BMW X3 Forum
BMW X3 Forum
      01-13-2016, 09:01 AM   #133
drewxnyc
20
Drives: X5
Originally Posted by Carbonm3ny View Post
Not sure if I missed this but does the x3 plays dvd movie and can it be program to play dvd while in motion similar to my f10?
Yea I am looking for a coder in the nyc area, but wanted to be sure about the dvd in motion as well. There is a pdf in the first post that lists all the options and DVD in motion is one of them.
http://x3.xbimmers.com/forums/showth...ght=nyc+coding
      01-13-2016, 10:37 AM   #134
M5Beast_NYC
Drives: 15 M5
Good News!
      01-20-2016, 04:00 PM   #135
PerryGunn
Idiot-in-chief
PerryGunn's Avatar
31
Drives: around: in: circles:
This thread contains some of the known working & tested options for the F25 LCI
X3 F25 LCI 30d M Sport
Alpina Roadster S
FSociety3816.50
      01-21-2016, 06:40 AM   #136
Tmost
Japan
Drives: 2015 LCI X3 20d Xline
f25 20d
I am looking for PSDZDATA 54.1. Anyone help me?
      07-09-2019, 02:27 PM   #137
Teedee
Drives: 2015 328d F31 M Sport pkg
Originally Posted by nyalpine90 View Post
your not suppose to drive with high beams on
What do you mean? Why, all cars come equipped with switchable high beams.
      10-15-2019, 03:29 PM   #138
Atlanteg
Drives: BMW X3 F25 LCI 20d 2016
Originally Posted by lbjgh View Post
Looking for coding options to adjust auto dimming mirrors that don't dim worth a damn...
JBBF 3080 ISP_HECKSCHEIBE dunkel (dunkel hell)
JBBF 3080 CODDT_00_SCAL_DIM_ECR_LIN 39 20 Dunkel ("35")
JBBF 3080 CODDT_01_SCAL_DIM_ECR_LIN 39 20 Dunkel ("35")
      10-15-2019, 03:41 PM   #139
Atlanteg
Originally Posted by HighPlainsCruiser View Post
The manual states that when in Accessory mode the 'Radio Ready' mode switches off automatically after 8 minutes, that seems about right, you can not listen to the radio for extended periods of time as it is now. There must be some code defining that 8 minutes, has anyone found it and increased that time?
It is:
(Car Access System, 3000 TC
CAS -> TC_TIME_KLR_OFF -> 08 (default 08 min.)
You can change to any other value in HEX.
For example: 0f (15 min).
Maximum will be - FF 255min
      11-04-2019, 09:55 PM   #140
arucano
arucano's Avatar
Drives: 2014 M6 Grand Coupe CP
2014 BMW M6 GC  [10.00]
[QUOTE=impulss;13150019]Here are all the features I added to my X3 thanks to my local MD coder.. I am loving it!
-Add fuel stop suggestion in NAV guidance
do you have the code for this? I apparently disabled mine by mistake
Thanks
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
      11-05-2019, 08:55 PM   #141
Toad535
Drives: F10 535 MSport
Anyone know what I would need to code to retrofit heated steering wheel? Is there a way in esys to see what changes would be made by a VO change, which I don't want to actually change due to warranty? Found some posts where it was done in fem_body for an F30 I believe but I have FRM, etc in my LCI F25.
      03-03-2021, 05:25 PM   #142
badgesnob
badgesnob's Avatar
Australia
Drives: F25 X3 xDrive 20i
2014 BMW X3  [0.00]
f25 coding
Is there an up-to-date guide for a newbie. Not sure what to download, and if an fsc code generator is required, etc...
      03-03-2021, 05:33 PM   #143
pungo
pungo's Avatar
Drives: Z4MC-X3-35i-525i, Corrado G60
This thread usually stays on the first page
      03-04-2021, 02:03 PM   #144
anyland
Drives: 2014 X3 28i
Hi all. I am an IT guy, so this isn't nerve wracking from that side. It is nerve wracking from the car side. I have a 2014 X3 and would love to make some of these changes. Specifically the macro camera change for a hitch I am planning on having installed.
What does this do to the BMW folks when they connect up to perform their maintenance etc. Does it hinder that? I.e. are they going to refuse service because I have changed some defaults?
      03-04-2021, 04:55 PM   #145
pungo
pungo's Avatar
No and no.
      03-04-2021, 05:55 PM   #146
anyland
Drives: 2014 X3 28i
Originally Posted by pungo View Post
No and no.
Thank you! For someone that has never messed with a car, but spent a career messing with everything from factory manufacturing lines to HVAC units, this helps ease the nervousness.
      03-27-2021, 05:08 AM   #147
VitorioUA
Ukraine
Drives: bmw x3
Hi All! My radio and idrive turn off when driver door is opened. How can a fix that or codin?
Or somehow make sure that the radio does not turn off after 8 minutes?
F25 2017
cas tc_time_klr_off - not work
In the Vehicle Settings > Doors/Keys check "Turn off after door opening" - I don't have that.
      12-17-2021, 01:43 PM   #148
denkodt
Drives: BMW 335xi E90
Disable Temperature below 37 degrees warning
Has anyone have any success with this dumb warning about temperature dropping below 37 degrees? I would REALLY like to disable it. It comes on with a sound and a warning message, and it's really annoying this time of the year.
Thanks
      12-17-2021, 02:06 PM   #149
pungo
pungo's Avatar
Thanks
I believe you can disable it so when you 1st start the vehicle and it's <37, it won't chime, but if while your driving, it drops below 37, it still chimes. I agree, it's annoying. I've been able to disable it on several E series, but not on the F25.
KOMBI>CC_TEMPERATURWARNUNG=nicht aktiv
      09-15-2023, 01:57 PM   #150
Heniek
Drives: E60, F25
Hi, I'm looking for coding option to enable headlight level adjustment. I've changed headlights H7 from USA to EU and now I have light switch with headlight level scroll.
      09-19-2023, 10:44 AM   #151
italyk1980
Drives: BMW X3 F25
Hi everyone. I have halogen headlights. Tried to make antifog lights work as adaptive in coners but after coding stoped working high beams.
Is it generaly possible to make it works on my type of headlights?
I tried these settings:
FRM> FRM_LAMPMAP 3080 > LAMP_MAP_PARA_SATZ_01 =BV_F025_wert_02__Cornerlight_ueber_NSW
FRM> FRM_LAMPMAP 3080 > LAMP_MAP_PARA_SATZ_02 = BV_F025_wert_02__Cornerlight_ueber_NSW NSW
FRM > U_EFF_CL> wert_08__13,0V = 82
FRM> LaMaster1 3073 > C_AFS_ENA >Ausgelesen>= F001_enable
FRM> LaMaster1 3073 > C_CLC_ENA >Ausgelesen>= F001_enable
FRM > LaMaster1 3073 > C_HBA_ADAPT_SHUT_ENA = F001_enable
xbimmers
