01-22-2024, 06:10 PM | #133 | |
32
Rep 96
I am waiting for mine. Got the 9 pin. Mine is pre lci led. I asked bayoptics which pin is correct and they told me 9 pin |
01-22-2024, 09:45 PM | #134 |
Rep 6
I think you got the correct one and should be good to go!
Unfortunately the seller told me to get 8 pin but turns out I needed the 9 pin instead for my adaptive Xenon. I just bought the wiring from Marius and hope they will fix the issue. |
01-23-2024, 12:48 AM | #135 |
32
Rep 96
Okay good luck. Post some pics after 👍
02-26-2024, 06:24 AM | #139 | |
Rep 1,387
I know this has already been addressed but just for anyone considering a DIY, the reason you cannot do this is because they gutted the light guides out and superglued LED strips in place. If you weren't already aware these are 2018 5 series headlights with the internals cut out and dumped into a 4 series housing, they don't make them brand new, they just sell you a modified set of headlights.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
SYT_Shadow11517.00 |
02-26-2024, 06:36 PM | #140 | |
110
Rep 165
Alpine-F80203.00 |
02-26-2024, 06:57 PM | #141 | |
Rep 5,963
I don’t see any issues with fourthirtyfive’s post. He was stating facts. There are quite a few new members that buy DRL modules along with fake ikons from vendors that massively mark up the price of these fake ikon headlights and know the modules can’t be used. These same vendors then charge a 25% return/restocking fee, if they refund at all (usually stuck with a store credit from a vendor they’d not want to buy from again), on an item that can’t be used on the fake headlights to begin with. If the vendors are not going to do it then that leaves forum members to spread the PSA’s/FYI’s. Not everyone will spend time exchanging information with Ali vendors to know what is/isnt oem like on the headlights. IMO, using cheap aftermarket headlights and taillights that don’t have the same functionality and brightness as oem DOT-certified lights puts other people in danger, not just you. You may have decided to accept the risks that come with the use of these inferior fake, not-DOT certified lights but the other people on the road with you have not. |
harunaspeedstar9.00 |
02-27-2024, 06:52 PM | #143 |
Rep 1,380
Get some PPF or reapply clear on them. Any budget headlight I've ever bought from China delaminates after about 6 months. That goes for HID and LED light sources.
It's a bitch to line up these headlights with the bumper and hood line on an F8X. So, do it right the first time. Not knocking aftermarket lights, but you will clearly see the difference in a few months use. Good for a few IG pics tho.
MGM Ext, SO int, Euro IKON, CS front lip, Carbon 1.5 diffuser, GTS/CS coding, M perf rear spoiler, & everything else STOCK.
(Previous E39 and NA1 NSX owner) Those were the days! Last edited by NSX2M4; 02-27-2024 at 07:30 PM.. |
02-28-2024, 07:03 AM | #144 | |
55
Rep 105
M2RAW122.00 |
02-29-2024, 11:17 PM | #145 |
Rep 3
03-01-2024, 12:36 AM | #146 | |
110
Rep 165
03-01-2024, 07:08 PM | #147 |
45
Rep 220
Hey I went with 8pin as well based on the seller comments (for pre lci xenon adaptive). I am guessing I need the 9pin as well. Got a link for the wiring harness?
03-03-2024, 12:11 PM | #148 |
Rep 3
03-04-2024, 04:13 PM | #149 |
Slow Guy
Rep 39
Stop being dramatic, the low beams are 2-3x brighter than "Dot certified" Xenons. Align them properly and you're putting no one at risk.
03-04-2024, 04:43 PM | #150 |
Rep 5,963
It’s a true statement but this comment was directed primarily at the GTS-style taillights which, with the brakes applied, can barely be seen in some photos.
03-05-2024, 01:30 AM | #151 |
Slow Guy
Rep 39
03-08-2024, 05:33 PM | #153 |
Rep 1,380
Good for you!
(Previous E39 and NA1 NSX owner) Those were the days! |
03-16-2024, 12:09 PM | #154 |
Rep 4
I Have had the ikons on my f82 m4 for over a year now and they work great. never had any issues. my only question is if anyone has looked into turning them yellow. would love to see if anyone has tried.
