to get back onto the throttle faster than verstappen. 2) You also notice when lewis brakes he also brakes less than verstappen. This shows you the w12 handles high speed corners better than the rb16b, so it isn't all straight line speed like you guys keep saying it is....
11-20-2021, 03:56 PM | #150 |
General
64686
Rep 24,943
It's back to normal , as you can see !
11-20-2021, 04:20 PM | #151 |
Rep 7,537
Apparently leclercs chassis was cracked, could be why he was so slow today.
11-20-2021, 04:33 PM | #152 | |
Rep 11,669
It was posted on Twitter by the waiter, that served the stewards their lunch. He overheard the whole discussion. |
minn1914078.00 |
11-20-2021, 04:33 PM | #153 |
Rep 3,659
///M Power-Belgium64686.00 M5Rick61783.00 |
11-20-2021, 04:36 PM | #154 | |
Rep 762
Drives: 2019 BMW X6M
Waiting on him too. PM'ed him NOV 8 & 9th and no response yet. He was on the forums NOV 17th.
2019 BMW X6M
2013 Lexus RX450H 2010 Nissan GTR AMS Omega 14 |
Killed by Death13155.00 ///M Power-Belgium64686.00 |
