Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Supercharger stuff (MILVs+AA+BPC)
      03-14-2024, 11:51 AM   #1519
shimstack
63
Drives: E91 6MT RWD
I'm still in the hunt here. Not using the ESS kit, I'm going to fab my own system.
I'm finishing up the N54 intake manifold and TB install and now seems to be a good time to install check valve(s) to keep the boost out of the crank case.
I retained the check valve from the N54 TB to the fuel tank vent. It seems like one is also needed in the PCV line between manifold and valve cover.
Any others?
      03-14-2024, 12:01 PM   #1520
shimstack
63
Drives: E91 6MT RWD
Or do I need to re-route this line to the intake upstream of the SC and plug the port in the manifold?
      03-16-2024, 10:59 AM   #1521
shimstack
63
Drives: E91 6MT RWD
I found the answer here in case anyone else is looking:
https://www.e90post.com/forums/showt...1143622&page=3
Also ESS doesn't list the N52 kit anymore, but it seems you can buy the parts:
https://esstuning.com/n52-vt/
Torgus3781.50
      03-27-2024, 01:05 PM   #1522
Igor.v_a
29
Drives: BMW E92 330i, ESS Supercharger
Originally Posted by dmytro98 View Post
The crank hub I got wasn't meant for the n52. It said it would only fit the n54 but all I needed to change to make it work on the n52 was using an n54 oil pump sprocket that the crankhub slips into as it was different sizes. Everything is shared between the n52 and n54.
The one on the left is the original crankhub, and the one on the right with the splines is the VTT n54 splined crankhub
How does the crunkhub from N54 work on your engine, is everything good?
My crankshaft bolt came loose again.
This has happened to me three times already.
      03-27-2024, 04:53 PM   #1523
dmytro98
88
Drives: bmw 128i coupe
I've had no issues with the n54 crankhub, but if you're thinking of swapping to that I don't think it would help keep the crankbolt coming loose. What are you torquing it to? Double-check if I'm right but I believe it's 100nm+360 degrees with no thread locker, but I've seen some people say to put oil on the threads.
      03-27-2024, 05:10 PM   #1524
dmytro98
88
Originally Posted by Igor.v_a View Post
Guys, does anyone know how many degrees water-methanol 50/50 reduces the temperature in the intake manifold?
Has anyone installed a temperature sensor in the intake manifold?
It's interesting how much the air heats up due to the supercharger.
My numbers might vary since I'm at around 6-7000 feet of elevation, but running a 3.12in pulley, I'm making 10psi above 7300rpm, and just doing a couple pulls on the street my IAT's have gotten as high as 180f, with the iat sensor in my chargepipe. This is with ambient temps of about 50f.
Currently I'm on full e85, or I guess e70 since that's what it ends up testing at, but I'm planning on running the water to air manifold that stagefp should be releasing soon.
      03-28-2024, 02:38 AM   #1525
Igor.v_a
29
That's right.
Tis says 100Nm + 360 degrees turn and lightly lubricate the thread.
We did just that, added blue Permatex thread locker and the crankshaft bolt still came loose.
Then we installed a new bolt, but no longer lubricated it with oil, but only with thread locker.
Even the OEM washer was installed from N54 and the bolt still came off.
I do not know what to do.
      03-28-2024, 02:46 AM   #1526
Igor.v_a
29
I also have an 80mm supercharger pulley installed.
At minus 10 Celsius, my boost gauge showed 13 psi. 6900RPM
Now it's plus 8 Celsius outside and my boost sensor shows a maximum boost of 11.5 -12 psi. 6800RPM
In the coming days, I will also install an IAT sensor in the intake manifold.
I also have a WMI injector installed in front of the throttle body.
22RPD recommended adding a second WMI injector, upstream of the supercharger.
And measure IAT temperature
      03-28-2024, 12:46 PM   #1527
Igor.v_a
29
I found a solution to prevent the crankshaft bolt from coming loose.
https://www.ecstuning.com/b-vargas-t...t-n54-cbc~vtt/
      03-29-2024, 01:12 PM   #1528
dmytro98
88
I had that same exact crankbolt capture, and that is why all my crank pulley bolts broke off. I've known of at least one person who tried it and had the same thing happen as me. I would highly advise against it since with it you risk having to replace your crankhub. I'm not sure what the solution is but I definitely wouldn't run the crankbolt capture.
      03-29-2024, 04:27 PM   #1529
Igor.v_a
29
Today the valve timing went wrong again while recording Log
WOT
This is probably the fourth time this has happened to me.
How did you overcome this problem, what exactly did you do to prevent the crankshaft bolt from coming off?
I don't understand at all why this bolt comes loose.
After all, the N54 engine has much more torque than ours.
And the N54 is doing well.
      03-31-2024, 12:09 PM   #1530
Torgus
Slow.
Torgus's Avatar
Drives: Single Turbo N54 on Meth!
2007 BMW E92  [10.00]
2007 BMW E90  [0.00]
2006 BMW E91  [0.00]
The N54 eats crank bolts as well. Just usually at power levels a little bit less than double.
https://vadersolutions.com/products/...uZDyyUj6iRnfVQ
      04-14-2024, 05:38 AM   #1531
Igor.v_a
29
There is an assumption that the crankshaft bolt unscrews the belt or the crooked torsional vibration damper.
A belt that is too short creates a strong load on the crankshaft damper.
What article number (size) of belts do you have on the 80mm pulley?
      04-14-2024, 05:48 AM   #1532
Igor.v_a
29
Originally Posted by Seattlesquash View Post
Guys at 22RPD hooked me up with a new sexy belt. Other continental one ran great, but since nothing breaks I had to do something!
Cheers,
What belt size (article) do you use with an 86 mm pulley?
      04-15-2024, 01:30 AM   #1533
dmytro98
88
I don't know the length of it since It came from 22rpd as part of the upgrade kit but it's called "Gates K060997HD FleetRunner Micro-V Serpentine Drive Belt"
      04-15-2024, 06:22 AM   #1534
Igor.v_a
29
Are you using this belt with an 80mm pulley?
Is the belt not slipping?
      04-22-2024, 08:42 PM   #1535
dmytro98
88
As far as I can tell it isn't slipping with the 80mm pulley, but the tensioner is just about maxed out. I also forgot to mention that I'm also running a larger idler pulley on the supercharger which I also got from 22rpd
      04-30-2024, 02:07 AM   #1536
Raccoon
Drives: 2010 bmw 328xi swdan
M3 injectors maxed.
22 rpd got back with me after some data logs and apparently the s65 injectors are maxed out.
Setup is currently
S/c G1
110 mm pulley
N54 manifold
Headers.
Was surprised I was making enough to max the injectors.
      05-13-2024, 11:46 AM   #1537
shimstack
63
Drives: E91 6MT RWD
First startup will be tonight. Hopefully!
I'll post full details in my thread once it's up and running. Thanks for everyone's help here.
Appreciate 3
      05-13-2024, 12:51 PM   #1538
Torgus
Slow.
Torgus's Avatar
2007 BMW E90  [0.00]
2006 BMW E91  [0.00]
Which rotrex SC is that?
Hope it was worth all the work!
      05-13-2024, 01:45 PM   #1539
shimstack
63
Drives: E91 6MT RWD
C38-71. Flows up to 660hp worth of air. I'm starting with the largest pulley and expecting 5ish psi. 22RPD said to do some gentle driving and send them some logs before going WOT. I'll downsize the pulley as the tune/IC/fuel allows.
Torgus3781.50
      05-17-2024, 08:00 AM   #1540
shimstack
63
Drives: E91 6MT RWD
Does the StageFP tune use the MAF?
