07-10-2010, 06:47 PM | #133 | |
2011 E92 M3
34
Rep 432
MUCH less carbon footprint on those. You guys don't get it? It's all about emissions now. Look at Ferrari putting electric motors on their cars to meet emission standards.
2011 E92 M3 6MT
Gone - 2007 E90 335i |
07-11-2010, 12:52 PM | #134 |
17
Rep 162
Change out without lifting the car?
Is it possible to change the oil without jacking up the car? I am guessing the clearance below is going to be tight and I would need a VERY shallow pan.
Has anyone done this? How hard was it?
2010 M3 E92 Space Gray, Black Novillo
2MK,2MT,ZCW,ZPP,ZTP,302,5AC,4MZ,507,6FL,655,752,41 5,A52 |
07-11-2010, 12:57 PM | #135 |
Commander-In-Chief
2206
Rep 8,949
Drives: 2023 M2 Coupe, 2020 GLE 450
It would not be possible to reach and remove the drain plugs. Unless you are parked over a pit like at the oil change places.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
07-11-2010, 06:54 PM | #136 |
Rep 5,012
As Greg said, no way. I have the shallowest oil pan I've seen, and doesn't even slide thru. And remember you need space between pan and engine to remove drain plugs. A pair of 2x6s in front would have been enough, but rear drain plug is in FRONT of the sump, so you want car either flat or raised at the rear, not the front. Therefore I put rear on ramps and front on jack stands to level the car, which made the job a lot easier. Then dropped the front a notch and left it draining overnight. Good luck.
07-12-2010, 12:03 AM | #137 |
Commander-In-Chief
2206
Rep 8,949
Oil change foibles
Okay, mid-point oil change today. I've done this before, no big deal. Well, main drain plug comes out and proceeds to flip upside down into my drain pan's inlet. So, hot oil pouring out; I try to get it out with a screwdriver.
Didn't think until later that I could have used a magnet. Anyhow, about 2 liters of dirty oil flowed over the pan onto my garage floor, but it cleaned up pretty well in the end. Always something new to learn - HOLD ONTO THE DAMN PLUG!
07-14-2010, 08:43 AM | #138 |
Rep 8,496
sorry a bit of confusion here, so 2 questions:
1. There only only 2 drain plugs total correct? The manual instructions in first post lead it to believe there's 3. 2. in this pic of one of the plugs: The plug we need is simply the one front and center in the pic right? It looks like we got some oil on the metal parts around the plug? B/c slightly to the top and left of this above pic, there's another what appears to be a "plug-like cap housed in the side of the black round thing with holes" (it's out of focus in the pic). This is not the plug we need, correct? The confusion is the above pic's plug appears to be the "plug-like cap house in the round thing with holes" that appears in the location of the back arrow in pic in this post below: please confirm: 1. there are only 2 plugs to drain. 2. we're simply talking about the one front and center in the pic. Last edited by mdosu; 07-14-2010 at 08:54 AM.. |
07-14-2010, 09:05 AM | #139 | |
Commander-In-Chief
2206
Rep 8,949
Oil change
2. Correct. The other "cap like" black element you see at the top of the first pic and between the arrows in the second pic is the front jack lift point. The element at the bottom of the first pic is the oil sensor.
07-14-2010, 09:01 PM | #140 |
chris
279
Rep 12,144
^^+1
i can confirm the above statement. there are 2 plugs and not 3. the 2 plugs require the same bit size to unscrew. dont touch the black rubber thing in between the two plugs. thats just the jacking point. dont worry too much bout the little bit of oil thats on the pan. i believe my car has some residue like that as well. i think its probably due to the expansion and contraction of the metal oil pan and drain plug that causes a slight leak. you shouldnt see any oil dripping though. if you do, then you have a problem.
Current: 2013 F10 M5 & 2016 Mini JCW 2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone) |
07-14-2010, 09:02 PM | #141 |
Commander-In-Chief
2206
Rep 8,949
Oil foibles
Okay, this is not my week. I picked up a business associate for a 100-mile trip to Eugene for some meetings this morning. I allowed and extra 1/2 hour in our schedule for the trip. Well, I get about 15 miles down the freeway and notice a thin veil of smoke behind the car. WTF?! I pull over with things clicking into place in my mind. I had added 1/2 liter of oil the night before after changing over the weekend, and yes, you guessed it, forgot to put the cap back on! Giant mess in the engine bay. I stufffed a rag in it and got back home to add some oil and do a quick clean up. Cap was setting on a shelf in the garage. We were only 5 minutes late to the meeting in the end.
But, this is going to be all over my office!
07-15-2010, 11:15 PM | #142 | |
Rep 5,012
To make you feel better, I still remember when I bought my first nice car ('96 Lexus SC400 coupe), when we were about to move. It was 100ºF+, and one of the garage door springs broke, so had to change it. Didn't want my new baby roasting under the sun, so I figured I could do the job without pulling the car out. Secured my trusty 8' A-frame ladder, inches away from my baby, set the tools I needed on top, and proceeded to do the job. When spring gave up its death grip, momentarily lost my balance, and tools went flying over my brand new car . Funny thing is they took like half an hour to fall. You know how you can see them falling in slow motion. Scratched and chipped the crap out of my car's trunk and rear fender. Wanted to kick myself in the a$$. Unfortunately, that's how we learn our lessons sometimes. Glad yours wasn't as painful . But you were close man; oil shoots out of that hole like crazy from the cam gears, even when just the gasket is twisted. But in that instance, the 9+ liters in there saved your bacon. Take care. |
07-15-2010, 11:20 PM | #143 | |
Commander-In-Chief
2206
Rep 8,949
08-19-2010, 01:02 PM | #144 |
15
Rep 123
Has anyone had issues with the 6mm hex plugs starting to strip out? Went to change mine today with the correct hex drive and the front sump came out fine but the rear must have been over torqued because it wouldn't budge and then started to strip. I want to have a new plug on hand to replace this with before I complete the oil change. Lucky for me i didn't remove the front plug, only loosened it. I haven't seen this before as my 545 had the same hex plug and I have done many mid-interval oil changes with no issues.
08-19-2010, 02:30 PM | #145 | |
Commander-In-Chief
2206
Rep 8,949
08-19-2010, 03:15 PM | #146 |
15
Rep 123
Sure did. Those hex threads have always seemed a little delicate but this one has got to be over-torqued.
08-20-2010, 05:25 PM | #147 | |
chris
279
Rep 12,144
08-20-2010, 08:44 PM | #148 |
Rep 5,482
Give it a few taps with a ball peen hammer while you're turning it, lightly. Allen keys are terrible, which is why BMW uses torx everywhere, but a copper-gasketed steel plug in an aluminum oil pan is going to bind up no matter what you torque it to, correct or not.
Took 8.75l for mine, and about 45 minutes start to finish. Took another 10 minutes to let it idle long enough to get a few accurate readings and re-readings. I started at 8.25l, warmed up and checked, and it was calling for an additional 3/4l. Added half a liter and everything's peachy. Driven it fo several days now and it hasn't budged. Doesn't seem like such a big deal to get right the first time if you're patient?
08-21-2010, 03:14 PM | #149 |
Rep 5,012
Good point; that's why it's important not to overtorque those bolts. I've always done that by hand with zero problems, and probably end up putting a lot less torque than specified. Dealer put mine pretty tight from the 1.2K service, but I assume was done to spec. And remember to always loosen the bolts by hitting the ratchet with your palm; it's a lot easier to strip bolts with steady force than a quick jolt. Works like a charm .
08-21-2010, 04:03 PM | #150 | |
chris
279
Rep 12,144
08-28-2010, 12:42 PM | #151 |
15
Rep 123
Got my new drain plug. I'm nervous the stripped bolt isn't going to come out. Guess we will see...
08-28-2010, 03:49 PM | #153 |
18
Rep 396
Is it possible to change the oil just by driving up some ramps and leaving the rear wheels on the ground, i guess the only negative is that all the oil wouldn't come out. Is this correct?
11-13-2010, 09:29 AM | #154 | |
Rep 8,496
The hardest part is finding a low profile drain pan, I have the black one shown in the pics on this thread too, I think it might be too high. |
