01-19-2016, 07:36 AM | #134 |
Rep 32
Hi all, I am wondering how many volts is the ambient light? do you guys know???????
And I assume that if I know the volt of ambient light, can I buy a LED strip with same volt and make it brighter? Thanks |
01-19-2016, 08:49 PM | #135 |
Rep 1,761
The way the lights work, there is an internal circuit that sinks the current through the LED and resistor, allowing it to light. You can think of it like a switch that shorts the other side to ground, but in reality there's a limit on how much current it can sink. Most LED strips need a lot of current and I doubt the circuit that operates the OEM led module can deal with that much current. There are ways to make an LED strip work, but you'd have to retire and/or add circuitry to power it. Not really worth the trouble I don't think.
01-19-2016, 09:32 PM | #136 |
Rep 1,761
Hey Daniel...what's the technique for opening the light module? I see there are four tabs you need to pry to get it open but I don't want to break them. Is there a technique you can share?
I picked up a couple of the new modules. I'm gonna swap them in but I ordered some different LEDs and resistors to experiment with the old ones. I'm going to see if I can get it even brighter. |
01-20-2016, 07:08 AM | #137 | |
Rep 32
01-20-2016, 07:12 AM | #138 | |
Rep 32
I've tried open the edge of the LED module like the following photos. |
01-20-2016, 07:30 AM | #139 | ||
Rep 1,761
01-20-2016, 07:34 AM | #140 | ||
Rep 1,761
01-21-2016, 01:55 PM | #141 |
19
Rep 124
Anyone manage to get the dealer to replace them as deflective? I am going to try to ask them when I take my car in for service. Since there are two part numbers its easier to ask. I doubt they will do it, but doesn't hurt to ask
01-21-2016, 10:48 PM | #142 | |
Rep 5,316
Drives: G80 M3 6MT
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
07-14-2016, 12:46 PM | #145 |
Schmollbraten
12516
Rep 1,985
The shop doesnt ship outside of China, I was attempting to get those too
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
07-15-2016, 01:55 AM | #147 |
Schmollbraten
12516
Rep 1,985
Do you know or able to read asian signs? Theres no translator available onto the site...
07-15-2016, 01:09 PM | #148 |
Rep 32
Chinese made it for 3 series Li only, but they can cut the door trim in order to fit f30 and f34, it doesn't fit to f30 and f34 perfectly. I asked them send me their product, however, they said unless I pay for their staff and the air ticket, otherwise they won't send me their product.
07-15-2016, 02:09 PM | #149 |
Schmollbraten
12516
Rep 1,985
Whats that for kinda nonsens? The seller wont sell unless you pay additionally for foreign installation of his staff like you did before? Ridiculous...
07-16-2016, 08:32 AM | #151 |
Schmollbraten
12516
Rep 1,985
So if you buy another set of the items you'll get them only if the whole lot of the MFR is invited to install elsewhere again? Man...
07-17-2016, 08:47 AM | #152 |
1ST CLASS AWMSPORT
74
Rep 789
Drives: 13' 328 MSPORT
Correct me if I'm wrong but I thought I saw somewhere on the form that can remove the outer black covering the light without taking the door panel off can somebody confirm this please
07-17-2016, 08:59 AM | #153 |
Schmollbraten
12516
Rep 1,985
Dunno how. The trims are fixed behind the cover with one-way rivets and get changed after mod with self cutting screws which are going into the new trim lines...
11-23-2016, 02:38 PM | #154 |
Rep 20
Extra Door lighting strip
Hi Gents
I've just installed this lighting strip, which I bought really cheap off e-bay.. quite fiddly to fit with a few small slots/cuts in to the door trim, but the overall affect is quite good, only one draw back...its permanently red, even in the day light... I had to wire them into the electric window switches, because i originally wired them in to the led module wiring, but they made the ambient lights flash and then cut out, not sure why?, but so far no issue with the window switches, they even dim with the dashboard light dimmer control. |
