Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > N52 Owners: Elec Water Pump Check-In Part Deux
View Poll Results: How many miles have you logged, and have you replaced your water pump yet?
Not yet, I have 60-75,000 miles 119 19.01%
Not yet, I have 75-90,000 miles 97 15.50%
Not yet, I have 90-105,000 miles 82 13.10%
Not yet, I have 105-120,000 miles 61 9.74%
Not yet, I'm invincible and have 120,000+ miles 69 11.02%
Yes, between 60-75,000 miles 35 5.59%
Yes, between 75-90,000 miles 49 7.83%
Yes, between 90-105,000 miles 44 7.03%
Yes, between 105-120,000 miles 34 5.43%
Yes, between 120,000 and xxx,xxx miles 36 5.75%
Voters: 626. You may not vote on this poll
      09-02-2020, 12:19 PM   #133
Michaluk_E92
Michaluk_E92's Avatar
Drives: BMW_E92_328i
Think I jinxed my self...
I just voted on this poll that I was between 90 and 100K. Without replacing the water pump. Well guess what @93k I had to replace the water pump and thermostat. That third bolt is an asshole am I right?
A. 2009 / 328i / manuel
B. It failed (overheated went into limp mode with my wife driving, scared the shit out her. She was on a busy road)
C. $412 in parts for FCP of course. No labor did it myself.
D. Replaced by me.
E. No damage.
F. No track days, she is not that kind of girl..
      12-04-2020, 03:39 AM   #134
Jesda
144
Drives: 2008 E93 N52 78k
I have 160k. Finally doing the t-stat and WP this winter. No codes, just preventative maintenance. I've owned the car for over 100k but I doubt it was ever replaced.
08 E93 N52 170k
      12-18-2020, 08:02 PM   #135
Brian86
Brian86's Avatar
640
Drives: e36 M3, e91 325xi, N50 Xterra
'06 e91mt 325xi
288k miles.
first 200k it was maintained by BMW with no record of replacement. 200k-280k it did not get one. Now I have it.
Not to say it wasn't done in in a driveway or by an indy during the first 200k, but as far as I know right now it's original.
(go gentle on the trolling, I've only had it a few months and it's needed a lot of TLC. It's on the maintenance list. Priority got bumped after I caught the radiator fan running in the garage after shutting the car down last week)
      02-28-2021, 10:10 AM   #136
horse9118
Drives: 2008 328i
100k miles on original water pump, hasn't filed yet.
      07-27-2021, 07:04 PM   #137
Igor_M5
Igor_M5's Avatar
Drives: Many, BMW.
Had 178k on my last N52 (2006) that still had the original cooling system, including the pump, I had never touched it in the 78k miles (3yrs) that I’ve owned it, with one exception for the micky mouse adapter that I’ve swapped out for a CNC one.
Otherwise... bump for a great thread.
      08-05-2021, 11:52 AM   #138
ntucker99
Drives: Bmw 328i
07 e92 328i mt
Failed at 141k miles
436 parts from fcp euro
replaced myself
hoses were damaged
Driven on COTA 6-7 times
      11-13-2021, 11:31 PM   #139
Brian86
Brian86's Avatar
640
I just pulled the (still good) pump out of my wagon. Radiator sprung a leak so it seemed like as good a time as any to do the pump/Tstat/Expansion bottle maintenance. Particularly since I already had all the parts.
It's not original. Neither is the Tstat. (I believe OE for 2006 was an aluminum Tstat housing). Tstat was missing one of the mounting screws. All the band clamps were pointed in directions that indicated somebody installed them in-situ. As opposed to those krauts at the factory that slap them on all willy-nilly with the engine sitting on a trolly.
If I'm reading my German identification numbers correctly it's a 2011 vintage Piersberg. Same p/n as my new one, but version .01 whereas my 2020 build is version .20. Interestingly the pump I pulled out has a BMW logo on it, which suggests it was purchased from a dealer.
I don't know for certain, but a 2011 pump would suggest the Piersberg version .01 ran for over 200k in my wagon without failing.
Sometimes a bolt is just a bolt.
      02-05-2022, 12:23 PM   #140
AdrianE36
AdrianE36's Avatar
27
Drives: E92 328i 6MT RWD
I had my WP, thermostat, and radiator + hoses and the Mickey Mouse flange replaced in January 2021 @ 137,291mi.
A. '07 E92 328i, 6MT
B. I was randomly checking my car using Carly and the ECU had a shadow code stored (002E84) but the car ran fine and didn't show any symptoms (yet, anyways). From what I could see from under the hood, the old WP had some rust spots on it which made me think it was factory original along with the thermostat being aluminum rather than plastic.
C. $477 in parts from FCP Euro
D. Replaced by indy: $1,800 in labor along with a coolant flush and the radiator also needed to be replaced as the upper neck cracked when they tried to remove the upper radiator hose.
E. No damage.
F. No track days.
E92 328i (N52), 6MT, RWD, Space Gray
Goal: Street/Autocross car
      04-09-2022, 02:38 PM   #141
gregfisher87
Drives: 2011 E91
Mine went out a couple months ago - went into limp mode on the interstate and needed a tow. had it fixed by a euro garage because I needed it back next day to get to work.
a. 2011 328xi MT
b. failed at 135,000
c. pump and thermostat, coolant flush 750 parts, 650 labor
d. indy
e. no added damage
f. never tracked
      09-06-2022, 10:43 AM   #142
bsmoov
Drives: e91 6 speed touring
Bought an amazon waterpump and replaced it during the pandemic for preventive maintenance since back then we had the stay at home order...
fast forward to July 2022, that cheap chinese $140 waterpump failed. Not too bad and can't really complain because it lasted about 3 years, but this time I wanted to not be cheap and bought the kit from ECS tuning. I didn't even check because I assumed it was gonna have quality parts like the kit from FCP euro, but I went with ECS because it was a little cheaper. Low and behold when I replaced it in July 2022, I found it weird that it was a Bavarian Autosport Brand water pump. It looked exactly like the amazon/chinese knockoffs but it had a Bavarian Autosport branding printed on the body of it. Very cheap printing at that as its was faint and could rub off pretty easily. Anyway, that sorry ass water pump failed in less than 2 months. Now I have to go through the return process and they're giving me the run around.
Do not buy the kit from ECS tuning...I should've bought it from FCP euro and had peace of mind with their lifetime warranty.
      10-05-2022, 08:23 PM   #143
brogrammer
Drives: 2008 bmw e90 328xi
Around 97K miles.
This happened last year.
I replaced the pump and it failed within 24 hours.
I had the pump w a better one and its still going strong.
      10-25-2022, 03:34 PM   #144
Suvorovo
Suvorovo's Avatar
258
Drives: Broken e90 330xi 6MT
Previous owner replaced thermostat and waterpump at around 100k miles as preventative maintenance. Did a bunch of suspension and other work too. See you at 200k.
      01-05-2023, 06:29 PM   #145
k90
43
Drives: -06 330xi 6MT
1/2" socket doesn't work in this specific bolt because of the subframe.
I'll pick up smaller E12 socket tommorow. I think 1/4" might handle it.
At least thermostat housing looked like original from the factory. Will see if the pump is. 245000km.
      01-06-2023, 04:30 PM   #146
k90
43
Pump is casted in year 2006. 245000km. Preventive maintenance, not a pump failure.
      12-08-2023, 08:38 PM   #147
EFk
Drives: 2007 BMW N51 328i
a. 2007 / 328i / Auto (GM) / currently at 127k
b. Never failed
c. -
d. -
e. -
f. 50% city 50% highway / easy driving
      03-04-2024, 04:00 AM   #148
yellowltd
Drives: '07 328i 6spd
a. 2007 328i manual
b. Failed-ish - the pump would work but then stop after driving for a bit, restarting the car would restart the pump, it would run for less and less time. I bought the car like this at 125k miles.
c. I believe I paid about $550 for the parts - pump, thermostat, & every hose I touched.
d. I did the work myself.
e. Not that I am aware of. Car now has 156k.
f. Not yet.
